Samsung 40" LCD TV LNT4042HX
My TV displays the info message box at all times. The message reads:"Not available."
When trying to use info function, info box flickers on and then reverts to the "not available" message.
When trying to access display and audio controls the display continuously scans through the menu. It does not respond to inputs or allow access to any controls.
Thank you.
  • 3 more comments
  • Anonymous Mar 26, 2009
    I have the same problem LNT4061F. Message pops up Not Available. If goes off after about 5 - 10 minutes and then itt is OK for the rest of the time the TV is on. Changed 4 boards and still have the problem. Good thing I have a 5 year warranty on this TV. I'll let you know if they ever fix it or replace the TV.
  • Anonymous Apr 23, 2009
    My Samsung LCD TV is a 40" LN-T4042H. The "Not Available" message came up 24 hours ago and is still there. I have unplugged the power, the HDMI, the remote, but it reamins on the screen.
  • Anonymous May 01, 2009
    Same problem just started happening on my tv (different model) that is 1.5 years old. The box comes and goes with no apparent reason. Same with the scrolling menu issue. Has anyone figured out what the issue is and how to fix it?
  • jimyou May 17, 2009
    I have the same problem with a Samsung 40" LCD TV LN-T4061F. The "Not Available" message comes on when the TV is initially turned on and it stays on for anywhere from 30 min to 1.5 hours before finally disappearing. While the message is on the screen, attempts to use the "Menu" button are unsuccessful because the menu scrolls constantly. Also, the volume sometimes changes settings on its own.
    f
  • pdfiore May 18, 2009
    lns4696dx Not available message starting coming up yesterday - unplugged power cord over night, tv worked fine for 1 hour, now message is on screen again. No buttons on remote work, also power on/off button doesn't work - only unplugging cord works - I have two of these Samsung tvs next to each other (purchased the same day about a year ago) and only this one has a problem.
  • 53 Answers
SOURCE: My Sharp Aquos 46" LCD
Digital inputs on Aquos TV's are "always on," usually the HDMI inputs and DVI inputs. As opposed to analog inputs 1, 2, or 3, are only activated once something is plugged in.
Try plugging in another HDMI sources into input4 or 5, if its still not working, the TV needs a new Main Board. Try calling Sharp 1-800-237-4277 and locating a local service center in your area.
Posted on Mar 14, 2008
SOURCE: samsung 40 inch lcd mode not supported
My 360 and samsung hdtv worked fine for about a year and now im getting the problems mentioned above, not sure if its a console/cable/telly problem but i did the following (temporary?) fix
Unplug your 360 and plug it into another television set, it seems to reset/calibrate itself somehow and then when you plug it back into your samsung tv it will work - mine did but for how long i dont know.
J Bizzle
Posted on Sep 22, 2008
JollyRoger00
  • 59 Answers
SOURCE: Digital Audio Output Problem
connect the optical line from the DTV box to the audio system directly.
Posted on Sep 24, 2009
57 varieties
  • 1653 Answers
SOURCE: 'satellite' icon not available to retune digital channels
Updating the Channel List Automatically You can update the channel list when the broadcaster adds new Services or if you move the TV to a new location.
1. Press the MENU button to display the menu. Press the ▲ or ▼ button to select "Digital Menu", then press the ENTER button.
2. Press the ▲ or ▼ button to select "Channel", then press the ENTER button.
3. Press the ENTER button again, to select "Country".
4. Select the appropriate country by pressing the ▲ or ▼ button. Press the ENTER button to confirm your choice. Even though you have changed the country setting in this menu, the country setting for Analogue TV is not changed. (Refer to page 11 of the user guide)
5. Press the ▲ or ▼ button again, to select "Auto Store". Press the ENTER button. When it has finished, the number of scanned services will be displayed. The existing favourite channel list will not be deleted when the channel list is updated. To stop the scan before it has finished, press the ENTER button with "STOP" selected.
6. Press the EXIT button to exit. If the signal status is poor, the "No Service found! Check the aerial connection" message is displayed. Check the aerial connection and the try the procedure again
Posted on Oct 02, 2009
lukster
  • 217 Answers
SOURCE: our flat samsung 40 inch just clinks won;t come on
REPLACE 3 -4 CAPACITORS IN THE POWER SUPPLY, THEY ARE SWOLLEN UP OR LEAKY
Posted on Dec 30, 2009
My samsung led tv i think the problem is lcd
Visit the site named 'Electro-help' for more details. Click this link.
View it in 'Flip card' option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. Some times, the ads attached with each posts, both at the right and bottom, might help you to find the availability of spare parts. There are more than 850 posts to different brand TVs now.
Sep 27, 2012 | Samsung UE40B7020 40 in. LED TV
HDMI input says "mode not compatible"
If your Playstation is putting out the signal in 1080p then try changing it to 1080i and see if that works. Not all TVs are compatible with 1080p.
Aug 02, 2012 | Samsung Lnt4042hx/xaa
Are have thish TV 3D function???
if you meant to ask, "Does the Samsung LA40A550 LCD TV have 3-D capability?" then the answer is no.
It pre-dates 3-D and is completely incapable of displaying those image.
Jun 30, 2011 | Samsung LA40A550 40 in. HD-Ready LCD TV
Want to use samsung 2233SW LCD monitor as TV
Yes you can, if you has PC desktop, plug your lcd to it. change LCD resolution from your PC.
-- Right Click on desktop
-- Click properties >> click settings tab
-- You will see Screen Resolution, change to the lowest (800x600)
-- Nnplug VGA cable from PC
-- Now plug the cable tou your TV Tuner.
Feb 08, 2010 | Samsung SyncMaster 2233SW Monitor
Our flat samsung 40 inch just clinks won;t come on
Dec 30, 2009 | Samsung LN-S4041D 40 in. LCD HDTV
3 year old Samsung 40 inch LCD TV will not turn on
The problem is 4 capacitors on the power supply board. Just had mine done under warranty. They (Sears) replaced the whole power board but you can get larger capacitors and just replace those for alot cheaper if not under warranty.
Dec 10, 2009 | Samsung LN-S4041D 40 in. LCD HDTV
Samsung lnt4042hx/xaa 40in lcd tv wont turn on
I concur with Lightnbaby.... had same problem... my TV LNT4042HX/XAA took 10 min to start sometimes... the capacitors on the power supply board had bubbles on top 4 of them all 10/1000Uf. Samsung wanted to charge $220+ to have a guy come out and fix. J&J parts (samsung vendor) wanted $108 for a new board. I replaced the 4 capacitors for $4.68 and the TV works fine now!!!!!
Apr 14, 2009 | Samsung LN-T4042H 40 in. LCD HDTV
Samsung 40" Full HD LCD
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
Aug 22, 2008 | Samsung LN-S2651D 26 in. LCD Television
Sony Bravia - picture don't fit the screen
I have a Scientific Atlanta cable box w/ Time Warner. I followed the instructions below for the cable box. Somehow it reset my picture and I can now read the ticker at the bottom of the screen and the different picture sizes seem to work properly. Good Luck.
http://newteevee.com/2007/12/15/six-steps-to-get-more-hd-from-your-scientific-atlanta-set-top-box/
Aug 03, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Televison & Video Logo
888 people viewed this question
Top Televison & Video Experts
