Question about Kelvinator 12 cu. ft. / 340 liter Chest Freezer KDC-47
My Kelvinator refrigerator temperature varies a lot; thermostat problem?
  • Mario L Oct 07, 2010
    It doen't seem to loose air.
    Another clue would be that the refrigerator doesn't run when thermostat button is set near the warmest position and only start when I turn it and reach near the coldest position.
    Temperature can vary from 32 to 42 degres.
  • 171 Answers
Check to see that the door closes tight and it is not losing cold air. If it seems to be ok I would check the thermostat
Posted on Oct 07, 2010
Kelvinator opal upright freezer is over freezing..is there a temperature control somewhere or what could be the problem?
the problem could be the heater element, bimetal, thermostat, fuse.must open freezer cover and check.
Nov 14, 2016 | Kelvinator Freezers
Where is the defrost thermostat located on kelvinator freezer
Depending on the model you pull the cover from evap coil and you will see either a bimetal thermostat or the timer
Jun 30, 2015 | Kelvinator Freezers
I have a chest cooler and it does not keep the 35degrees needed it is alway on 40 degress. is there an adjusting know in the unit?
Adjusting the thermostat clockwise will normally lower the freezing temperature on unit.. If it does not, either the thermostat is defective or perhaps the unit is low on refrigerant.
Feb 17, 2015 | Kelvinator Freezers
Freezer serial # 845440256 age?
Replacement thermostats depends on whether the fridge is a double door or single door model. You can buy this part from your appliance parts store/supplier.
Feb 20, 2014 | Kelvinator Freezers
Freezer won't get below 30 degrees at the highest setting, food won't freeze.
Possible that the gas pressure is down to low gas or leak on the system. Also it can be due to faulty thermostat, faulty compressor if the compressor is working all the time and reaching the set temperature. Also if the compressor is not cutting off this must be a suspect.
Aug 24, 2011 | Kelvinator Freezers
Major Appliance
It sounds like the thermostat is not sensing when the fridge/freezer reaches it's set temperature.This will result in the compressor running non-stop and this causes ice build-up inside the fridge.See on what number (0-7) the thermostat is set on.If it is set on 7,turn it down to 3 and see if it makes a difference.If there is no difference it means that the thermostat is not sensing & switching the compressor off.You will then have to replace the thermostat.
Regards
Andre Nagel
Mar 15, 2010 | Freezers
Fridge not getting cold
unplug unit to "reset." pull unit out from wall and blow the coils out on the back of refrigerator. if that does not work- call service man to come check freon level.
Aug 09, 2009 | Kelvinator 12 cu. ft. / 340 liter Chest...
Freezers Logo
523 people viewed this question
Top Kelvinator Freezers Experts
Mike Squire
Victor Nwachukwu
Victor Nwachukwu
Are you a Kelvinator Freezer Expert? Answer questions, earn points and help others
