Question about Kenmore 62602 Electric Dryer
Wont stay on
Will start but wont stay on
  • iamenergy May 11, 2010
    BE VERY CAREFUL WHEN WORKING ON ANYTHING WITH AC POWER CONNECTED !!
    What exactly do you mean by "won't stay on"?
    Does it stop tumbling?
    Does the heating element continually cycle on/off?
    There is at least one thermal cut off switch.
    It is a two terminal device usually mounted near the heating element or in/near where the hot air exhaust leaves the dryer.
    It
    should be closed (shorted) all of the time. It should ONLY open when
    dryer overheats. Check it with an ohm meter with AC power disconnected.
    It should be a short. If open replace it.
    You can also check it with power connected but you must be VERY VERY CAREFUL !!
    Connect an AC voltmeter set to read 250 VAC across the switch.
    Run the the dryer.
    It should measure zero VAC.
    If the switch opens it will measure about 220 VAC.
    If it opens when it has not overheated, replace the switch.
  • 413 Answers
Check under the console for a motor relay. If a motor relay is present replace it. On some models the relay is part of the start switch. The relay will be a black,square device with 3 to 4 wires on it. There may also be a relay for the heater. If so, replace it too as it may be ready to fail soon.
Posted on Jun 01, 2008
95 explorer wont stay running
Someone will need to check the key switch and figure out what is not getting power. Could be the key switch or a relay.
Jun 08, 2013 | Cars & Trucks
If immobiliser light stays on and my renault megane 1.4 hatchback wont start whats the problem
If immobiliser light stays on and my renault megane 1.6 hatchback wont start whats the problem
Nov 14, 2012 | 2005 Renault Megane 1.4
It wont start then if it starts it wont stay start
i would start with the safety switch on the clutch/brake pedal
Sep 23, 2012 | Craftsman GT 5000 26 HP54" Garden Tractor...
Wont start
Its old enough, how about the coil packs? Crank position sensor?
May 16, 2010 | 2000 Oldsmobile Intrigue
I have a 1992 ford probe 2.2 that wont stay running
try a compression test on the cylnders, If it overheated when the head blew , the rings can go soft with too much heat
Apr 24, 2010 | 1996 Ford Probe
Fuel pump wont stay on wont start replace the
The pump is not supposed to stay on, you should only hear it for a second or two when the ignition is turned on. At least you know the pump is working. There must be a problem in the ignition system, like no spark, do to a bad coil, ignition module, without testing it's hard to say.
Nov 10, 2009 | 1983 Dodge Pickup
Wont stay started
if you removed the timing belt, then its probably out of sync. the sound is probably the piston hitting the valves. its a good practice to turn the engine manually 2X after assembly before starting. sad to say if im right the valves are bent by now
Jun 03, 2009 | 2000 Chrysler Grand Voyager
Wont stay stared
try adjusting the idle screw on the carb.
Jan 19, 2009 | 1998 Gas Gas EC 250
Wont start
if i drive my bronco to work shut it off it wont start sounds like it has a dead battery if i let it sit for an hour it will start back up can you tell me if you know what it is
Dec 15, 2008 | 1989 Ford Bronco
Kenmore 62602 Electric Dryer Logo
100 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
