Question about Home Security
R16D4B4SYS-1000 will my enternet service alow me to view my system from my work pc or will i need a IP address?
SOURCE: NetPrint 1000
Hello everyone,
I've spent the past several hours getting my NetPrint print servers to work on my network & print from Windows XP.
Guess what? I've got the solution.
I have both the NetPrint 50 model and the NetPrint 1000 model. I only got the NetPrint 50 to work. I think my NetPrint 1000 may be shot. Also realize that there were a number of company acquisitions (DPI / Digital Product Inc., Osicom, Sorrento), so there is little to no information left on the Internet regarding these print servers.
Here is what you need to know:
1.) Take the cover off the print server. On the left and right sides there is a little tab that holds the case together. Get a flat-head screwdriver and apply it to either the left or right side along the seam.
2.) Jumper pins. On the NetPrint 50 you want: Auto; 10BaseT. On the NetPrint 1000 you want: 10BaseT; Auto; Tx; Factory (Jumper 10). Remember, I couldn't get my NetPrint 1000 working.
3.) IP Address. The NetPrint print servers use BOOTP to obtain an IP address. Realize - this is an older version of DHCP, but NOT the same thing as DHCP. Some DHCP servers are backwards compatible and support BOOTP. Fat chance, though. My wireless router only has a DHCP server. So, obtaining an IP address automatically is likely far too difficult / impossible. What you will need to do is assign an IP address to the unit. We cannot use DHCP to do this, and we cannot remotely access the unit (web server / Port 80 is not listening on my units). To assign an IP address to your unit, open up a DOS / CMD prompt (Start->Run; type: "cmd" and hit OK). We will be using the ARP command, which stands for Address Resolution Protocol. This is the protocol that translates between IP addresses and MAC addresses.
a.) Select an IP address you want to assign to the unit
b.) Ok, now look at the bottom of your unit and find the MAC address; it begins with two zeros.
Now enter this command:
arp -s 192.168.0.16 00-40-AF-18-61-40
replace 192.168.0.16 with the IP address you want to assign to the unit. Replace 00-40-AF-18-61-40 with the MAC address found on the bottom of our unit.
What we just did was tell your computer that anytime we send data to that IP address, it will actually send it to that MAC address, which is your unit. Ok, good job.
Now type: arp -a
and you should see and verify your entry. If you made a mistake, type: arp -d 192.168.0.16 to remove your entry.
Now, your NetPrint print server has no idea it's just been assigned an address. And it won't know to respond to that IP address unless we make it listen on that IP address. This is easy to do. All you have to do is ping the unit. Don't worry if the unit does not reply to your pings. Simply pinging it will make it realize it needs to listen on that IP address. So, type this command:
ping 192.168.0.16
Done. It's now listening on the IP address you just assigned it.
4.) Setup Printer in Windows XP. Ok, go to Control Panel -> Printers and Faxes. Add a Printer, select a Local Printer (uncheck plug-and-play). When it asks you to select a Printer Port (it will default to LPT1)... select Create New Port -> Standard TCP/IP Port. Hit Next. Now it will ask you for the Printer IP Address and Port Name: Enter the IP address you just assigned to your unit; the Port Name can be anything you want... this is just a string that uniquely identifies this printer port on your computer and it has nothing to do with the printer or print server itself (I used "RyansNetPrint"). If it asks you for what type of Network card, just select Generic. Select the Printer driver for the printer you have hooked up to your NetPrint print server.
5.) Setup LPR & Queue Name. We need to reconfigure this for it to work. Ok, Now under Control Panel->Printers and Faxes - right-click on your newly created printer and hit Properties. Click on the Ports tab. Highlight your newly created printer port (ie, RyansNetPrint) and the Configure Port button. Windows defaults the Protocol to RAW. This won't work on your NetPrint print servers. You need to select LPR. Now, the one last thing you need to do is enter the proper Queue Name. The Queue Name format is: "PORTn" Where n is the Port Number (probably 1 or 2) on your NetPrint print server where you connected your printer cable. My NetPrint 50 only has one port, so my Queue Name is "PORT1". This is where I found the Queue Name information: "http://www.brooksnet.com/faq/210-04.html". Realize - I couldn't get my NetPrint 1000 to work properly. I think it uses different Queue Names. For instance, I tried "PORT10001", "10001", etc... to no avail. I gave up and used my NetPrint 50 since it worked easily with the instructions I just gave you.
Now hit OK, click on the General tab, and click Print Test Page. Walaa!
Hope this helps you. Took me a long time to figure all this out.
Ryan
PS. the arp -s command is only peformed on your local computer. When you ping your unit. When you reboot yoru computer, the arp -s record your created will disappear. So, they key here is - my wireless router remembers what IP address goes to what MAC address (because I pinged it). Now, if my wireless router is powered off - it forgets that information. So - if you reboot your wireless router / network router / switch / hub... you will need to reenter the arp -s command and ping your NetPrint print server again to assign the IP address again. Not perfect, but it works.
Posted on Jun 08, 2008
sandrew
  • 2961 Answers
SOURCE: Acquiring Address Problem
you will need to make sure that DHCP is enabled within the routers settings as this will tell the router to assign ip addresses automatically, then go to network connections, right click on your network card>properties>TCP/IP line>properties and tick 'obtain an ip address automatically', click ok, close window and restart pc.
Posted on Sep 24, 2008
  • 62 Answers
SOURCE: Linksys wireless camera--viewable if ISP uses dynamic IPs?
Ok, everything by default hands out dynamic ip addresses. If the camera is plugged into the network it will automatically pick up an ip address and you would be able to see it in your router config page. Try attaching the camera to the wireless network and then log into your router and look for attached devices. Let me know if you get stuck and where you get stuck.
Regards
Posted on Dec 20, 2008
  • 44 Answers
SOURCE: need to forward to static ip
access your modem i belive the ip address is
192168.0.1
if not then run an (ipconfig) on ur command prompt
use the default gateway on ur address bar
by default the username and password are both (admin)
if you set ur own up then im sure u know what it is
go inthe modem click on
(advanced) then on (ip static routes) and type in information that should take care of it !
rate my service please
july
thanx
Posted on Apr 21, 2009
SOURCE: New internet service now Savin C3030 won't work
how do you change the ip address on a hp jetdirect 170XC
Posted on May 04, 2011
Browser will not start: a popup says Cannot find DNS address
first off type ipconfig /all
should list dns servers
if dont click on network icon
go change setting go into ipv4
go back to ipconfig look gateway address this is key get this right
should be 192.168.0.1 or 192.168.1.1
if not u need these numbers
ipv4 should be set to autoconfig throw dont allways work
click change will alow u change settings
ok computer address first 3 segment say 192.168.0 has to match gateway last number say put 254
dns servers first 8.8.8.8
2ed 8.8.4.4
gateway must match gateway address u get has be same
or wont work
if u geting ip address of 168. this address meens u pc router not talking each other
so something u need check
this will work any os once this set pc should work
reboot pc
could also be a routeing probem in pc more so if micrsoft
this big probem
Feb 10, 2017 | Computers & Internet
Change ip address
Type cmd in Start menu-Run. A little black window will open. Type: ipconfig/all and Enter. It'll list your IP among other info.
If you want to change it: Start menu->Control Panel
Type "adapter" int the search box. You'll have "Network and sharing Center". Click "View network connections". Select "Internet Protocol version 4 (TCP/IPv4)" and click Properties. There you can change your IP settings.
Jan 17, 2014 | Lenovo IdeaPad Computers & Internet
Internet Problem
Networks using manually assigned IP addresses some time encounter problems/conflict when two computers happen to have the same IP address.on win7 go to network sharing center, on the left panel of the window you'll see/click on " change adapter settings" in the that window right click the local area connections and click on properties. in the net work tab click on internet protocol version 4 (TCP/IP4) then click on the properties button below to gain access to the IP Setting then select use the following IP address to alow you modify
May 22, 2013 | Computers & Internet
How do I find my ip address?
In windows 7, xp, vista:
START, ALL PROGRAMS, ACCESSORIES, COMMAND PROMPT
type in ipconfig,
ENTER,
IP IS SERIES OF NUMBERS
if you are using ppp with modem then will change every time you log in.
Mac OS X computer:
APPLE MENU, SYSTEM PREFERENCES, VIEW MENU, NETWORK, IN PREFERENCE, NETWORK PORT,
if you are connected it will be there.
OS X 10.4 OR 10.3:
APPLE MENU, LOCATION, NETWORK PREFERENCES, SHOW, NETWORK STATUS,
Sep 06, 2012 | Dell Computers & Internet
WIRELESS ACCES UNABLE TO FIND IP ADDRESS
It may be a connection problem.You can reset the modem and then you can check ip-address using Ip-Details.com
IP-Details.com, Search and find ip address's,domain name host's whois information including city, country, global latitude & longitude coordinates.
Aug 27, 2012 | HP Mini 1000 Netbook
I have just installed my Uniden UDW20553 Video Surveillance System. I was under the impression that I would have remote access to view my cameras from anywhere in the world on my laptop. Have looked high...
The only solution I have found is using Remote Desktop Connection and running the Uniden application. On my Iphone I found that using Pocket Cloud Remote Desktop (RDP Itunes download application) works best. You must also download a free application named "Pocket Cloud Companion" on the PC your Uniden software is running. Pocket Cloud Companion must be running for connection to made through 3G, Edge or Wifi networks. Also, you have to configure your remote connections by using your PC's IP address rather then the name of your pc, particularly if making connection on 3G network.
Feb 12, 2011 | Uniden Wireless Security Surveillance...
How come the http://192.168.123.254 address isnt working?
Find your computer's IP address : Windows 7, Vista, and XP, using the command prompt
  1. Click Start, and then select All Programs. Note: If this doesn't match what you see, refer to About navigation settings in Windows.
  2. Click Accessories, and then Command Prompt.
  3. At the command prompt, enter: ipconfig The IP address (or IPv4 address, if you are using Windows 7 or Vista) will be a series of numbers following the pattern xxx.xxx.xxx.xxx (i.e., 156.56.27.32).
Note: If you are using PPP with a modem at home, your IP address will change each time you log in.
Windows 7, without using the command prompt
  1. In the system tray, click the network connection icon and select Open Network and Sharing Center.
  2. To view the IP address of a wired connection, click Local Area Connection. To view the IP address of a wireless adapter, click Wireless Network Connection (Network Name).
  3. Click Details... . Your IP address will appear next to "IPv4 Address".
Windows Vista, without using the command prompt
  1. From the Start menu, right-click Network, and then select Properties. This opens the Network and Sharing Center.
  2. To view the IP address of a wired connection, click View Status to the right of Local Area Connection. To view the IP address of a wireless adapter, click View Status to the right of Wireless Network Connection.
  3. Click Details... . Look for the address next to "IPv4 IP Address".
Windows XP, without using the command prompt
  1. From the Start menu, right-click My Network Places, and then click Properties.
  2. To view the IP address of a wired connection, double-click Local Area Connection. To view the IP address of a wireless adapter, double-click Wireless Network Connection.
  3. Click the Support tab, and then click Details... . The window that appears will display the IP address.
Your IP address has to be in the 192.168.123.xxx range
The router must be configured to match your
Internet service. If you do not know your
Internet connection configuration, please
contact your Internet Service Provider (ISP).
By default, the router is pre-configured with
these settings:
• Automatically set IP addresses for
computers on your LAN (connected to the
router's ports 1-4). The router acts as a
server for dynamic host configuration
protocol (DHCP) and assigns IP addresses
in the range 192.168.123.100 through
192.168.123.199
• The default LAN IP address for the router is
192.168.123.254 with a subnet mask of
255.255.255.0
• The Internet service connected to the
router's WAN port uses a dynamic IP
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 26, 2010 | Asante FriendlyNET FR1104-G Wireless...
I have very good signl but enternet dosent openmy router belkin ;
unplug modem and plug back in in 15seconds. reset router also. this should help the system get the computer's ip address. Good luck
Sep 04, 2009 | Belkin (F5D7230-4) Router (587009)
I want all cmmands of router dx 1821
Please send all commands for configur & view of dax
Dec 04, 2008 | 2wire HomePortal 100W (1000-400026-000)...
Setting IP Address
Really need a bit more information, like operating system for a start, but here goes: I am guessing that your subnet mask is different from your printers. What address that you set are you getting from the printer? On your PC, what is your IP and subnetmask set to?
Aug 10, 2007 | Osicom NetPrint 1000 Print Server
Home Security Logo
386 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
