Question about Whirlpool LGR8648PG Gas Dryer
How do I get to the igniter on my WP Gas Dryer (LGR8648PG)?
  • 5,911 Answers
In order to get to the burner assembly where the igniter is located, you will need to open the dryer cabinet and remove the drum by following these steps:
1. UNPLUG the dryer and remove the lint screen.
2. Remove the two screws that were under the lint screen and lift the top panel.
3. Unplug the door switch connector plug and any ground wire that may be installed on the casing.
4. Locate the two screws that hold the front panel in place. There should be one screw on each side in the cabinet interior.
5. With the door shut, lean against the front panel and remove the two screws that hold it in place. Once the screws are removed, grasp the front panel at the top center and lift straight up to remove.
You should now have complete access to the dryer interior.
6. Remove the dryer drum. Release the belt tension, by pushing the idler pulley (tensioner) to the right (away from the belt) and remove the belt from around the motor pulley. Then, with the belt still wrapped around the drum, use the belt to lift the entire drum out of the cabinet.
You can reference the following websites for helpful exploded view diagrams to assist you with assembling and disassembling your dryer:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
Once you have completed your repairs, reassemble the dryer as follows:
1. Re-install the drum, making sure the rollers are seated properly in the groove around the perimeter in the rear. Make sure the belt is looped around the drum with the groove side facing the drum.
2. Have someone hold the drum in place while you re-install the belt over the tension pulley and motor. If working alone, kneel down so you can see the tensioner and motor and rest the drum front on your shoulder or knee.
NOTE: With the belt removed, this may cause the idler pulley (tensioner) to come loose. This is normal with no tension on the pulley to hold it in place.
3. Reinstall the belt tensioner by following these steps:
a. Loop the drive belt around the dryer drum with the groove side facing the drum.
b. With the tensioner in your left hand, insert the clip end of the idler pulley into the grooves on the dryer bottom casing with the idler wheel pointing to your left. (The grooves are directly in front of the drive motor.)
c. While holding the tensioner in place, insert the belt UNDER the wheel with your right hand and push the wheel to the RIGHT while pulling the belt over the drive motor pulley.
NOTE: If this does not explain it well enough, you can also verify by going to repairclinic.com. Click on the Repair Help link and look for the "Dryer Belt Diagrams" link under the Special Features section on the next page. Look for WHIRLPOOL and refer to diagram H (This model Amana is manufactured by Whirlpool).
4. Once you have the belt installed, re-install the dryer front panel by holding it as you did previously. Line up the holes on the inside bottom edge of the front panel with the small mounting cleats on the front edge of the side panels. This can be done by yourself, but an assist may make it easier.
5. Once you have the front panel in place, lean against it to hold it in place and install the mounting screws.
NOTE: Don't forget to reconnect the grounding wire and door switch connector plug. Without the door switch connected, the dryer will not run. Lower the top panel back in place and reinstall the two screws.
NOTE: Placing a piece of duct tape over the dryer vent chute will help safeguard against dropping anything down in the blower fan assembly. If you drop any screws down the chute, you will need to remove the dryer back panel to retrieve them.
If you have any questions about this repair, please post back and let me know. I hope you find this information helpful.
Posted on Oct 07, 2010
Igniter comes on when dryer starts and the flame burns but only the first time. Is this a problem with the coils on the gas valve?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 19, 2010 | Whirlpool LGR8648PG Gas Dryer
Need book to convert dryer from natural to lp
Thank you for contacting Fixya.com.
Please check the bellow links to have an in-depth knowledge related to your query:-
http://www.ehow.com/how_5321294_convert-dryer-natural-gas-propane.html
http://fixitnow.com/wp/2009/03/13/converting-a-gas-dryer-from-natural-gas-to-propane/
Please get back to us if you have any further query.
Have a nice day.
Dec 02, 2010 | Whirlpool Dryers
THE BURNER COMES ON AND THEN THE BURNER SHUTS DOWN AFTER A FEW MINUTES. TIMER WORKS FINE, SPINS WITH NO PROBLEM AND HAS BEEN COMPLETELY CLEANED OF LINT.
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 02, 2010 | Whirlpool LGR8648PG Gas Dryer
I can't get any heat from it.
Make sure front of dryer is not blocked, air flow is needed to dry.Check that the lint filter and exhaust duct is clean.
Check the blown fuses and home’s circuit breaker tripped. Dryer use 2 household Fuses or a circuit breakers, If one is blown, the dryer may still operate but not heat. Alternatively, the dryer may heat, but it may not heat up as hot as it should. Replace the Fuses or reset the circuit breaker.
Another common cause of a dryer failing to heat is a faulty Heating Element. You will need to replace it.
Good Luck and have a nice day.
Rating the solution is highly appreciated.
LPG kit for Speed Queen 30XG gas dryer
You should be able to convert it over. Check out the link that I am providing. It's information on the conversion process and what it entails. Hope this helped and best wishes.
Sep 06, 2009 | Dryers
No heat
Try this link I hope it helps, I know it helped me a ton!! ps don't forget to rank my help. Thank you and have a nice day!
http://fixitnow.com/wp/2004/11/13/mailbag-how-to-troubleshoot-a-gas-dryer-with-no-heat/
May 07, 2009 | Kenmore 73012 / 73014 Gas Dryer
My gas dryer stopped heating it is a Kenmore 70 series. I am getting good gas flow but dryer will not heat.
May 07, 2009 | Whirlpool LGR3624JQ Gas Dryer
Will not dry gas dryer
May 06, 2009 | Dryers
GE Gas Dryer
Please read this article for detailed info:
http://fixitnow.com/wp/2004/11/30/appliance-repair-revelation-burner-operation-in-a-gas-dryer/
and
http://fixitnow.com/wp/2004/09/19/appliance-repair-revelation-troubleshooting-a-gas-oven-that-wont-fire-up/
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Jun 16, 2008 | Dryers
Whirlpool LGR8648PG Gas Dryer Logo
116 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
