Question about Kenmore Dryers
I have a kenmore dryer Model number 11066752501. I was working with jahn21 earlier on some problems but now the dryer won't continue to run. I push the start button and the dryer starts but stops as soon as I release the start button. My origional problem was that it wouldn't heat up. After replacing the timer, high limit thermostat, heating element and the door switch I thought I had the problem solved but now it won't stay running.
  • 1 more comment
  • dhunt1157 Oct 07, 2010
    It does the same thing when I manually push the switch. It also does the same thing if I by-pass the switch and wire the 3 wires together.
  • dhunt1157 Oct 10, 2010
    I just replaced the motor and everything works great now. Thank you for your help!
    I just replaced the motor and everything works great. I really appreciate all your help.
    President:
  • 1,554 Answers
Based on the information posted here and upon reviewing the original problem, the problem now turns out to be a centrifugal switch or the motor itself as a whole. The dryer doesn't stay running because the centrifugal switch fails to throw from the start winding to the main (run) winding or the main (run) winding itself is open. In either case, the motor needs to be replaced since the centrifugal switch is an integral part of the motor. But before you do that, check the motor terminal connections and/or the motor windings.
Posted on Oct 07, 2010
Kenmore he2 dryer, model: 110.c87561602 beeps twice, wont start and is not showing any error messages
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
https://www.youtube.com/watch?v=MhVUEhngZMg
https://www.youtube.com/watch?v=9xD7lCXJ0ZM
https://www.youtube.com/watch?v=sTRP6kHqAFs
Hey GOD IS GOOD !!!! WHICH IS WHY MY ADVICE IS FREE
What to Test When Whirlpool or Kenmore Dryer Won Start or Run Troubleshooting Why Your Dryer Won Start PartSelect com Kenmore Whirlpool Dryer Won Start Easy Fix
Jan 03, 2017 | Kenmore Dryers
Model 64982. Where can I get push to start button?
This is a Sears Model that begins with the number 110.64982 and has more numbers. You should be able to find tag inside dryer door. Once you have the full number any local parts outlet should be able to get the part.
Be awre, this switch does NOT fail often and MAY not be the problem. There are SEVERAL reason why your dryer may not start when button is pressed and you should check those before you buy a part you may not be able to return.
The video below WILL help get you started:
How to Troubleshoot Brown Top Kenmore Dryer that Won Start
Nov 21, 2015 | Kenmore Dryers
Kenmore dryer model 110.74994300 push start does not stay on
Jul 01, 2014 | Kenmore 62602 Electric Dryer
Kenmore elite sensor smart electric dryer Model 110 65066500 I have power but won't start
Jun 24, 2014 | Kenmore Dryers
Kenmore 70 series dryer won't heat
Post the model number for clarity. These tests should only be attempted by competent service personnel. Do you actually have 220 power? Are both legs of circuit hot...at 120v? While dryer is unplugged from power, check the heating coil for continuity. Also check continuity to ground from each end of heater (should not have continuity to ground at both ends). Also there should be power to the heating element when activated.
Mar 14, 2012 | Kenmore Dryers
I have a Kenmore 500 series dryer. The dryer just stopped working but the light stays on when the door is closed.
the door switch is broke.when you push on the paddle of the door switch the lite should go out,if you don't see the paddle it most likely broke off,you need to send the full model number next time,it will start with 110.or similar.the door switch is a safety so the machine won't run until the door is closed,if the switch is broke no power will go to start the dryer
May 10, 2011 | Kenmore 500 6953 Dryer
My Kenmore Series 70 Dryer will not start at all. No sensation of the start button doing anything when I push it. Thermal fuse continuity is good (0 ohms). Light goes off inside the dryer when I depress...
most likely its the push button that is bad. you can buy one from any appliance dealer that services a kenmore dryer. the part is a reasonable price. you also have to give them the model number and serial number. have a good day!!
Oct 15, 2010 | Kenmore Dryers
Kenmore electric dryer not heating
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 20, 2010 | Kenmore 63942 Dryer
Dryers Logo
138 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
