Question about KitchenAid KSM90 Ultra Power Series Stand Mixer
I have mixer model #4ksm90wh. It has a slow leak of oil from the circulating part above the bowl and into the base, probably from being tilted up. It's probably a seal or gasket that is worn. I haven't opened it up yet but if this is something a mechanically inclined person can tackle? What is the problem? Where can I get the parts and what kind of oil is used? Thank you, Ross
SOURCE: kitchen aid tilthead mixer will not lock down
The solution for both of these is a large screw that sits at the base of the head where the head and the base meet - you'll see it when you tilt the head up. This screw should not be all the way in. You can adjust how low the head goes- in the case of your blades hitting the bowl you'll want to let the screw out a bit; in the case of the locking, you'll want to screw it in a bit more.
Posted on Mar 17, 2008
SOURCE: Oil leaking, sounds like the problems folks are having with the K55 model
I've got the same problem, I put my mixer in a box when I moved and it must have gotten tipped over cause there was oil all over it that spilled out from inside. How can I crack this thing one and refill the oil and what oil spec does it need?
Posted on May 24, 2008
SOURCE: Replacement beaters
I had an SM100 which did not work when I got it out to make cookies recently. So, I have both bowls available (large and small), beaters, dough hooks, whisks and the use and care book too! I sure will miss that mixer. Contact me at lindareagan@comcast.net
Posted on Dec 06, 2008
  • 7 Answers
SOURCE: KitchenAid 250 Watts; Classic: Leaking Oil
Found this,may be helpful.
Why do I see oil leaking from the beater shaft of my stand mixer?
Some KitchenAid® stand mixers that are not used very often or have been tipped may experience slight oil leakage from the shaft or hub attachment. To avoid the oil leakage, KitchenAid suggests that you run the mixer weekly for short periods of time. Generally, the mixer may lose approximately X cup of oil before repair is necessary. The oil used is FDA approved and is not harmful to consume, should any get into the food that you are preparing.
Posted on Dec 15, 2008
SOURCE: kitchenAid stand mixer is leaking alot of oil
ok, there are 4 skrews holding the body together on its white underside( or what ever color you have.) after you get those there are like 9 or 10 little skrews under a shiny rig that goes around the shaft that does all the work in the bowl. pull the ring off and take out those skrews. after that... well i have to find out for myself how to fix the oil leak! good luck and if you find out let me know! BTW here is a link to the service manual.
http://store.mendingshed.com/k45map.html
Posted on Dec 29, 2008
What model kitchenaid was made in december of 1973?
Is the brushed band around the head missing or worn off? The model is on that band. If it worn or missing in order to correctly answer your question I need more information. Is your mixer a tilt head or a bowl lift variety? Did you look on the bottom of the base for a serial number? Some models had them there. Can you describe the ceramic piece a little better? Many models shard the same internal parts and it might not be too difficult to locate that part.
Aug 03, 2014 | KitchenAid K45SS Classic Stand Mixer
Where do you find the serial number for a 5 quart glas bowl for the Artisan mixer
The serial number for all KitchenAid mixers is located under the base of the mixer. You will need to carefully tilt the mixer over, and underneath the mixer you will find a label with the model number and serial number.
Feb 16, 2013 | Kitchenaid 5 Quart Glass Bowl Artisan...
Is a kitchen aid model # KSM5PSAC the same as KSM150SP?
The KSM5 and the KSM150 are different mixers. They are both 5 quart mixers and use the same gearing and motor. However the bowl design is different. The KSM5 is a 5 quart bowl lift, which means the bowl locks into the arms of the mixer and raises towards the head of the mixer, where the ksm150 mixer is a artisan mixer, which is also a 5quart mixer, but the head of the mixer tilts back and the bowl twists into the base ring to lock into place. These two mixers will take different bowls and beaters.
Thank you,
Colleen
Customer Service
MendingShed.com
Jan 27, 2013 | KitchenAid KSM150PS Artisan Series Stand...
My beater, dough hook, and wire whip all hit the bottom of the mixing bowl. I have been told that I can adjust them. Can you tell me how? Thank you
On the tilt head models there is a "Stop screw" that adjusts how far down the head goes. I just can't remember if it's in the head or base. I use the other model that lifts the bowl.
Dec 31, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
Kitchen aid mixer leans forward too far, causing the mixing attachments to rub on the bottom of the bowl instead of rotating just above the bottom of the bowl. how do i fix it?
Is this for a "tilt neck model? If so, the manual suggests that there is a small screw in between the base stand and the "neck" of the mixer. You should be able to screw it in or out to adjust it. Good luck!
Oct 24, 2010 | KitchenAid K45SS Classic Stand Mixer
I have model A-200-D Hobart mixer. Serial # 1575984. It is leaking oil into the bowl. Who can I call to get an estimate to service or repair this machine?
The oil leeking into your bowl is old grease that has broken down into oil and is getting past your oil seal you need to take out all of your old grease and oil replace it with hi-temp grease or a good grade lithium grease and replace your agitor shaft oil seal
May 16, 2010 | Food Mixers
Beater rubbing bowl
Although I can't find your mixer by the model number you gave me, I assume that your mixer is the kind which the bowl moves up and down not the "tilt-head" style.
See pg. 12 of the owners manual for bowl height adjustment procedure:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%209707946.pdf
There is a screw in the base of the mixer which is turned
clockwise to raise the bowl
and counterclockwise to lower
the bowl.
Apr 04, 2010 | KitchenAid K5SS Heavy Duty Commercial...
Can't get the screw adjustment to change the height of the bowl
I had a similar problem with mine - the problem turned out to be that I hadn't clicked the bowl into place corectly. If you find the bowl is tilting forward slightly then you probably need to push it into the clip at the back.
May 17, 2009 | KitchenAid KP26M1X Stand Mixer
Kitchenaid Mixer head wobbles bad
The solution provided by luannej is useful only if your mixing attachment is striking the surface of the bowl. By adjusting the screw located at the junction of the head and base, you are actually controlling how far the head is allowed to tilt forward and, thus, the height of the attachment above the bottom of the bowl. Although the attachment striking the bottom of the bowl will lead to wobble (and noise!), it isn't usually the root cause of the wobble. In fact, the wobble may be causing the bowl strikes and adjusting the head height only hides the problem.
The head of the mixer is secured to the base by a large steel pin. Any play between the head and base comes from this hinge and its resulting tolerances. To "tighten" the sloppy tolerances causing your wobble, follow these steps: 1) Lock the mixer's head down and turn the entire mixer upside down. 2) Looking deep into the hollow base, find the small slotted set screw. This screw actually presses against the pin and takes up the slop between the head and pin. Note that this screw is not the large slotted screw I mentioned earlier visible when you tilt the head back. 3)Tighten the small set screw as much as you can. Your wobble should be greatly reduced or eliminated now. 4) Lastly, you may want to readjust the large screw controlling the head's tilt to optimize the distance between attachment and bowl. Hope this helps.
Oct 24, 2008 | KitchenAid Artisan Series Tilt-Head Stand...
Kitchen aid tilthead mixer will not lock down
Nov 13, 2007 | KitchenAid KSM90 Ultra Power Series Stand...
KitchenAid KSM90 Ultra Power Series Stand Mixer Logo
149 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
