Question about Bosch Nexxt 500 WFMC3301 Front Load Washer
My dryer does not heat up I pushed both reset buttons...
  • Bosch Master
  • 2,605 Answers
Welcome to FixYa.
Just to clarify your statement "dryer does not heat up I pushed both reset buttons..." are you referring to the hi limit cut out ( on the heater box ) and the emergency shut off switches ( next to the belt pulley ) you've reset already ?
examples
I'll assume you are unless you say otherwise since you've also stated the dryer will indeed tumble just not heat, correct ?
Have you checked the heating element for continuity following the reset attempts ?
If not, that is where I'd direct your attention going forward. With the aid of an ohm meter or a multi-meter, place a lead on each element terminal and you should have continuity.
If you're uncertain about how to go about this, send me an email at macmarkus@live.ca and I can attach a short .wmv file approximately 3.5MB ( there is no audio and it is directly from Bosch ) on "how to".
I'll watch for your reply. Good luck.
Regards,
Macmarkus :)
Posted on Oct 07, 2010
  • Bosch Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Do a tumble dryer have a reset button once you have changed the thermostats?
check the heating element they might be the problem if they are not getting any power or are open.
Aug 27, 2014 | Hotpoint Dryers
Bosh 500 series dryer wont heat and rest button wont push in.
then u definately have a problem,and would be better getting a tech to look at it for u
Jan 19, 2014 | Bosch Nexxt 500 Dryer
Where is the reset button on a fisher & paykel dryer model DEGX1, also where is the heating element located?
Always disconnect power first and take the front off of the dryer and locate the heating element. On the front of the heating element, in between two wires, there is a red button. Push the button and you might hear a click that sounds similar to a circuit breaker. It is a reset button for the heating element. This should fix your problem, here is a website if you need further assistance, Good Luck Tim:
http://www.appliancerepairlesson.com/
Mar 13, 2011 | Dryers
Do I replace the heating element on my DEGX1 smartload dryer. Dryer is not heating. I have replace all of the venting inside and out. and cleaned all of the lint from the inside of dryer. Sometimes when...
I would guess thermal fuse:
http://www.davesrepair.com/DIYhelp/DIYthermalfuses.htm
here is another good website:
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Good Luck Tim
Mar 11, 2011 | Fisher and Paykel SMARTLOAD DE62TG1...
Dryer run but no heat
Try pushing the reset button located inside the dryer housing. (Remove top, then outer housing 'wrap around', reset button is behind the outer 'wrap around' metal in the front of the dryer.)
Jan 06, 2010 | Fisher and Paykel DEGX1 Electric Dryer
No heat
You may need a new heating unit for your dryer, but usually and most always it's the temperature sensor that needs reset, most of them have a push button built into the sensor that you can push to reset it.
This most always works, failing that you need a new element to heat. though sometimes wires rattle loose and simply need plugged back into socket.
In all examples you need to take the panels off your unit to get the parts in question.
Hope this helps.
Jan 01, 2010 | Dryers
Fisher & Paykel DEGX2 Dryer. Need heating element changed?
I had the same problem. Everyone continued to tell me that I needed a new heating element, clean lint trap, etc. However, I took the front off of the dryer and located the heating element. On the front of the heating element, in between two wires, there is a red button. Push the button and you might hear a click that sounds similar to a circuit breaker. It is a reset button for the heating element. Try that and it might help.
Jul 08, 2009 | Fisher and Paykel DEGX2 Dryer
Asko Dryer stops running when you release the start button.
Hi, this is a simple issue here. these switches will fail from time to time. the start switch is unable to hold the circuit, in return, opening it upon release of the button.
Simply replacing the switch will fix this issue. switch is 20 dollars tops.
May 28, 2009 | Asko T701 Electric Dryer
White Knight tumble dryer making a clicking noise when on & has no heat
How to Replace A White Knight Tumble Dryer Heating Element Heater and Thermostat
utube.png You-Tube video "XNxE9eXx2Rk" placeholder (do not delete) utube.png
For a full list of appliance Video Repair help see our video section
White knight tumble dryer not heating this video show you how to change and fit a new heating element and thermostats can be used on Ariston, Electrolux, Ignis, Neutral, Tricity Bendix, Whirlpool,
Here is the element in this video
For all you tumble dryer spare parts click here
The easiest way to find you part is put your model number into our search bar at http://www.apart4u.co.uk/ TEL 08455218000
http://www.apart4u.co.uk/news/category/questions-and-answers/diagrams/
May 02, 2009 | Dryers
ASKO T700
I had the same problem. Turns out the reset button on the back of the dryer needs to be pushed; when you push the reset button you should hear a click. If you do not hear a click the problem was probably not the reset button. The button shuts down the dryer heating elements if they are getting too hot and also keeps the drum from turning unless the start button is held down.
If you push the reset button and the dryer starts to work again, I strongly recommend that you stop the dryer and investigate why the heater elements overheated. In my case there was lint/hair build up on the heater elements themselves. Extensive dryer disassembly is required to properly clean the heating elements but it is worth the prevention of a house fire. While you're at it, clean the rest of the machine and the duct work.
Hope this helps
Jun 20, 2008 | Asko T700 Electric Commercial Dryer
Bosch Nexxt 500 WFMC3301 Front Load Washer Logo
255 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
