Question about Fargo Pro L ID Thermal Printer
Fargo Pro-L error message Mag Jam.
Hey all, it says that I have a Mag Jam, but I have no Mag encoder...what should I do?
  • pau_ngu Aug 15, 2008
    I get the Card Jam: Mag error also and when i try to fix it there is nothing jammed inside to fix.
IT MEANS MAGAZINE JAM AS IN "MAGAZINE FOR CARDS"
Posted on Aug 12, 2008
When I try to print it appears an error: flipper jam
Try to disable double sided printing in the Fargo settings?
That should make the Filpper shut down,
Selvol
Mar 06, 2012 | Fargo Pro L ID Thermal Printer
White card keeping jamming in the middle everythine
Hi gigi_airambu,
The card jam, often caused by cards are jamming on or at the flipper table. Here are additional steps that you can apply to resolve this issue.
1. Verify that the Card Feed Roller on the Flipper table is not running backwards. (Note: Having an Encoder installed in the Printer will determine the direction that the Card Feed Roller on the Flipper Table will rotate.)
2. Open the Top Cover and remove any cards that are jammed inside the Printer.
3. Reset power on the Printer to clear any error messages that are on the LCD.
4. Press the MENU button on the LCD.
5. Press the Down Arrow button and select PRINTER SETUP.
6. Scroll through the menu and select ENCODER SETUP.
7. Ensure that the appropriate Encoders settings are set to Installed or None, based on the options that are installed in the Printer.
8. Press the Save button to save any changes that have been changed.
For additional information about your machine, please visit this link.
Hope it helps.
Thank you for using FixYa.
Apr 13, 2011 | Fargo DTC510 Card Printer
Solving Card Jam problem with FARGO PERSONA C30 ID CARD Printer.
Hey I hope you can help me, My c30 persona printer is task, theres a badge inside and cant get out, what can I do?
Aug 25, 2010 | Fargo Persona C30 Thermal Card Printer
Fargo Persona C-15 error message "Bad Mag Option"
TRY RUNNING THE DIAGNOSTIC UTILITY AND ATTEMPT A MAGNETIC SELF TEST
TRY TO DO THE MECHANICS TO SELF REPAIR THE CLOGS AS INSTRUCTED
sangram.brahma@gmail.com
Dec 11, 2009 | Fargo Persona C15 Thermal Printer
CARD JAM: MAG
SOLUTION = WRONG DRIVER.
I had the Pro-lx drivers installed for a Pro-L and once I found the Pro-L drivers, I deleted the other drivers completely and uninstalled the printer and redid it with the right drivers and it works perfectly.
Aug 12, 2008 | Fargo Pro L ID Thermal Printer
Card Flip Jam Error message
Open the left hand top cover, In between the ribbon rollers you will see a small flipper, ( small piece of metal with a wheel stuck on one end. ) Maually turn this so the grey wheel is on top and white smaller wheel on the bottom.
This ocassional gets jammed and need righting manually.
Aug 04, 2008 | Fargo Pro L ID Thermal Printer
Printing problem
No mag encoder means you're trying to send encoding data to the printer but the printer isn't configured with an encoder. A mag encoder writes data to the magnetic stripe you see on the back of some cards, like credit cards. Most likely, the printer doesn't have an encoder installed, but if it does, it may be turned off in the printer settings.
If you're sure that it does have an encoder, you can check/change the setting by going into the menu on the printer. Go to Menu -> Setup Printer -> Change Parameter -> Encoder Settings -> Mag. It will say none or installed. Note that this can be changed to one or the other whether or not the encoder is physically installed or not. This only turns it on if the encoder is there.
Hope this helps.
Jun 13, 2008 | Fargo DTC510 Card Printer
The card stucks
this is an old post, but are you using ultra card III cards by fargo?
Oct 25, 2006 | Fargo Pro LX ID Thermal Card Printer
Mag Verifying error
Page 46 of the user guide suggests several things to try to resolve the error. http://www.fargo.com/users_guides_pdf/Persona_C16_Full_Document_(Rev.%205.0)1.pdf http://www.fargosupport.com/search_results.asp?printer=35&submit.x=16&submit.y=11
Oct 18, 2006 | Fargo Persona C15 Thermal Printer
Fargo Pro L ID Thermal Printer Logo
300 people viewed this question
Top Fargo Office Equipment & Supplies Experts
Safe-Card ID...
Are you a Fargo Office Equipment and Supply Expert? Answer questions, earn points and help others
