Question about Speed Queen Dryers
My Speed Queen Electric dryer no longer heats. Model number AE5413W. I purchased this dryer in 1992+/- and cannot find a repair manual online. I believe it is the thermal safety switch, but since I don't have the manual, I do not know where to look. Pleae help. Thank you, Donna Houser
  • 171 Answers
I believe it is the element as they wear over time and it may have broken and needsa to be replaced.
Posted on Oct 07, 2010
Speed queen electric dryer heats for about 8 minutes then heat goes off and does not come back on
The duct may be clear but the exhaust on the back of the dryer may be blocked. You have to take the back off the dryer and check where the blower is. Good luck.
Mar 25, 2014 | Speed Queen AES28AWF Electric Dryer
My speed queen dryer model #AES68AWF doesnt heat what could it be?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101';
Jul 16, 2011 | Speed Queen AES68AWF Gas Dryers
I have a speed queen electric dryer model number aem45300. problem the dryer runs but does not heat. We cleaned out all the area that contained lint. Is there a reset button for the heating element in...
There is no reset button, check yoru breaker, by turning FULLY OFF (somewhat forcefully off) then back on and test again.
All thermal limiters will auto reset when cooled...
Mar 04, 2011 | Speed Queen AES17AWF Electric Dryer
My speed queen gas dryer comes on but will no longer heat. The igniter is fine.....passes the Ohm test. What might be the solution? And what are the est. part costs....this is an old speed...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
It works on amps... not ohms...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 07, 2010 | Dryers
Speed Queen Commercial Dryer model EE111OL (electric) got wet in recent flood, still spins but not getting heat. Is it the thermostat, sensor or igniter that is bad and needs replacement?
If this dryer was submerged any component that was in water needs to be replaced. NOT cleaned and reused. there could be water in he burner and any electrical or mechanical component that was in water will soon fail if it hasn't already. This is a safety issue. Please have this repaired as if your life depends on it as it may.
Eric
Jul 30, 2010 | Speed Queen AES28AWF Electric Dryer
My speed queen AGS17AWF isn't getting any heat, a friend said that it could be the ignitor or fuse but I cannot find the fuse on diagrams and I don't know how to get to it based on the diagrams, any help...
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 05, 2010 | Speed Queen AGS17AWF Gas Dryer
Dryer does not heat. Electric ignition does not "spark" lighting
Gas Dryer2_bing.gif not Working Gas Dryer Not Heating
If your dryer is electric2_bing.gif..
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
heatman101
May 04, 2010 | Speed Queen AGS28AWF Gas Dryer
Dyrer won't heat...
I can not find a diagram using your model number.
However, most Speed Quenn dryers have 2 screws on the bottom right and left sides of the front panel.
Unplug the dryer.
Remove the 2 screws.
Lift the panel forward and disconnect the door switch wires.
Reemove the belt and drum to access the heater circuit.
Jan 20, 2009 | Speed Queen AES28AWF Electric Dryer
Electric maytag stack dryer not heating...
That dryer is made by Speed Queen. A common failure part is the thermal overload, mounted on the heater box. Items 4 and 6 in the picture Iposted are possiblities.
Dec 14, 2008 | Maytag SDE2606 Electric Dryer
Dryers Logo
255 people viewed this question
Top Speed Queen Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
danoyachtcap
danoyachtcap
Are you a Speed Queen Dryer Expert? Answer questions, earn points and help others
