Ecoquest Living Air Classic Air Purifier
Problem for Ecoquest Living Air Classic Air Purifier
No Ozone
By Ronv67 on May 29, 2008
Have a Living Air Purifier. Replaced the plates and coil on the side but no ozone / clean air is coming out. The fan is turning fine. It is a XL 15
Clarification Request
Posted by JSEhandyman on Dec 23, 2008
Is the fan working?
Have you checked the fuse (in back of the chassis)?
Classics usually have a couple of lights or LEDs inside, visible if working. Can you see them?
By "coil on the side", are you referring to the "flyswatter" antenna?
Thanks in-advance.
Same Problem
Jun 02, 2008
-   No ozone...green light does not come on; however fan works just fine.-   Guest
Popular Solutions for Ecoquest Living Air Classic
Questions and Unsolved Problems for Ecoquest Living Air Classic
Do you recommend Ecoquest Living Air Classic Air Purifier?
Answer
Answer
I have a Classic Living Air model XL-15C. I keep hearing a loud rattling noise from inside. I... (More)
Answer
no high voltage to grid after 5 minutes operation
Answer
Appears that the high volatge supply has failed. Neither lamp (inside) is illuminated consiquentlky... (More)
Answer
the ozone only comes on at the highest setting. It is to strong to have it on that level. What is... (More)
Answer
Not producing ozone, wire on little round sensor is broken on the small silicned in circuit board... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Ecoquest Living Air Classic...:
Top Air Purifier Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Air Purifier Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
