Question about M&S Systems Bagless Central Vacuum
I just inherited an AirVac AV400. It won't turn on. What do I try? GrampaBigJohn
  • 171 Answers
There is a reset button on it some where near the power switch so I would look for it as it most likely is that simple. good luck!
Posted on Oct 07, 2010
My airvac av2500 powerhead does not work. I bought a replacement and the replacement doesn't work either.
Test the wiring in your hose to insure the power head is getting the proper voltage.
Jan 09, 2017 | Airvac Vacuums
I have an airvac 525 that came with my new home. Need to know how to take care of it
Change the bag when it is full.
After a couple months, use a cleaning cloth and run it through each vacuum point.
Not much else to do.
Dec 14, 2014 | Airvac Vacuums
Airvac wont turn off
the on and off switch is bad
Jul 15, 2012 | Vacuums
Vacuum has good suction but will not turn off at the handle or when disconnected from the fitting on the wall
Disconnect the low voltage wires going to the vacuum. If the vacuum stays on you have a bad relay. If the vacuum turns off you have a short in the wire somewhere. The bad news is the relays are not available, however there are some companies that sell external relay control boxes that will bypass your units bad relay.
Jul 20, 2011 | Airvac AVP3000 Bagged Central System...
Hi! My central vacuum has worked perfectly until just a couple months ago. I went to plug the vacuum in and it didn't automatically start the suction. When I clicked the switch to the right on the...
It sounds like you may have a bad hose. Plug the hose into the wall but rotate it 90 degrees from the normal position. This will bypass the switch on the hose. If you look at the wall end of your hose, you will see a metal band around it. That metal band is split into two sections. You are trying to plug in the hose so that the separation of the two pieces of metal is not lining up at the top of your inlet. If your vacuum turns on then you have a bad hose. It is possible that you have a bad switch in the hose, but it is more likely that you have a bad hose.
If your vacuum does not turn on, then you may have a break in your low voltage wire somewhere. You can check to make sure it didn't get disconnected at the unit. If the wire is connected then try to cross the low voltage wire from the relay at the unit with a small screw driver. If the unit does not turn on you have a bad relay.
If it is the relay, AirVac does not provide them. You would need to consider buying a new unit.
Jul 17, 2011 | M&S Systems AirVac AVP1200 Platinum Series...
No suction from wall outlet. Power to powerhead. Breaker has not been tripped. Manual mode works on cannister in garage. AirVac VM458.
I had the same exact problem and it took about 4 months to find out the problem. I had a paper clip stuck to one of the orifice in the hall way of my house and that is what I had experienced. The other thing is to check the entire tube system because maybe a mouse or rat has chewed into it. It has all to do with the electrical wire throughout the system. Good Luck
Jan 06, 2011 | M&S Systems AirVac AVP1200 Platinum Series...
AirVac ZX6000 won't turn off!
There is a relay board inside your unit which is most likely bad. If you have the make and model, you can contact me and I can order the board for you(pending your mechanical abilities). If not, contact your local central vacuum installation company. www.thevacdudes.com
Apr 21, 2009 | M&S Systems AirVac AVP1200 Platinum Series...
I have a 10 year old AirVac central vacuum system that has worked until this morning. As I was using it this morning, and turned it off for about five minutes it would not start again. The tank in the...
Sounds like the motor finally siezed on you. Motor is trying to turn but won't thus the hum. Do not allow the vacuum to stay on like this as it may cause a fire. Requires a motor replacement.
Nov 23, 2008 | M&S Systems ZX7000 Bagged Central System...
De clogging pipes
You can try these as long as you have some airflow. http://builtinvacuum.com/tornado-power/ If you have no suction or airflow from one particular inlet, you can reverse the main unit by hooking the inlet piping to the exhaust of the unit. Tape all other inlets closed, and turn the unit on. This should blow the clog out through the inlet door. (be prepared for a some mess with newspaper or something else to protect your floor in front of the inlet) If you still can't unclog it, borrow a portable canister vacuum or a shop vac and try to **** the clog from the inlet while you blow from the other end with your central unit. Good Luck!!
Sep 08, 2008 | M&S Systems AirVac AVP1200 Platinum Series...
M&S Systems Bagless Central Vacuum Logo
Top M&S Systems Vacuums Experts
JoeVacs
Are you a M&S Systems Vacuum Expert? Answer questions, earn points and help others
