Question about Bissell Healthy Home HEPA Bagless Upright Vacuum - Metallic Blue
I need a manual for this vacuum as well as an answer as to why the belt stops working. how to fix it please and thank you......Trisha
  • 694 Answers
The model number is 5770 and the user's manual can be downloaded at:
http://www.bissell.com/user-guides/?searchtext=5770&searchType=search&mode=228
I'm not sure what you mean by the belt stops working, but it won't turn the roller brush if it's loose, worn, or broken. It's designed to last the "usefult" life of the machine.
Posted on Oct 07, 2010
Automatic height adjuster is not working,it grabs carpet and stops roller
Hi There,
Actually usually when this happens, it's usually the belt that causes the brush to stop and not the height adjustment. What happens is, over time the belt will get hot, which causes the belt to stretch. Once the belt stretches out, it becomes too long, and will stop the brush from spinning when it feels any resistance to the brushes. This is most likely why the brush is stopping when you put it down on the carpet.
I'm pretty confident that if you replace the belt on your vacuum, this should fix the problem of your brush stopping when it hits the carpeting.
Here's a link to the owners manual for your vacuum that will explain step by step how to replace the belt:
http://www.dirtdevil.com/manuals/?id=03c9b130-874d-4601-9e64-2da6376ccfab
I hope this information was helpful to you. If this did help you solve your problem, please be so kind and rate my repair, or leave feedback for me. Thanks so much,
Chris Jones
GoVacuum.com
May 17, 2010 | Dirt Devil Featherlite Bagless Vacuum...
Does not pick up
Hi There,
It may be that your belt is broken, or stretched out. This will cause the brushes to slow down dramatically when vacuuming the carpets. When the belt stretches, this causes the machine not to pick up on the carpets, and makes it seem that the vacuum is loosing suction.
In order to test this, turn the vacuum on it's side while it's on. Are the brushes spinning? If they aren't, this is because your belt is broken. If the brushes are spinning, the belt still may be stretched. Listen to the brushes as you put them onto the carpet. Can you hear a change in the sound like the brushes are slowing down? If you put just a little pressure on the top of the vacuum by stepping on it, do the brushes stop then?
It may also be the filter is clogged in the machine and needs to be replaced. Bagless vacuums use a HEPA filter in the dirt cup instead of a bag. With a bagged vacuum you just replace the bag when it gets full, but on a bagless vacuum the HEPA filter continually gets debris and fine dust accumulating on it, and needs to be cleaned, and replaced occasionally.
Here's a link to the owners manual for your vacuum. This will explain step by step on how to replace the belt, as well as servicing the filter.
http://www.dirtdevil.com/manuals/?id=83831cab-2807-439b-811d-52aab2fd84ee
If you still need some help, please just use the comment field here on Fixya to ask your question. I'm always more then happy to answer all follow up questions, and I really am not completely satisfied until you are able to fix your vacuum.
If you found this repair helpful, please be so kind and rate the repair, or leave feedback. This is greatly appreciated.
Thanks,
Chris Jones
GoVacuum.com
Apr 23, 2010 | Dirt Devil Featherlite Bagless Vacuum...
NEED ASSISTANCE ON INSTALLING BELT FOR MODEL 8625
HI There,
Here's a link that will walk you through step by step on how to replace the belt on your Riccar 8625 upright. This is an almost identical model, and the belt change is identical to yours.
If you have any questions please feel free to add a comment on the repair, and I"ll be happy to follow up and answer any of your questions.
Please rate my repair or send me feedback if this helped you,
http://www.fixya.com/support/t4184186-replace_belt_riccar
Thanks,
Apr 20, 2010 | Riccar 8650/8625 s Vacuum
Dear Expert, the vacuum is not working in normal mode but if i use pipe then it works. Any suggestions? thanks khangee
So usually when an upright vacuum works well when using the attachment hose, but doesn't work well when vacuuming on the floor mode, this typically means that you have a belt problem. This is very easy to diagnosis. Turn the machine sideways so the brushes are facing you while the machine is plugged in. Be careful and make sure there's no hair, or clothing near the brushes, and turn the vacuum on. When you do this, are the bottom brushes spinning? If the brushes are spinning, with the vacuum running, put the vacuum brushes down on the carpet as if you were vacuuming, and listen to the brushes. Can you hear the brushes stop when you put the vacuum brushes on carpeting?
If your brushes are not spinning, or if you the brushes stop when you put the vacuum down on carpeting, this is a clear sign that you have either a stretched, or broken belt. Many people equate a broken or stretched belt to loss of suction because without the belt, the vacuum really can not pick up much at all off of the floor. When the vacuum doesn't pick up, many people assume the vacuum has lost suction.
Your roller brush may or may not also be bad. Installing a new belt properly will help you answer this question.
Please see the link below for the owners manual to a model that's similar to the model you posted this repair question under. The belt change will be identical. The belt change instructions starts on page 13 of the .pdf
http://www.hoover.com/pdfs/manuals/C1414900.pdf
I hope that this information was helpful to you, if so please be sure to rate my repair as helpful by clicking the thumbs up icon in the top of the repair.
If the belt is fine on your vacuum, please also let me know by leaving a comment here on the repair page, I can then go through some more advanced troubleshooting with you.
Thank you,
Chris J.
GoVacuum
Apr 06, 2010 | Hoover Elite U5061-900 Bagged Upright...
Brush roll belt stops turning when in position to vacuum. Does turn when vacuum is turned onto side. Belt is in tact, brush roll is fine. What's going on?
I think I know what the problem is with your machine. It's a rather lengthy repair, and I'll be happy to photograph it for you (like I do on most of my Fixya answers), but I'd like to know before doing all of that if you still need help, or if you've already fixed it.
Thanks,
CJ
Apr 06, 2010 | Eureka Smartvac 4870 Bagged Upright Vacuum
How do you change the belt on a kirby g4 vacum
Greetings,
I have shot an excellent video repair on how to replace the belt on Kirby Generation Vacuum Cleaners, including your Generation 4, G4. The video is below in an easy to follow, and understand video. Feel free to use the pause controls to pause the movie as you're fixing the belt on your Kirby.
I hope this video was able to teach you the exact process of how the Kirby belt has to be installed in order for it to work properly. Please, if you have any questions just request a clarification of the repair and I'll be more then happy to help you further, I'm always happy to answer any questions. If you found this video helpful, please kindly rate this repair solution as helpful also. I really do appreciate it, thank you.
Thanks for watching!
Chris J.
Feb 20, 2010 | Kirby G4 Bagged Upright Vacuum
How do I replace the drive belt on a Kirby G5 vacuum cleaner?
Greetings,
I have shot an excellent video repair on how to replace the belt on Kirby Generation Vacuum Cleaners including your Generation 5 (G5). The belt change procedure is the same for Kirby Models G3-G10 Sentria. The video is below in an easy to follow, and understand video. Feel free to use the pause controls to pause the movie as you're fixing the belt on your Kirby.
Chris J
Jan 20, 2010 | Kirby G5 Bagged Upright Vacuum
Beater bar stopped working
hi welcome to fixya you need to replace belt if belt is ok than you burnt out the motor please check belt first as it is cheaper thank you for useing fixya please rate
Mar 02, 2009 | Kenmore 23313 Whispertone Bagged Canister...
Brushes stopped working and started making real sound sound
http://geeksquad.fixya.com/ThreadView.aspx?prdid=40488&thid=754331
Brushes stopped working and started making real...
Posted by charlenemo on Jul 07, 2008
I was on my 2nd room and the brushes stopped working and it spells like a belt broke but there are no belts on the machine. Also making a louder sound.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover SteamVac F5914-900 Spin Scrub Upright --- If the vacuum does not have a belt there has to be something driving the brushes of which a part is broken and is in need of replacement. Please check your owner’s manual under the trouble shooting guide to see what is wrong, or feel free to call the Hoover factory website or phone 3 to cust serv @ Hoover to see what is wrong or to have them send out an owner’s manual to you for future use. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 07, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Bissell 37602 roller stopped spinning
If the roller brush as stopped spinneng .and the brush motor still works the brush belt as broken,
you must replace the brush belt, t
Sep 05, 2007 | Bissell 37603 Upright Vacuum
Bissell Healthy Home HEPA Bagless Upright Vacuum - Metallic Blue Logo
136 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
