Question about Epson Stylus Photo 925 InkJet Printer
I have an Epson stylus photo 925 printer. It is only printing out the top half of pages. Any solutions?
  • 286 Answers
This is usually caused by the purge unit or capping assembly. Epsons have a bat habit of the purge tube falling off of the bottom of the capping assembly.
The purge unit is used the **** a little ink out of the printhead. Inkjets do this to keep the nozzles full of fresh ink. Sometimes the hose will come off of the bottom of the head capping assembly on the top of the purge unit preventing the purge pump from having any effect. This assembly should be on the right side inside the printer where the head sits when the machine is off. If you can get the head to move to the center of travel you can unplug the machine, shine a light into the right side and inspect the assembly. Depending on use it could be quite dirty with old ink making it difficult to inspect. If the rubber cap is missing or misaligned, or if there looks like there is too much old ink you should be able to tell with the visual inspection. If the tube has come off the bottom of the assembly you may be able to see that as well. If you just cannot tell, you'll have to decide if you want to try new ink cartridges or not. This can be an expensive test, but often just old cartridges can cause similar problems. If not, the machine would have to be disassembled and have the purge unit removed for a closer inspection and cleaning or repair.
Posted on Oct 07, 2010
I have Epson stylus photo 925 and get horizontal lines on printed page. I have run the Print Head Alignment program but the printout is too light to see. Aolution?
Hi
I suggest you clean it manually by removing the print head and then rub the print head in a plain paper with isopropyl alcohol until ink flows. Return the ink cartridge into the printer and run the print nozzle for 2-3 times.
Please let me know if you need more help.
Mar 05, 2011 | Epson Stylus Photo 925 InkJet Printer
Photo 925 broke print and i need to replace it
It is probably cheaper ,unfortunately,to replace the printer.Heads are roughly $60 US and it takes a tech to install plus new ink required to seal the vacuum.
Jun 20, 2009 | Epson Stylus Photo 925 InkJet Printer
New/refurbished printers from Epson.com are cheaper than a new head.
My epson rx420 only prints the left hand side of any document ??? Can any one help please . many thanks
have you set the page setup in document is same with page setup at print setup. Some new epson printer use paper sensor to measure the paper width. If page setup wider than actually paper inserted, the printer will print only half page. example : Your document 10 cm wide, page setup 20 cm, and you insert 10 cm paper wide. It will print only half of 10 cm, 5 cm.
Jun 09, 2009 | Epson STYLUS R230 InkJet Photo Printer
My printer is only printing half of the page
half page? just half top page (top-bottom), or left and right. If just left half page, set page setup as actually paper wide that inserted. because, if actually paper wide is smaller than page setup, some epson printer jsut print half. before starting printing, the paper sensor measure paper wide first.
Jun 08, 2009 | Epson Stylus Photo 925 InkJet Printer
My Epson 1290 only prints half a page
Hello I am use in 1290 printe in epson problem in hafe page print and red led on and printing in hang pl.. uragent in
Thanxx.
Rawat
Nov 10, 2008 | Epson Stylus Photo 1290 InkJet Printer
Printing problem
Try jiggling the cables and making sure that the USB connection is solid. It worked for me. Good luck.
Sep 03, 2008 | Epson Stylus Photo R200 InkJet Printer
Epson Stylus Photo 925 InkJet Printer Logo
172 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
