Question about Lexmark X83 All-In-One InkJet Printer
My lexmark x83 is making a clicking noise and will not pull paper through.
    Scholar:
  • 107 Answers
Hello, the problem with your machine is a gear that drives the paper feed section, not the paper feed roller but the platen roller, well its cracked, unless you have an identical machine, you will not be able to repair this printer, i have tried. so, this machine has performed for you extremely well, but now it time to look for another one. sorry
Posted on Oct 07, 2010
I need a installing discs for Lexmark x83
Please visit the Lexmark website to download and install the Lexmark X83 Printer Driver on your computer. Select your operating system > click on "FILTER" > click on the driver under Recommended Downloads > download and execute the file. Simply follow the instructions on your computer screen to complete the installation.
Should you really need the installation disc, please contact Lexmark Technical Support Center for assistance.
Jan 18, 2012 | Lexmark X83 All-In-One InkJet Printer
Paper feed problem
The clicking noise is an indication that something's not right in the printer. But try taking out the cartridges from the printer. Then, close the cover. Remove all sheets of paper. Unplug the power supply from the printer. The power supply is the black box behind the printer where the power cord is attached. Wait at least 10-15 seconds before plugging it back in. Once printer's ready, reload the cartridges. Load some paper and try to print again. If this doesn't help and you're still getting that continuous clicking noise, it's a hardware issue. If that's the case, I strongly suggest you contact Lexmark Technical Support for further assistance. I hope I can assist you more on this.
May 28, 2010 | Lexmark X83 All-In-One InkJet Printer
How do I remove the cover of my lexmark X83? The paper will only feed part of the way then I get a paper jam message.
there is a cover there at the back of your printer, pull it down then remove the paper hang on their, then after you remove , check if there is another paper to hang, after that try to print
Jul 01, 2009 | Lexmark X83 All-In-One InkJet Printer
Lexmark x83 paper feed problem
If your not qualified to do this I would not sugges you do it, tho here is a solution for you. See if its snapped in place instead of being bolted down. you can also access underneath the unit hope this helps.
Apr 22, 2009 | Lexmark X83 All-In-One InkJet Printer
Paper keeps jaming
problemwith the roller or with the gear which is attached to themotor
Jan 10, 2009 | Lexmark X83 All-In-One InkJet Printer
Lexmark X83 prints streakily or not at all
Have you used a new cartridge.
Do the test for running and cleaning new cartridge heads and the alignment procedure..
(Go to Start, settings, printers, right click on printer then click properties, cartridge maintenance.)
Other thing that might cause problem is build up of ink in right side of machine below printer cartridges.
You will have to strip down machine to get at this area.
Make a note of exactly what action you take when doing this so that you can bits back together.
I use cotton buds to get at the build up of ink or tissue wound round end of pointed object.
Go gently. When you have cleared what you can care reassemble bits and go through above procedure again. Check for any unusual noises that may denote part of mechanism has worn.
Alleluia
PTL
Nov 24, 2008 | Lexmark X83 All-In-One InkJet Printer
Paper won't feed in my Lexmar X83
insert sandpaper into printer tray. begin print. hold the sheet tightly and DO NOT let the printer feed it in. it worked with my lexmark z611.
Jul 23, 2008 | Lexmark X83 All-In-One InkJet Printer
Lexmark x83
Sounds like there is something like a part of a sticky address label, or a piece of other paper stuck inside.
Take a heavy piece of card stock and feed it through the paper path. Chances are, when you get the card stock all the way through, it will push out the offending object that is hung in the paper path.
May 19, 2008 | Lexmark X83 All-In-One InkJet Printer
Paper will not feed into printer
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Oct 17, 2007 | Lexmark X83 All-In-One InkJet Printer
LEXMARK X83 PRINTER 1) A few times papers jammed too far back to pull out from the front so i pulled them out the back. Now when the paper feeds there is a clicking noise and the papers feed only...
Oct 10, 2007 | Lexmark X83 All-In-One InkJet Printer
Lexmark X83 All-In-One InkJet Printer Logo
105 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
