Question about Kenmore 57029 Side by Side Refrigerator
Kenmore Side by side is HOT between fridge and freezer. I know there are alot of comments on how to check the coils but I don't understand how... I checked the toe kick area and I don't even see coils... so I looked in the back and only thing back there is a cardboard backing that i don't know how to get off unless I rip it off... How do I check the coils or fan or compressor. Can someone give me a little more clear advice? Kenmore Model # 253.52349303 HELP!!!
  • maichicha May 29, 2008
    Fan was not even attached... it fell off somehow. Put back on and now it's good as new!!
    Genius:
  • 1,122 Answers
THE ONLY THING HOT IN FREEZER IS DEFROST HEATER AT COMES ON EVERY 6 HRS. FOR 20 MINUTES, YOU CAN PULL THE FRIG. OUT AND USE A 5/16 OR 1/4 INCH NUT DRIVER TO REMOVE CARDBORD,YOU WILL FIND CONDENSER FAN AND CONSENSER COILS,USE HAND BRUSH AND THEN A SHOP VAC TO REMOVE ALL DUST,YOUR FRIG. WILL WORK ALOT EASYER NOW,THANKS-MIKE
Posted on May 29, 2008
  • MIKE major May 29, 2008
    good job trouble shooting,mike
Kenmore elite model#5059903 the divider between the freezer and fridge gets extremely hot.
Refridgerators have coils than run thru then body of the fridge. They are there to reduce moisture and condensation. It is normal for tham to get warm and sometimes they do get hot it happens when the coil is too close to the body. Normally it only happens periodically. If it is so hot it burns or if it stays hot and dont stop than you have two options. #1 move contents of fridge to another location (back up fridge) and unplug for 24 hrs leave doors slightly open and have some towels near bottom there will be a little bit of water. Plug back in if this does not work. Contact the manufacturer and let them know. There may be a defect in the design.
Jun 05, 2011 | Kenmore Side by Side Refrigerator
Divider between the fridge and freezer is hot to the touch, only from the outside the inside walls of both the freezer and fridge is cold, but the outside facing you as you open the door divider is very...
This is usually normal for these units it can depen on how long the unit is running in a cooling mode.
the other thing to check is the condensor fan in the bottom back side of the fridge and make sure it is running if it is not the it needs to be replaced this will also cause alot of heat on the fromt of the unit
Jun 03, 2010 | Kenmore 53642 / 53644 Side by Side...
Vertical surface on the sides towards the front hot
clean the coil behind the fridge or under the fridge (where ever they are) and make sure both fans are running, the one in the freezer and the one underneath
Aug 11, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Elite Coldspot side by side Model # 106.57706701 Frdige warm, freezer is frozen up. Have removed back panel several times in ther freezer to defrost coils and several weeks later, same problem.
check the fan that transfers the cold air from the freezer to the fridge. thats where it comes from if you didn't know that. also check the the fan on the condenser at the bottom of the fridge. it should be blowing hot air off the condenser to facilitate the elimination of the heat from the condensing unit, just like your a/c does on the houe.
Jul 20, 2009 | Kenmore Refrigerators
Kenmore Coldspot side by side fridge/freezer no longer cold.
The black thing is the compressor. It should run warm but not hot. This usually indicates it's time to clean the condenser coils under the refrigerator. Try using a long soft brush and your vacuum cleaner.
May 03, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore 5126101 middle separator b/t fridge/freezer extremely hot
There are 2 or 3 things that would cause this. first make sure the condenser coils are not plugged with dust (vacumn or blow them out) next check to make sure the fan that cools these coils is running, (this is the most likely problem). if both of these check out ok then you would need to check to make sure your interior lights ar going off when the doors are closed as these will add extra heat and cause the center rails to run hot. last and most uncommon would be a freon system problem.
fyi there is a hot gas freon line that runs in between the doors to prevent exterior sweating. when poor or no air flow problems for the condenser coil exist it causes this area to become hotter.
One more thing. if you do determine that the condenser fan motor is bad you can put a normal house fan blowing on to the coil to help cool this area down until you can get the unit repaired.
If you need any further assistance leave me a comment here and I'll gladly get back to you. Thanks Peyton
Mar 11, 2009 | Refrigerators
Kenmore fridge side by side keeps freezing up
defrost problem,check,freezer fan,remoce freezer back panel,check heater,find and check defrost timer,most are in the frig.if it is manual put it in defrost then check to see if the heater ib the freezer comes on,if it does then you have a bad defrost timer,if not,the freezer heater or terminater(attached to coils)is bad,chevk with your meter,let me know-mike
Feb 03, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigirator not cooling up
you need to pop off the gate and really get under there with a shop vac,is the fan in the freezer working?can you pull the frig out to see if the compressor is running,you can put your hand on it to feel if it is running(watch it it might be hot,the only other thing is it might be stuck in defrost,can you find the defrost timer and manualy take it out of defrost,let me know what you find and we can go from there-mike
Oct 14, 2008 | Kenmore 53642 / 53644 Side by Side...
My side by side fridge, fridge side is feezing up...
HI,GOOD JOB CLEANING THE COILS IT HELPS ALOT,MOST TIMES IF YOUR FREEZER SIDE IS FREEZING UP THERE ARE 5 THINGS TO CHECK,WHAT MAKE,MOST GE HEARTERS GO BAD FIRST,EASTEST TO CHECK FIRST IS THE FAN,OPEN FREEZER DOOR,IS THE FAN RUNNING,SOME MODELS YOU WILL HAVE TO HOLD THE FREEZER BUTTON DOWN FIRST,MOST ON INSIDE TOP,NEXT REMOVE FREEZER BACK PANEL WALL,IF YOU SEE A SHEET OF ICE,YOUR DEFROST HEATER(ON BOTTOM OR SIDE) AND THE HEATER TERMANATOR(LITTLE ROUND CLIP ON BALL WILL HAVE TO BE CHECKED WITH A OMES METER,YOU CAN DEFROST IT WITH A HAIR DRYER,WHEN DEFROSTED YOU CAN SEE IF THE DRAIN(MIDDLE BOTTOM OF FREEZER IS CLOGGED,LAST DEFROST TIMER(TOP FRONT,BACK BOTTOM,INSIDE FRIG.TURN CLOCKWISE SLOW TILL YOU HEAR A CLICK,SEE IF FREEZER FAN WENT OFF,WAIT 25 MINUTES,SEE IF FAN COMES BACK ON IF SO IT'S NOT THE TIMER,LET ME KNOW WHAT YOU FIND AND I WILL HELP YOU FARTHER-MIKE
Jun 21, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore 57029 Side by Side Refrigerator Logo
99 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
