Check the temperature setting
Assure that there is enough room for air flow in the freezer or freezer
Check for air flow restrictions in vents
Test the temperature control
Clean the condensor coils
Check the door seals
Test the door switch
Test defrost heater
Test defrost timer
Test evaporator fan
Check for a clogged drain tube
Check for refrigerant leak
Freezer is too cold
Freezer is noisy
Hissing and popping is normal, it is the defrost heater.
Check that the freezer is level
Check the drain pan
Check the condensor fan
Check the evaporator fan
Inspect the compressor mounts
Freezer runs continuously
Defrost the freezer
Freezer starts and stops frequently
Check the outlet voltage
Test the condensor fan
Test the compressor relay
Test the overload protector
Test the compressor motor
Freezer does not defrost automatically
Test the defrost timer
Test the defrost heater
Test the defrost thermostat
Freezer has an unpleasant odor
Remove spoiled food
Clean freezer interior with a solution of h
Clean freezer interior with a solution of hot water and baking soda
Clean the door seals
Remove breaker strips and check for wet insulation
Water on floor outside of freezer
Check the drain pan
If you have an ice-maker, check the water supply hose going into and coming out of the water inlet valve
Water inside the freezer
If you have an ice-maker, check freezer and ice-maker for level
Hope this will help in solving the problem.....
