Lines running verticaly through the screen. - Audio Players & Recorders
  • shadychic_8 Feb 14, 2009
    vertical lines on the screen...
  • Anonymous Feb 19, 2009
    colored vertical lines through screen shortly after I've been using docking station.
  • 8,596 Answers
LCD cracked - can't be repaired - replacement only - sorry
You can try any software fix that your manufacturer might suggest, but i have never seen a single case where it has worked
Posted on May 29, 2008
Lines flickering verticaly thru screen
l would check to see on a rear input (audio/video) if this happens and if using a coax connection wiggle the cables with set on and doing this--a poor shield connection on a coax cable will do this also.
Trying the rear input will rule things out and may offer a way around the issue.
Dec 21, 2012 | Hitachi 50UX57B 50" Rear Projection...
Vertical lines on video
best bet to get that video on pc 1st ok then convert it to dvd format 720x480 29.97 fps mpeg 2 use allok software online to convert then burn to dvd play perfect use nero 7 to make dvds proably is flat screen your resoution proably dont match up or the verticaly sync in hertz is higher cuses the vertical lines so do that way to make pro videos
Jan 27, 2008 | Video Cameras
Tv takes up to four minutes to turn on and when it does it has distorted red lines running verticaly across the screen
is there retrace line with red colour then off agian.if yes there is red gun problem which is shorted with have to do give another way heater ac voltages or replace picture tube.
Oct 16, 2010 | Samsung Televison & Video
Nothing but multi colered lines verticly on the screen
Try this:
Turn it off.
Disconnect power cord and any other device attached to it.
Take battery out.
Without anything attached. Hold down the power button for 10-15 seconds.
Connect the power cord only.
Hold down F2 (while it's off)
Turn it on while holding down F2.
Let go of F2 when something comes out of the screen.
If multi colored lines still appears.
You have either defective LCD(screen) or video card.
Jan 30, 2010 | Toshiba Tecra M2 Notebook
Taking pitures with lines in betwen verticaly
Vertical lines in picture is problem of electronic shutter that is part of lens assembly.
Lens assembly will be replaced to correct this problem. It is hardware issue.
Dec 26, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
My 42 inch lg plasma has colorful lines running verticaly on the left side of screen. i moved it to another location then it worked for a few hours then went back to the lines. what is the problem?
u might had placed some powerful magnet nearby, so pls check
if lines appear again switch it off for a few hours or remove the magnet and let it work...
it will become normal when the effect will be over
Jul 11, 2009 | LG 42PM1M 42 in. HDTV-Ready Plasma...
50' LG plasma TV has thin lines running verticaly through tv
HI, this will happen when the power isn't distributed correctly, in return, depriving the main board of its needed current for operations. this will usually produce these lines. Replacing the power control board will fix this issue. LG Electronics/Zenith Part Number: 6871QYH039B
Jun 03, 2009 | LG 50PC1DRA 50 in. Plasma Television
I have red lines up/down on my Vizio, how can I correct this?
Your sympton need to be more specific, but if what you see is 1 or more tiny lines running from top to bottom of screen (verticaly) and those lines change colors (red/green) depending on the background color on the screen, then your control board need to be replaced, you will need your TV model and product code, both located in the back of the TV next to serial number
Jun 03, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
My Aspire 3003LCi has different colored lines streaming verticaly down the left side of my screen. This happened on my other comp and it eventually went completely back. Please Help soon before my computer...
There's nothing you can do. It's hardware related. Either the video card (gpu) or the lcd (most likely) is failing.
You'll have to replace some hardware to correct the issue.
Try using an external monitor, if the lines still appear then your video card is the problem, if not it's most likely the lcd.
Sorry for the bad news but it is what it is.
Mar 10, 2009 | Dell Inspiron 9100 Notebook
99 people viewed this question
