Question about Yamaha 2500 Watt Industrial Inverter Generator YG2800i
I have a Yamaha ef2800i that will fire on the first pull, runs up to operating rpm then dies. It won't restart for about a minute. I will go through the fuel system but first I want to check the oil level kill. Where is it located? The oil light does not come on before it dies but as soon as the AC light comes on it shuts down. Is this a clue to a problem?
  • super_dave94 Oct 11, 2010
    Classic fuel problem it was. I was able to run the unit on starter fluid confirming it was not the oil level kill, cleaned carb. It now runs great.... Until I put the throttle control motor back on the carb. I indexed the controller to wot with the engine off but it now runs wide open unde a load when not in sw mode. Any ideas?
  • Yamaha Master
  • 5,603 Answers
This is a classic fuel flow problem. The oil level switch is usually screwed into the crankcase fairly low with a single wire attached. I would check the float valve into the carb bowl. Also check fuel filter. Some of these are on the end of the fuel finder hose in the tank. Purrge the fuel system and carb. ALSO verify the fuel supply valves is being fully opened as some are hard to get to.
Posted on Oct 07, 2010
  • Fred Yearian Oct 11, 2010
    Getting the control motor set properly is essential. Also check wiring... backwards control power would do this. Often there are springs involved with the govenor systems and those can be critical. The indexing of that control motor is going to be critical and IF by chance it were off 180 degrees that would cause the runaway. Try to find a manual or call the manufacturer for alignment procedure or the other thing is to keep trying different indexing till you find the right one. Indexing can be tough to keep track of as often there are springs that go "sproing" and disturb the setting before you can document it.
I have a 1998 yamaha xl760 cranks over but does not fire.I have spark, fuel,and compression. It's a new sbt engine.It was running fine out of water,when I put it in the water it would only run at...
The only other thing is air. I am not familiar with your engine but it sounds like it's not getting air. If you pull the plug after trying to start it is the plug wet?
May 24, 2012 | Yamaha Boating
Toro snowthrower model # HSK 635 won't restart, stated first time, ran about ten minutes, then died, put brand new spark plug in, getting good spark, just won't fire up, even when I tried a li
check and make sure its getting fuel. when trying to start, spray some engine starting fluid in spark plug hole. just a little bit. replace the plug then try to start it. if it starts then quits then its a fuel problem. fuel not reaching engine. good-day !
Jan 30, 2012 | Garden
My 2001 yz 250 N-1 just died after running really strong 10 minutes into the trail. I changed the plug and it wouldnt turn over and just backfire like every so many kicks.
Hi, Brian and the usual suspects are:
1. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
2. Failed alternator/generator and or voltage regulator.
3. Loose or corroded battery terminals and or cables especially the "NEGATIVE" cable, look for loose, corroded, or broken connectors inside the cable harness at "BOTH" ends.
4. Failed main circuit breaker or ignition switch, check for loose connections and continuity.
5. Failed system and or ignition relay, check for continuity.
6. Failed ignition coil, ignition/electronic module.
7. Failed CKP, CPS, CMP, MAP, TPS, or BAS sensor, corroded, loose or broken wire connector pins/sockets.
8. Throttle cables and or idle speed improperly adjusted hot idle speed should be 950 RPM to 1000 RPM.
9. Air/fuel mixture screw improperly adjusted.
10. Accelerator pump damaged or not working.
11. Water or dirt in the fuel system, carburetor or filter.
12. Restricted, blocked or kinked fuel line.
13. Fuel tank empty.
14. The gas cap is not venting properly or fuel tank venting system blocked.
15. A failed fuel pump, pressure regulator and or fuel injectors.
16. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
17. Needle and seat stuck closed in the float bowl.
For more information about your issue and valuable "FREE" downloads that you need please click on the links below. Good luck and have a nice day.
2000 YZ250 Back fire Yamaha 2 Stroke
Bike won start just backfires occasionally
YAMAHA YZ250 LC Owner Service Manual
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Jan 15, 2012 | Yamaha YZ 250 Motorcycles
I just got a 1994 yz 125 and when i was riding it ,.. it would run good as long as i was going slow and not raping out the gears .. but when i would give it a lot of gas to take off it would bog out and...
if the plug is sooty your float is set wrong the air filter should have oil on it to catch dirt.sounds like a carb problem although it could be the power valve
Aug 24, 2011 | 2003 Yamaha YZ 125
I have a 06 banshee with fmf pipes it won't start
sounds like your rings are shot, Prob only runs at high rpm & dies when gets lower and wont tick over, try kicking it over slowly with your foot can you feel the compreesion cycles , if not defo rings
May 27, 2011 | 1986 Yamaha RD 350
I have a 2002 dtr125, recently i ran the tank dry i refueled and it ran straight away. left the bike over night and started it the following evening, i rode 50m down the road and it died! still has full...
Sounds as if you have all the variables to make it go but, I'd suspect that either the tank filter is plugged or there is an inline gas filter that is plugged to a point it's only allowing a small amount of fuel (gas) to enter the carb. It's not uncommon after running and engine bone dry to pick up a bunch af rusty sediment in the bottom of the tank. the filters do their job but end up starving the engine of gas. There is a bit that's running through and after sitting for a few minutes the carb floats fill up and the motorcycle operated normally till the gas in the float bowls runs out and the engine dies.
Dec 20, 2010 | Yamaha DT 360 Motorcycles
Yamaha 2500 Watt Industrial Inverter Generator YG2800i Logo
174 people viewed this question
Top Yamaha Electrical Supplies Experts
John Trevino
Roland W VanLue
Roland W VanLue
Dusty Ryan
Level 1 Expert
Are you a Yamaha Electrical Supply Expert? Answer questions, earn points and help others
