Question about Garden
Sprayer will not stop pumping when switched to pump mode after primed it will not shut down it just keeps pumping. .
Paint sprayer.
Flip lever down to prime > paint comes out small plastic hose.
Flip lever up to put pressure on spray line.
Problem: prime keeps running and spray line never gets pressure.
Future solution:
You did not clean sprayer very well last time, or it is rusted. When cleaning, run full 5 gallons of cleaner through machine twice.
You should fill spray line and pump with kerosene if machine sits idle more than few days.
We all forget.
Good news: you have prime. If machine doesn't prime, you probably have to disassemble.
More good news: There are two steel balls inside pump. Tap top one with hammer to loosen. Keep machine running. Keep lever up. Start tapping top one. Tap a little harder... keep tapping ... sometimes it will not free up ... take apart pipe and see if you can nudge ball loose >> be careful not to scratch anything... the sprayer is high pressure and all parts have to fit
sprayer will not stop pumping
Posted on Oct 07, 2010
Why Towing Issues! Overheats and then Limp In Mode. Stop/Shut Down/Prime Fuel System, good for a short while?
Most German cars have a heat sender unit when malfunctions creates engine management problems, fuel pump may be faulty, check fan switch for activating issues.
Dec 17, 2014 | Cars & Trucks
Fuel pump keeps priming. wont shut off
Pump still runs because hasn't started and is in cold start mode. Get power to the coil to get it running first, then see if the pump shuts down when switch is off.
Oct 12, 2014 | 1996 Ford Thunderbird LX
Roundup Sprayer
Hi Robert
Your pump probably needs priming.
Hold the triggger down and squeeze the bottle at the same time to create a pressure inside of the bottle of spray to prime the pump.
Bud
Apr 27, 2013 | Roundup Garden
My titan 330 airless paint spray will not shut off while primming
Airless paint sprayers should not turn off while in prime mode. As long as the prime valve is open the motor can pump paint but the system will not build any pressure. Once the prime valve is closed the pump should pump paint into the hose until it gets to the pressure level required to turn the motor off. If the pump does not turn off with the prime valve closed, it could be that the spring in the valve is weak and won't hold the valve closed under pressure. If the hose is up to pressure and the motor just keeps trying to pump paint, you may have a bad pressure sensor or it is disconnected from the circuit board.
Jul 10, 2012 | Air Tools & Compressors
I have EP2105i and it does not want to spray though motor on and seems to be suction when prime
Hi, W/D here.
Here's a few things to try:
1. Disassemble the gun and check the filter in the handle. Deposits can plug the gun up. Change the filter if necessary, they're cheap.
2. Disassemble the tip and clean. I use a small brush, not unlike a toothbrush, to clean mine. A toothpick or small dental probe works well for removing harder deposits.
3. On the bottom side of the pump is a primer pump. You push the stem several times to make sure that the check ball on the inside is operating freely. You may need to clean it if it's operation is suspect.
4. When initially starting the sprayer up, set the control knob to prime and pump water into a waste bucket. Turn the knob from prime to paint and try to pump water through the tip of the gun. If the pump shuts off on prssure, but nothing comes out of the tip, roll the lever 180 degrees and try it again. Reversing the tip puts in the cleanout mode, and reverses the flow through the tip, backwashing it. Once clear, return the tip to the normal position.
These few items always get me up and running, hopefully they'll serve you well also.
Best regards, --W/D--Please feel free to rate this solution. Thanks.
Feb 19, 2011 | Wagner 1/2HPPaint Pump Sprayer
My flojet pump runs but it pumps no water . It is a 25 gallon sprayer
Sounds to me like it just needs priming (or in other words) the air bled out of it.
Using the force of gravity, force water to run STRAIGHT DOWN from the 25 gal tank, through the gate valve & into the running pump.
While doing this, close the bypass valve slowly until it's about 3/4 of the way shut.
You should begin to hear the sound of the pump begin to deepen as the air escapes.
If you don't, then there may be an air leak somewhere along the hose line, typically at the filter, causing it not to prime.
Correct the air leak, then you'll probably have better luck.
I recommend not running an electric pump like a Flojet for very long when it's not primed. Doing this may overheat it & shorten its lifespan considerably.
May 19, 2010 | Flojet Ag Sprayer Pump 2.1 Gpm 12 Volt...
Airless sprayer will not prime Model AL230502LX
Check for a plunger on the bottom of the machine. Pump it several times and try to prime with water. Also, if there is difficulty priming after trying the plunger, switch on in prime, and cycle to paint, back to prime,paint,prime. After several tries, leave it in prime with the pickup tube in water, and pump the plunger again. If this doesn't help, disconnect the hose fron the pump and try again. If you're getting water now, the issue is down the hose, or at the roller/gun.
Hope this helps! --W/D--
Jul 12, 2009 | Campbell Hausfeld Airless Spray Guns &...
Pump has no pressure
scrub up the check valve within the pump really well, that should help restore the prime! use dish soap and a toothbrush!
Jun 30, 2009 | Fimco Trailer Sprayer, 15 Gallon, 2.1 GPM,...
Garden Logo
184 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
