Question about Westinghouse LCM-19v1 Monitor
Screen went blank. Power light shows green but nothing else.
  • 11,361 Answers
Starting looking for bad caps in the power supply.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Oct 07, 2010
My acer is not coming on ,there is power going into my lap top but the screen is completly blank?
Bring your laptop under sunlight. If you look very closely and can see your screen then your backlight went out. Otherwise there might be a loose/broken connection to your lcd.
Jul 03, 2012 | Acer Aspire 5535-5050 Notebook
Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Jul 21, 2009 | Dell E173FP 17" LCD Monitor
Fujitsu plasma screen went blank and the LED light which generally shows green (on) or red (off) is blank (no color) as well.
Usually when these develop a fault you will get flashing LED codes. If you are not getting any the power supply may have failed completely.
Try another cable and socket in the first instance and ensure the manual power switch feels normal in action.
Jul 06, 2009 | Fujitsu Televison & Video
Dell 24'' Ultrasharp went blank
I suspect the invertor supplying power to the Xenon backlight tubes has failed.
This can be reapired but may not be cost effective.
Ask for a quote from your local computer specialist but keep in mind the cost of a new monitor.
Mar 18, 2009 | Dell Computers & Internet
ViewSonic LCD (VA1912w) Went Blank
I am using this great LCD for about an year. But few times in the past my LCD didnt show up the display though the Green light was still ON, turning off the LCD and opening it again always solved the problem. But now My LCD completely went blank. Turning off/on didnt work at all now. I've tried couple of other tweaks mentioned on this site but they didnt work. I am just seeing a blank screen with green light ON. and ya theres a very low hissing sound coming from the LCD.
Feb 18, 2009 | ViewSonic VA1912w 19" LCD Monitor
Sony KDF-46E2000 - Screen Goes Blank
The lamp can cause the picture to cycle without spitting out a lamp error. I'd replace the lamp and clean out the dust/dirt from fans, etc to hopefully resolve your issues.
Dec 06, 2008 | Televison & Video
You definitely have a bad lamp. Sony rates the lamp life at between 4000 and 8000 hours. There are 3 things that effect the lamp life, listed in order of importance:
1) number of times the lamp is turned on and off. Every time the lamp is first fired, it takes life off the lamp. Customers I see that turn the TV on in the morning, leave it on all day and then turn it off on the evening can get up to 12000 lamp hours
2) ventilation. Be sure you have at least 6 inches of open space all the way around the set and that the vents are clear of dust and debris.
3) power. If the power is interrupted when the set is on, there cannot be a proper cool down cycle. The fans will run after you turn the set off to properly cool it down, if the power is lost this cannot happen. If your power is unreliable, buy a small UPS to let the set finish a cool down cycle
Occasionally a lamp will faill before the average lamp time due to being defective. from your purchase date it sounds like you got about average lamp time. Be sure to purchase AN ORIGINAL SONY LAMP as a replacement, becuase the aftermarket lamps are bad news, Be sure to rate this solution. Thanks!
Oct 13, 2008 | Sony KDF46E2000 46" Projection HDTV
Bank Monitor problems
Unplug the cable from your PC, if the monitor shows a test image, the monitor is fine and the problem is with your graphic card. If you dont see nothing on-screen after unpluging the cable from the PC, then the monitor in damaged. Send it to repair.
Jul 09, 2007 | Dell E193FP 19" LCD Monitor
Westinghouse LCM-19v1 Monitor Logo
90 people viewed this question
Top Westinghouse Computers & Internet Experts
Jim Goldsmith
Jim Goldsmith
Paul Bade
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
