Question about Midland Two Way Radio
Where can I get a manual for a Midland Xtra talk GXT 650. One of these radios will not viabrate. Can I get a replacement or can I get it serviced.
5 Suggested Answers
Benimur
  • 6966 Answers
SOURCE: Midland gxt-850 gets HOT!
It is very possible that the terminal of the positive end of the bottom battery is shorting to the battery's body hence the heating up. If this is the case, then when you charge the radio, excessive current is flowing since the battery set has one shorted. Again this would cause heat buildup specially on the bottom battery and the charging terminals.
A possible solution is to check the bottom battery's positive terminal and ensure that it only contacts with the positive terminal of the battery and does not touch the battery body (which is negative).
Alternately (and perhaps more to your advantage), seek replacement of the defective unit considering it is new and therefore should be under warranty.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Posted on Dec 06, 2007
Neto
  • 123 Answers
SOURCE: programming problem
http://www.midlandradio.com/owners_manuals.asp
Try this site
Good luck
Posted on Jan 23, 2009
BillB-SA
  • 2761 Answers
SOURCE: is the midland gxt 650 compatable with the g12
All type-accepted GMRS radios operate on the same frequencies and use the same type of transmissions. Channel numbers are the same on most models, but check the channel/frequency chart in the radio's operating manual to be sure.
Bill B
Posted on Jun 02, 2010
  • 22 Answers
SOURCE: My Midland xtra talk lxt 320 is not working
Try replacing the batteries with a good set of alkalines. The standard batteries that come with these radios are of poor quality and get weak very shortly after purchasing these radios. The radios will have the symptoms you described when the batteries are weak. At least this has been my experience having these radios.
Posted on Sep 08, 2010
Midland radio manuals
Download your manual from here: http://www.manualslib.com/manual/103191/Midland-Gxt-850.html
Aug 12, 2014 | Midland Radio Communications
How do you change battery in Midland GTX450
Do you mean the GXT450 model, if so this manual is for the 300 upto the 450 and explains how to remove the batteries or battery pack.
http://www.manualslib.com/manual/103192/Midland-Gxt300.html?page=6#manual
Hope this helps
Jul 14, 2014 | HQRP Battery Replacement Fits Midland...
Donde puedo conseguir el manual para midland xtra gtx750
aqui esta el manual: http://www.buytwowayradios.com/products/midland/manuals/GXT-550-manual.pdf
Mar 04, 2014 | Radio Communications
I lost my manuall for my GXT walkie talkie
Look online for the manual, I found my refrigerator manual online,
Jul 04, 2012 | Midland Radio GXT760VP4 - X-TRA TALK GMRS...
Needing a manual for the GXT 756.
This was very difficult to find, but I found it just for you! Please make sure you rate my answer 4 thumbs up! Thanks so much for understanding, it would be a huge help to me. I would be forever grateful if you could do this for me. To view the manual you will need adobe reader, which you can get for free from http://get.adobe.com/reader/ You probably already have it though, please try opening the file first and find out. If you require some other manual, the file doesn't work, or this isn't what you are looking for PLEASE reply to my answer here and I will correct it for you. Here is the manual / guide please give it a few minutes the file is quite large:
The GXT 756 is a variation of the GXT 750, which is covered in this manual here....
http://www.buytwowayradios.com/Products/Midland/manuals/GXT-710-manual.pdf
Oct 16, 2010 | Midland GXT450VP4 (22 Channels) 2-Way...
My Midland xtra talk lxt 320 is not working properly. Once I turned the radio on it just started buzzing. For some reason I can't turn it off. It also says rx at the top right hand corner. On my another...
Jul 20, 2010 | Midland LXT310 2-Way Radio
Hello and Good day, Can you please help me get the manual for the GXT 400 X-Tra Talk? Thanks Emileo
just click on this link.. its a pdf file....
www.buytwowayradios.com/Products/Midland/manuals/GXT-300om.pdf
Jun 22, 2010 | Midland X-TRA TALK GXT400 (7 Channels)...
Is the midland gxt 650 compatable with the g12
Bill B
May 30, 2010 | Midland Two Way Radio
Midland   Two Way Radio Logo
303 people viewed this question
Top Midland Radio Communications Experts
AnyMHz.com
AnyMHz.com
eradiostore
eradiostore
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
