Question about Whirlpool GU2400XTP Built-in Dishwasher
My unit used to send steam out of the top but no longer gets hot. I'm sure the coil should be replaced. This unit was pricey and is used every 7-10 days over the last 14 or so months. My last unit lasted 15 years. How difficult is it to change the heating coil? How much is the suggested retail price?
  • Whirlpool Master
  • 43,501 Answers
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Posted on Oct 07, 2010
My delonghi esam3300 can not make any steam or hot water. The heater still get hot. There is voltage across the solenoid terminals on and off when I flip the steamer switch. Solenoid defective?
First I'm not a Delonghi tech. But I have worked on similar table top "Super Automatic" machines. You should call your vendor for service as there is no customer serviceable parts in this machine.
*** the following is for information only. ***
* There are usually separate boilers for table top units. There is a pump and heater system for each section. (usually 2 for this type of machine. But there may be a third system if you have the Coco option.
* Since each system is separate then your Latte/cappucino system has a problem. I will list the most common but all require a qualified service tech to repair/replace. (lots of small parts crammed into a very small space.)
* Cap/Latte Membrane button not working. If it feels mushy (not like the other buttons) then the button panel needs to be replaced.
* There is a CPU/PC board malfunction. Replace
* There is air in the water line to the Cap/Latte system. Make sure the water tank is filled. Power down. Wait 10 seconds. Power back up. Press the Cap/latte button to start the pump. Watch the steam wand if water flows out. If it does, then wait 30 seconds and try again. should be steaming.
* No steam or at least hot water? Just cold water? Then the steam heater and/or thermo-fuse, thermo-disk, needs to be replaced.
* Got hot water but little to no steam? Then steam unit and/or thermo disk needs to be replaced. (best to replace both as a whole unit; tank, Heater, and Thermo-disk)
* Heats up very hot but sputters water and steam. Clean steam wand and/or tip (if removable) If it leaks steam at the top of the wand near the body of the machine then the whole wand needs to be replaced.
* Still sputtering? The steam system is clogging up. Call for service.
* Final; I'm not a fan of de-scaling as it causes more problems for the machine. I've always found that using filtered water (bottled ok) is best. Water softeners if available is okay. BUT stay away from HARD water and Ultra Pure (100%) water as it leaches out the metal ions from the machine.
Aloha, ukeboy57
P.S. Since you have already taken things apart, I'm guessing you don't mind jumping to the 'guts'. Your probably looking at a clog at the vibration pump all the way to the hot water (or steam) tip. It can clog anywhere there is water. It may even be the water hose (with filter?) or the water tank. Start from the tank and keep trying to get water to flow through each section. You will need power for this so be careful! There are a lot of you tube vids showing how to check the common vibration pump. Bring your reading glasses as it have very small parts (and don't lose the spring or the small ball!) Good luck! Aloha, ukeboy57
Apr 16, 2018 | DeLonghi Coffee Makers & Espresso Machines
Can you fix an X3-X4 francis francis machine
First I'm not a Francis tech. But I have worked on similar table top machines. You should call your vendor for service as there is no customer serviceable parts in this machine. (To your question, Yes, it can be fixed but you may find it costs more to fix than to replace it with a new machine.)
Aloha, ukeboy57
Apr 09, 2018 | Coffee Makers & Espresso Machines
I have a delonghi esam 6900. It makes coffe but it doesn't make capuccino or latte or flat white and also no steam. What causing it?
* Final; I'm not a fan of de-scaling as it causes more problems for the machine. I've always found that using filtered water (bottled ok) is best. Water softeners if available is okay. BUT stay away from HARD water and Ultra Pure (100%) water as it leaches out the metal ions from the machine. If you must descale then follow the MFR instructions and use approved solutions.
Aloha, ukeboy57
Feb 08, 2018 | DeLonghi Coffee Makers & Espresso Machines
Dishwasher not cleaning dishes; water not coming out of top spray arm
You are right to go to the inlet filters. If they are clogged you would lose pressure, but not that much...The pressure pump is probably not outputting any longer. Locate it and see if it is moving freely.
Jan 14, 2013 | Dishwashers
Water shoots out of steam valve and can't make espresso
Samantha,
The steam function and the expresso use the same elements to create the steam but the valves will direct the steam to the expresso unit or the steam arm. Most likely you have a faulty valve. In most cases the valve will not open until the pressure gets to the right level. If you are just getting hot water out of the steam arm instead of steam via the expresso unit it most likely means that the valve is faulty. The valves can be replaced but is not easy. You will need to have the unit serviced or you could try to replace the valves. Make sure the flow meter is working before you replace the valves. You can check the operation of the flow meter by running the hot water cycle and making sure that you get the right amount of hot water. Good luck!
Nov 21, 2011 | Krups XP2070 10 cup Coffee Maker/15 bar...
I am getting a build up of black mold on the inside of the rinseaid compartment and all plastic pieces. Even in the bottom of the utensil basket. This has been happening for the last two months. Once I...
The first problem I believe you have is your hot water entering the unit is NOT hot enough. Turn up the temperature setting on your hot water heater. The water in your pipes should come out around 120 degrees Fahrenheit. That should be hot enough to burn your skin so use a thermometer to test. Second the internal heating coil may be burnt out or operating very low and may need to be replaced. For it to sterilize it needs to heat the inside to over 212 degrees Fahrenheit when steam is created. You should definitely make sure that the unit is drying your dishes and steam is spewing out the front exhaust vent during that cycle. Third the soap you use should be a better quality such as Cascade, or Finish. You may also try 2 TBSP of bleach during the WASH cycle. Which will also cause to sterilize.
The only reason you can be getting mold is lack of heat. If you are saying it is a recent problem then I would consider how old is the machine? And look toward the heating coil element.
If the heating coil is working, the washing unit may not be getting enough power. Make should the circuit is properly load rated so it is getting enough electricity to get it hot, hot, hot.
Oct 30, 2010 | Gaggenau GI966-760 Built-in Dishwasher
Radiators only working on the top third? please can anyone help! it is a central heating system
If old cast iron units, they are probably filling with rust and debris not allowing the water or steam to get to the lower sections. You will need to have them cleaned. Not an easy fix. They will need to be removed and either power washed or acid dipped. Make sure the valves are open fully to allow as much flow through them as possible.
Jan 06, 2010 | Heating & Cooling
Overflow getting hot oan letting steam out
if the guage isnt indicating hot and the car is getting hot i would make sure that the temp sending unit is still good and do a cooling system service
Sep 26, 2008 | 2003 Mazda Protege
Significant leak into drip tray when brewing and using steam/hot water
run a 50/50 mixture of white vinegar and water thru your system.may have to run it twice,should clear it up if its a mineral clog. be sure to run a few cycles of clean water afterwards to clear the system
Dec 01, 2007 | Saeco Vienna De Luxe Espresso Machine
Whirlpool GU2400XTP Built-in Dishwasher Logo
48 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
