Question about Cameras
It smells like burnt plastic and it wont turn on
  • 480 Answers
When small ecletric componits burn out they smell burnt chances are your camera is shot try taking it back or see if a warrenty would cover it.
Posted on Oct 07, 2010
I burnet a styfoam, and plastic cover in the microwave. The smell is awful, like melted plastic and burnt wood. My entire house smells horrible. Is there some way to get the smell out.
Try pouring some vinegar in a cup and microwaving until the vinegar steams. This works well when burnt popcorn smells up the microwave.
Apr 21, 2016 | In Microwave Ovens
My mazda mpv wont turn over 1991 V6 and it smells like burnt rubber when trying to start it and it smelled liked that while running for a couple of days before it cut off
Unusual for a rubber smell could it be plastic? I would suggest possible a wiring loom that has either shorted and melted or has touched a hot component and melted. If you can smell burning with the electrics on but the engine off it is probably a shot and you may be able to trace with sight and smell with just the ignition switch in. This can cause issue with starting as it could be a feed to or from the starter, an imobiliser cable or just the ecu seeing an electrical fault and not allowing you to start. An unto electrician should be able to advise if you can't find it. You don't say if it is turning over but not firing or not turning over at all
hope this helps
Jul 05, 2014 | Cars & Trucks
2006 Chevy Equinox Smoke emitting from the steering column with smell of burnt plastic. I have popped off the harness cover but not been able to deduct source of smell or any damaged...
Turn signal switch is common issue, the plactic melts when the contacts overheat. look for discolored or malformed plastic, near wires and contacts.
Sep 21, 2010 | Chevrolet Equinox Cars & Trucks
Microwave not heating and giving burnt plastic smell
STOP USING IT!! UNPLUG IT!! Microwaves are inexpensive now. It will cost you more than a new one costs, to get it fixed.
Apr 02, 2010 | Microwave Ovens
Burnt plastic smell coming from bottom of frig
This is a sign of a short and should be looked at immediately. A smell like that is a sign of something burning. I could be the start relay and start capacitor with overload. But I would not sleep with the possibility of a fire. I will look over your model and see if I can find what this could be, Sea Breeze
Aug 28, 2009 | GE Refrigerators
Burnt plastic smell that burns your nose
sounds like it could be electrical then... have you done any changes to the electrical at all? rewiring, changing headlights, etc? I had a similar smell when I changed my headlights... new headlights were defective and were melting the housing and harness...
Aug 11, 2009 | 1994 Chevrolet Camaro
98 blazer wont start no guages
These vehicles where known for Ignition switches burning up,seperate your column covers and smell around the switch usally smell like burnt plastic
Jul 12, 2009 | 1997 Chevrolet Blazer
Burning plastic smell, big flash & now its dead - Bosch SHU8805UC
remove the water and, the burnt plastic that probanly melted on the dish drying heater coil
close and, lock the door turn the dishwasher back on and, reset the circuit breaker to see if the motor will run or, is damaged
Jul 01, 2009 | Bosch 23 in. SHU 8805 Built-in Dishwasher
Washer stopped filled with water, smells like burnt plastic
REPL/ PUMP BURNT PALSTIC SMELL ,AND RUBBER SMELL, ONCE REPL./ SHOULD FIX
Nov 29, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Dryer smelled of burning plastic, smoked stopped turning on
check the power cord itself, if you see on the back side of the cord a burnt or blackened spot then the cord is the issue
Apr 12, 2008 | Dryers
Cameras Logo
50 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
