My 1985 Kenmore furnace is not starting. It has a Honeywell DSI. There is a nice spark going on, but it seems no gas is coming in. (The water heater is connected to the same gas line, and it fires-up allright) Looks like the honeywell valve does not allow the gas to pass thru. Any hints?
  • 59 Answers
You need tools. You need to check if there is any open sensors not allowing electrical current to travel back to the gas valve and open up like normal. Turn the furnace on check to see if you hear the gas valve click if u here it click and no gas comes out you have a bad valve. But most likely its a sensor problem.
Posted on Oct 07, 2010
Smart gas valve get 24v. but pilot will not spark or light
Do you have 24 volts at the gas valve terminals when the pressure switch closes?
Dec 17, 2013 | Honeywell Furnace Gas Valve Sv9501h2409
When i turn the heat up sometimes it takes a long time for the gas furnace to start ..why?
Watch your furnace when you turn the thermostat up...make sure to record everything that it is doing. If you have an induced draft, forced air system, then the heat sequence of order should go like this... Initial call for heat from tstat, Inducer vent motor turns on-pulls in the pressure switch, circuit board sends power to igniter whether it is spark or hot surface, then gas valve opens. Flame sensor senses flame, burner stays on, and blower motor kicks in to heat the space. If you notice any variance from this, then something needs to be checked by an HVAC Service Tech.
Dec 14, 2013 | Honeywell Programmable Thermostat Heater
Is the honeywell wv8840B1109 like a smart meter. I was concerned after they installed this on my new water heater. It's basically an alarm for if the pilot shuts off. Seems awfully big to just be for that....
Thanks for photo link. Not a smart meter.
Just ordinary water heater gas control valve, with small circuit board to support error codes:
Copy following link for handy resources:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
http://www.thetankatwaterheaterrescue.com/forums/forum3/
http://waterheatertimer.org/How-to-replace-Honeywell-gas-control-valve.html
How the newer gas control valves are different: Old water heater had thermocouple which supplies very tiny current to gas control valve. When pilot light blows out, the thermocouple no longer sends tiny current and gas control valve shuts off gas to heater.
New gas water heaters have thermopile (just like modern furnaces and stoves), which is basically several thermocouples bunched together. So thermopile sends more current to gas control valve, and supplies enough current to power small circuit board. The circuit board records error events and issues simple error codes. If pilot blows out, then thermopile no longer sends current and gas control valve shuts off gas to heater.
Moreover, the new gas control valve can be repaired and replaced without removing from tank. So tank does not have to be drained... saving time and repair cost.
Gene
Aug 09, 2013 | Water Heaters
Honeywell thermostat RTH6580WF heat is ok but a/c doesnt cool
Same problem here. Gas, hot air furnace with A/C. Fan works with heat, but not A/C. Furnace is old, and I had to move the G wire to C at the furnace, plus install a jumper from Y to G.
Apr 10, 2013 | Honeywell Programmable Thermostat Heater
What does DSI mean when referring to RV water heaters?
D.S.I. = Direct Spark Ignition. You would have a 12 volt switch inside RV, that when turned to ON, will ignite water heater automatically, provided ignition module and rest of components are there, or come with new water heater. Otherwise you would have to go outside with a lighter/matches or whatever and manually start the water heater.
Oct 22, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
Furnace will not heat.
Most of the Lennox G-16s that I have repaired were having problems with the gray Penn-Johnson Piggyback igniton control module.
This is best repaired by replacing the spark module. Sometimes it may be neccesary to replace the gas valve also. Lennox updated to a ROBERTSHAW ignition system. Honeywell can also be used.
Also check that there is no water in the pressure switch or tube.
Hope this helps.
Matt
machtcl1@verizon.net
Jan 13, 2009 | Honeywell Electronic Programmable...
My furnace wont start from the thermomstat.i have to push in start button on the panel to kick on.. i have my temp set at 70.. i changed the batteries on thermostat.. but every other day i have to go down...
I would say that the thermostat needs replaced! (this is the most common problem with the honeywell brand!
Please rate my response to your question!
THANK YOU!
WIRING DIAGRAM LOST FOR NON-PROGRAMMABLE CT87
Red is power return to turn on heat
White is common power to both heat and cold
Blue is power return to turn on AC
You can get specific guidance on wiring at the Honeywell Website.
http://customer.honeywell.com/techlit/pdf/69-0000s/69-0274.pdf
Apr 12, 2008 | Honeywell CT87B ROUND HEATING&COOLING...
Heating & Cooling Logo
101 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
