Question about Samsung Televison & Video
Hln43w. Screen went dark. 3 lights on front flashed, and TC emitted a high pitch whine. Replaced lamp. 3 lights no longer flash, but whine is still present and screen is still dark.
    Genius:
  • 1,066 Answers
If there anything like commercial flourescent cieling lights, there is a unit called a ballast which may be responsible for the symptoms you are observing.
Posted on May 29, 2008
My tv powers on displays the LG logo then makes a high pitched squeal sound from speakers and then flashes on screen (strobe light effect) does not display picture or sound.
LCD TV Repair Tutorial - LCD TV Parts Overview, Common ...
? 11:05
https://www.youtube.com/watch?v=tS4sIpdajVw
Aug 23, 2013 - Uploaded by ShopJimmy.com
Repair review of common LCD TV Problems and Repair Solutions ... input the tv is set to it begins making a high pitched whiningsound. .... I have a LG 47LN5750 that powers on, flashes a good picture for about 1/2 second, then goes dark. ... hi my samsung tvis not turning on is black. and I just replace the ...
#Treat At Home high pitched whine from plasma tv Tinnitus ...
www.aspenridgerentals.com/tinnituscure/?...high%20pitched%20whine%...
LG 50PK540 plasma TV Repair power supply EAY60968801 Part 1-2 ... Sanyo DP42849 with high pitched squeal after replacing power supply. ... In my second daily fix video, I solve a mystery that was making me having to turn off my speakers before I went to be ... The flash is accompanied by an high pitched sound.
TV not turning on; making high-pitched sounds - Tom's ...
Dec 16, 2015 | LG 55LE5400 TV
I have a Samsung HL-R5677W TV set and now there is no picture at all. Every time you power on the TV the green light flashes and you hear this sound that repeats itself. It sounds like a camera flash, low...
I have a few questions which will determine what your problem may be.
Did or does the set make a high pitched fan like sound or a high pitched whine?
What have you examined so far?
As far as a lamp it is unlikely it will cause such a sound but if you remove it look to see it is intact and not shattered.
Let me know
SD TECH
Sep 23, 2011 | Samsung HL-R5677W 56" HDTV
When i turned it on screen went black...3 lights started to blink on front of screen
The "LAMP"LED light indication flashes or stay lite?The projection lamp life is over.Replaced the projection lamp.Tv require a new projection lamp.
Oct 19, 2010 | Samsung HLN5065W 50" Rear Projection...
My hlt4675sx/xaa won't power up. The Stand by/ temp light and the lamp light flash. The bulb id brand new.
First thing to do is look from back of set or area when lamp is: do you see the lamp come on for even a few seconds?
Also is the problem the exact same as before lamp Replaced?
Before set failed did you hear unusual fan like, high pitched whine or even grinding sound?
Depending on how you answer I will assist you.
SD TECH
Aug 22, 2010 | Samsung DLP HL-P5663W 56" TV
When turning on samsung hln467w, lamp light blinks, screen stays dark, can hear audio from tv show, but then a high pitched sound begins for a few seconds. The tv turns on and off for a few cycles with the...
The tv have a colors wheel,have a whinning high pitch sound,mean colors wheel is warping not spinning right any more.The colors wheel is dead,must be replaced.The tv have high pitch sound,shutdown the projection lamp.The projection lamp might be dead or not?Not yet determine dead or just shutdown by the nonfunction of the colors wheel.
Aug 05, 2010 | Samsung HLN467W 46" Rear Projection HDTV
My screen went blank and the 3 lights on the front of the tv were flashing (lamp/temp). I ordered, received, and replaced lamp as I had done previously with this problem. The tv worked beautifully for...
Hi,do you hear any strange noises? if you heart clicking or like wanting to turn on it could be the ballast that's the board that powers the lamp.Do you hear buzzing,whirling,or high pitch sounds?If you do it could be the color wheel which is a little disc looking that when the light of the lamp goes through it creates the colors on the tv.This are the most common failures on samsungs.
Sep 30, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Monitor Goes black, or flickers on and off
The high pitch sound is coming from the inverter. It is faulty and needs to be repaired or replaced. The inverter supplies high voltage to the CCFL lamp, this lamp gives the backlight to the LCD so you can see the LCD images.
Check out LCD parts for parts, service and DIY info. use this link :-
www.lcdparts.net
Aug 29, 2009 | ViewSonic OptiQuest Monitor
Exact problem, lamp comes on, no picture, lamp light flashes.
remove the lamp and with a light and or mirror look where the front of the lamp faces--there is a color wheel there--if it is shattered or damaged the set will not come on--most of these sets have a high pitched whine or grinding noise if this happens---the wheel is available on the internet and a moderate job to replace--I have seen lots of them bad---if you want an idea of what it looks like--etower.766@netzero.net Steve
Aug 10, 2009 | Samsung HL-P4667W 46" Rear Projection HDTV
RCA HD61LPW42 - no picture
I haven't worked on an RCA DLP but have on Samsung DLP, based on your description it sounds like the color wheel is bad. Take the back off and turn on TV make sure its not a fan making the noise ,but most likely its the "wheel" it is inside the light engine probably right next to where the lamp is plugged in. If the whine comes from this area definitely the wheel.
Apr 26, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
Cassette Deck emits high-pitched whine
I like Silcone grease for this kind of thing. It's sold at electric shops such as Maplin (UK).
Jan 07, 2009 | Audio Players & Recorders
Televison & Video Logo
66 people viewed this question
Jerry Greenberg
Jerry Greenberg
