Home
My Products
Sign In
Back to:
All Products
Hotpoint
HSS25IFMCC / HSS25IFMWW Side by Side Refrigerator
Troubleshooting
Tags
WATER DISPENCER
low flow
low water flow
ice water dispencer
Water dispencer
posted by
tylane
on May 29, 2008
Report abuse
Water continues even after you remove tha glass.Also even when you switch to ice which works fine.
Solve This!
I have the same problem.
X
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
OK
Solution #1
posted on May 29, 2008
micbeth1981
Rank:
Guru
Rating:
88%, 149 votes
RELAY BOTTON IN PANEL IS IN THE CLOSED POSTION KEEPING THE WATER FLOWING,REPLACE OR WATER INLET VALVE ON LOWER BACK OF FRIG. IS STUCK OPEN,REPLACE,THANKS-MIKE
Was this solution helpful? Show your Appreciation by rating it:
Inappropriate
Thanks for Trying
Helpful
FixYa!
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Water dispencer:
I don't want to Accept this solution
Done
Suggest a new solution for this problem
Can you Help with these Refrigerators problems?
Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Hot point HSS251IFMWW
Freezer will not defrost, tech installed round sensor that...
Answer This...
My refrigerator won't get cold
My freezer is working It's freezing but my refrigerator...
Answer This...
Hotpoint > HSS25IFMCC / HSS25IFMWW Side by Side...
mntech said-to check the defrost coil aa well will that...
Answer This...
warm refrig and freezer
My evaporator fan was running sluggish then it seemed to...
Answer This...
hotpoint will not defrost
I connected line to defrost on the board and the heater...
Answer This...
Let Our Experts
Solve
Your Problems
Ask!
Loading problems.
fairl
Wiz
Let FixYa Experts
Solve Your Problem
Ask!
Repair Service
Find Refrigerator Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
Find Parts
Order Hotpoint Refrigerators Parts Here
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
No
Yes
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
