Question about Imperial IFS40 Deep Fryer
Ifs40 w/ new thermopile
Bought a new thermopile because pilot wouldnt stay lit...Now pilot will light but when I turn it on and it reaches temp.(tested at 200'f) the burners shut down correctly but 1/2 second later so does the Pilot, almost as if a safety trips and you can't relight the pilot for an extended period of time afterwards...Checked for leaks and found none..help???
  • 4 more comments
  • Iraj Sharifikhah
    Iraj Sharifikhah Jun 11, 2008
    when I turn it on after 20 second it turn back off even pilot it is s40
  • Anonymous Jun 15, 2008
    Same Problem
  • usmani Jun 21, 2008
    The pilot does not stay lit.
  • debndave73 Jul 11, 2008
    replaced the thermopile and everything goes out after onr cycle
  • Anonymous Oct 18, 2008
    Pilot wont stay lit. Pilot will
    light but when I turn it on and it reaches temp. the
  • amergy Oct 18, 2008
    Pilot wont stay lit. Pilot will light but when I turn it on
    and it reaches temp. the burners shut down correctly but 1/2 second later so
    Scholar:
  • 68 Answers
If the pilot shuts off within seconds of the burner, I strongly suspect you are having a problem with the hi-limit circuit. Check your wiring. The slightest unwanted grounding will cause the valve to drop out.
You also need to inspect the mounting of the bulb for the high limit. Make sure it isn't covered in debris. It should be clamped close, but not touching the heat exchanger. Grease needs to be able to flow on both sides of the bulb.
You'll need to test the switch with a meter or a jumper (for TESTING ONLY!). Remember, the hi-limit switch may be doing it's job and be the symptom, not the cause. But if the switch is tripping open prematurely, you'll need to replace it. (Part# 1177) Are you testing with enough oil in the vat?
Posted on May 31, 2008
Just replaced thermopile generator and pilot will not stay lit
Check the new thermopile with a millivolt meter and make sure it has the correct output not connected to the gas valve.If it does,then the gas valve is defective.Make sure to test ONLY the thermopile.If it does not generate enough millivolts the gas valve will not open.If the piliot is dirty it will not generate enough heat for the thermopile.Make sure you have a good,strong,blue flame at the pilot.You said the piliot will not stay lit?If not then start by blowing air back through the piliot where the flame comes out with compressed air.hopefully that will clean it well enough.If not you may have to take the pilot tubing loose from the valve and use compressed air to clean it.Make sure when you reconnect the tubing to the valve USE FINGERS ONLY to start tyubing or you may crossthread the tubing....and thats NOT a good thing.Good Luck.
Jan 16, 2015 | Williams Wall Heaters: 35,000 Btu/hr...
Pilot light wont stay lighted
Hi there.
Try cleaning the thermopile (cylindrical piece of metal behind the pilot) wwith a non-metal scrubbing pad. thermopile needs the heat of pilot flame to keep the pilot flame lighted as well as burners during operation.
Kindly check also if the gas has sufficient pressure.
Regards.
Jul 05, 2012 | Imperial IFS40 Deep Fryer
When you light the pilot, it stays lit, then you turn the the temp up on the thermostat, once it reaches its heat level and the cooking is done, turning off the thermostat also kills the pilot everytime,...
Thermopile generates 500 to 750 milli volts when heated properly, this small amount of electricity is used in energizing pilot and main valve coils of the gas valve for pilot and burner operation. Since the current is so small, it will not be able to flow on loosely fitted wire terminals or connectors, better check for this and tighten all wiring connections.
Also check if the gas pressure meets the standard pressure stamped on the unit's nameplate.
Jun 15, 2011 | Imperial IFS40 Deep Fryer
Pilot light keeps going out! Will not stay Lit.
Check if the the gas pressure is sufficient (as stated on unit's nameplate). Check if the hi limit device is good. Check also if the thermopile (cylindrical metal with two wires standing behind the pilot hood) is receiving enough heat from the pilot flame. The voltage generated by thermopile should be 500millivolts in order to open pilot and main valve. If there is 500millivolt on gas valve thermopile and the pilot flame does not stay lit, you have to replace the gas valve. If the thermopile is glowing red and the voltage generated does not reach 500 millivots, you have to replace the thermopile.
Jan 18, 2011 | Pitco Frialator SG18S Deep Fryer
Pilot won't stay lit
replace the thermocouple pretty easy looks like bare copper wire
Jan 21, 2010 | Imperial IFS40 Deep Fryer
Pilot light will not stay lit
use a torch to simulate pilot flame and read milivolt. if ok then make sure pilot flame is fully contacting thermopile. also make sure thermopile wiring connections are clean and secure.
Jul 16, 2009 | Imperial IFS40 Deep Fryer
Cant get the main flame on
Check the vent hole (plastic plug, not the screw) on the regulator between your gas line & the back of the fryer. If it is plugged, it wont fire & the pilot will go out when t-stat makes.
captrick
Jul 15, 2009 | Imperial IFS40 Deep Fryer
Pilot will not stay lit
When you try to light the pilot does the flame look nice and blue?If so i would replace the thermopile.It's a cheap part,goto 3wire.com for a part's break down.
Apr 06, 2009 | Imperial IFS40 Deep Fryer
Imperial IFS40 Deep Fryer Logo
364 people viewed this question
Top Imperial Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dan Webster
Dan Webster
Paul Carew
Are you an Imperial Kitchen Appliances - Other Expert? Answer questions, earn points and help others
