Repairing fan balancer
There is a very loud noise like a belt is partly broken and hitting a part in the AC.What I could see  is that the metal balancer on the fan is loose on one blade. I need to know how do I fix it??? What screw, Bolt or clip do I need. What can I do to make it easier to work on.
  • hensleyjt Jun 07, 2008
    One blade had come off. Can see part in bottom of unit. Need steps in taking off cover. Re-attaching blade and checking for proper blade angle.
    Problem Solver:
  • 14 Answers
Gorilla glue. Seriously.
Posted on May 29, 2008
It made a loud noise during spin cycle and started smoking
Doesn't sound good does it?
Smoke could be a burned and shredded belt. Worse, the motor is burned out.
Loud noise? Depends on what it sounded like. Could be the concrete balance weight hitting the cabinet. Could be the belt hitting the cabinet when it snapped.
You need a repair man to diagnose.
Aug 24, 2015 | Washing Machines
What could cause my ford taurus 03 to cause such a loud squeeling noise?
it maybe the synchroniser which is under the throttle body (and houses the cam sensor)and makes the same noise. use a rubber hose to pimpoint the location of the noise
Sep 17, 2014 | 2003 Ford Taurus
2002 dodge stratus making very loud noise sounding like metal to metal seeing metal shavings on underpin near ac unit. i can visually see the ac pulley wiggling very hard and that is where the noise is...
There are two companies that I've heard of that make a bypass pulley. One is Dorman the other I can';t remember. Both require that the compressor be removed and the pulley replaces it so you can run the same belt and configuration. You'd need to check with your local parts house to see if they make one for your engine. Most factory systems don't allow for a bypass... the belt usually ends up hitting something and not working.
Jun 27, 2011 | 2004 Dodge Stratus
Washer is out of balance. it just leans to the left side and makes loud noise like metal on metal.
It sounds like your drum support, and/or balance mechanism inside the washing machine has broken. You will need to open your Washing machine and inspect the Drum Support, and the balance mechanism. Hook it back up or replace it if it is broken.
Feb 27, 2011 | Washing Machines
Battery light turned on. Lost power steering and AC.
You broke your serpatine belt. Needs replacing. It's a $50ish part and easy to do if you have a diagram under the hood of how the belt fits. But if it was "rattling" for a couple of weeks take it in for crying out loud. Let the mechanic look it over to make sure your lack of vechile care didn't destroy anything under the hood.....
Jun 12, 2010 | 1998 Saturn SC
A very loud noise commining from the compresser clutch fan?
a/c clutch bearing or idler breainr may be faulty
Oct 08, 2009 | 2000 Oldsmobile Intrigue
1995 galant broken balance shaft belt
You sould replace the belt along with the timing belt. If it gets caught in the timing belt you will have MAJOR EGINE DAMAGE!
Jul 21, 2009 | 2005 Mitsubishi Galant
Squealing NOISE possibly from fan belt
If the noise going away every time u turning off the ac it's probably your ac compressor belt.however i will suggest to take some vaseline and rub it all over the exposed parts of your drive belt.
Jun 22, 2008 | 1998 Dodge Caravan
Heating & Cooling Logo
106 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
