Question about Texas Instruments TI-83 Plus Calculator
I'm trying to make a list & when i hit STAT and then 1. Edit it goes to the list but instead of me being able to enter numbers it says Name=
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
Give the list a name then press ENTER. You have to tell the calculator which list you want to edit.
Posted on Oct 07, 2010
When I push stat abd then edit, all that comes up is a list with "name" at the bottom of the screen. How do I get off that ?
Each "list" has to have a name. Usually, the lists are named L1, L2, L3, L4, L5, L6 ect. but you can give them text names as well.
To name the list, go to Stat--> Edit --> Input a name--> Enter To input a name, either do 2nd --> L1,L2,L3 ect.. or use Alpha --> Name
Mar 01, 2011 | Texas Instruments TI-83 Plus Calculator
How do you get the table ([2ND GRAPH]) from the [STAT] [EDIT] [L1] [L2] list to appear with [Y1] in the second the column? The information appears in the scatter plot, but the information in the table does...
Instead of hitting the [table] button. You should hit the [stat] or [stats] button as I forget which it is. Then hit [enter] which will bring you to a stats list editor of some kind. You will want to enter the data for your x-axis in L1 and the data for your y-axis in L2. Once you have completed your lists, hit the [stat] button again and then click [right] or the right arrow in order to move to the section of calc. from number 4 down it will help create a graph of that type of function. lets say you think it is linear, so you hit [enter] on number 4 and then you will be at the home screen with LinReg already written. You just have to complete the statement and it will do it for you. hit the [2nd] [1] and then the comma button, then [2nd] [2] and [enter]. that will do it for you.
Feb 14, 2011 | Texas Instruments TI-84 Plus Silver...
When I type a list of numbers into L1 and then hit Stat, calc, 1-var stats L1. i get invalid dim
  1. Press [STAT][5:SetUpEditor][ENTER].
  2. Press [STAT][1:Edit..]
  3. Enter your data in L1.
  4. Press [STAT][CALC][1:1-Var Stats].
  5. Command echoes on main screen.
  6. If ONLY one list contains data, it must be L1.
  7. When you do not specify the list in the command line it will take L1 by default.
  8. If L1 is empty and the data is in L2, or another but L1, the name of list must be specified.
Feb 19, 2010 | Texas Instruments TI-84 Plus Calculator
Invalid dimension
Most of the time when you get the "invalid dimenstion" error, either list 1 or list 2 is longer than the other. Check your data and make sure you there are not more numbers in one list than in the other.
Another posssibility is that when you tried to clear list one, you may have deleted list one. If this is the case, you can get the column labeled list one back by pressing stat, then select set up editor form that menu which will take you back to the home screen. Press enter and the word done will appear. Now when you go back to stat edit, list one will be there.
Aug 29, 2009 | Texas Instruments TI-84 Plus Calculator
Under Stat, Edit, only L5 and L6 appears. When I
You've accidentally deleted your lists instead of clearing your lists. Press the stat key and then select #5 (set up editor). You will now be back at the home screen. Now press enter and done will appear on the home screen. All of your lists should now be available.
Jun 26, 2009 | Texas Instruments TI-84 Plus Calculator
List disapearance and graph problems
You have accidentally deleted lis 1 and list 2 instead of clearing them. Press the stat key. Select #5 (set up editor). You are now back at the home screen. Press enter. Screen will show "done". Your list one and list two will now be there when you press stat and select edit.
Jun 09, 2009 | Texas Instruments TI-84 Plus Calculator
Invalid dimension error on my TI-83 plus?
This is a pretty vague problem but not much of a problem. Your actualy plotting device of your stat plot is under your "y=". But before you do that you need to hit the stat button right next to the blue apps button. Then hit edit. These are your stat data. If you are trying to add data in you should notice what list they are under. (top of the screen L1, L2, ect.) You should also make sure that the number of data adds up for your two list. Now that you have done that you can go to "2nd" then hit "y=". If you don't want to graph your stat plots just make sure they all sat plot... off by hitting enter on the one that says that it is on. Now if you want one on hit enter and make sure your lists from your data match up with your stat plot. You can hit enter and see what one you need. they are above the 1, 2, 3, etc key. Hope this works. If all else fails you can clear your calculator by pressing "2nd", "+", "7", "1", "2". This will turn off all your stat plots if you have trouble understandsing this. b
Jan 08, 2008 | Texas Instruments TI-83 Plus Calculator
List dimensions
This is a pretty vague problem but not much of a problem. Your actualy plotting device of your stat plot is under your "y=". But before you do that you need to hit the stat button right next to the blue apps button. Then hit edit. These are your stat data1.gif. If you are trying to add data in you should notice what list they are under. (top of the screen L1, L2, ect.) You should also make sure that the number of data adds up for your two list. Now that you have done that you can go to "2nd" then hit "y=". If you don't want to graph your stat plots just make sure they all sat plot... off by hitting enter on the one that says that it is on. Now if you want one on hit enter and make sure your lists from your data match up with your stat plot. You can hit enter and see what one you need. they are above the 1, 2, 3, etc key. Hope this works. If all else fails you can clear your calculator by pressing "2nd", "+", "7", "1", "2". This will turn off all your stat plots if you have trouble understandsing this. But most importnat make sure your L1 and L2 match up on your stat plot with your list under your stat edit. If you don't understand this just i can help you out some more
Dec 29, 2007 | Texas Instruments TI-84 Plus Calculator
Texas indtrument TI 83
Dec 07, 2007 | Texas Instruments TI-83 Plus Calculator
L2 disappeared
Here's what you do in a TI-83 or TI-84:
Go to STAT > 1: Edit > UP ARROW > 2ND > INS > *List Name* > ENTER
Hope that helps!
Oct 18, 2007 | Texas Instruments TI-84 Plus Calculator
Texas Instruments TI-83 Plus Calculator Logo
54 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
