Question about Vivitar Cameras
The s/n that i have on my disc wont work when i try to use it in the setup wizard so i can put my pics in my pc
    Genius:
  • 1,142 Answers
Ivitar Entries
Posted on May 29, 2008
DELL LATITUDE D130 SCREEN WENT BLACK AFTER USING TV WIZARD HOW DO I FIX
You may need to repair windows. Insert your windows disc and boot from it. Choose repair windows.
Aug 05, 2016 | Dell LATITUDE Computers & Internet
I am trying to install my bitdefender antivirus pro 2011 the directions say to insert the disk and the setup wizard will automatically start but if it dont which it wont it says to double click on "my...
When you go to the CD/DVD does it detect the disc being there? If it does try to right click on the drive and choose explore then go to the folder that it tells you to.
If the CD/DVD still says CD/DVD then the disc they provided may need to be replaced.
If you see the disc and there is nothing on it it means that there are no files on the cd so take it back where you bought it and get a replacement.
Hope this helps!
Apr 16, 2011 | Dell Computers & Internet
Trying to copy some pics onto a cd to get some disc space but my drive wont recognise the cd rw
do you have a cd writer or rom drive is the first thing you have to check, if it's a writer then put the disc in first and it should give you an option to write files to cd accept then follow the the instruction to add your files, assuming your running windows. iif that does'nt work check to see if your discs are + or - it may be your wriiter will only accept one kind
Mar 26, 2010 | Compaq Presario V4000 Notebook PC
I can't open mastercook version 3 on PC
Compatibility Wizard
1. Open the Program Compatibility Wizard by clicking the Start button , clicking Control Panel, clicking Programs, and then clicking Use an older program with this version of Windows.
2. Follow the instructions in the wizard.
If you cannot install a program, insert the installation disc for the program and, using the wizard, browse to the program's setup file, usually called Setup.exe, Install.exe, or something similar. The wizard is not designed to work on programs that have an .msi file name extension.
To change compatibility settings manually for a program, right-click the icon for the program, click Properties, and then click the Compatibility tab.
Jan 03, 2010 | Sierra MasterCook Deluxe Low Carb...
Hp4300 series disc won't work with my new hp window vista computer my printer is a 4315v
Please perform the steps given below and check if yuo are able to fax
1. Open a MS Word Document.
2. Click File -> Send to -> Recipient using a fax modem.
3. Follow the instructions given in the fax wizard. Ensure that you select the HP all-in-one as the fax program.
Now check whether you are able to send the fax.
OR
Try setting up the Fax once again
=== Fax Setup wizard ===
- Double-click on the HP Solution Center to open it.
- Go to Settings --> Fax Settings & Setup --> Fax Setup Wizard.
Complete the fax setup wizard and then, try to fax
Vishwanath V U
May 19, 2009 | HP Officejet 4315v All-In-One InkJet...
Setup wizard doesn't locate wireless router.
Any old ethernet cable should be fine. The setup disc is generally used only for initial setup to establish communications between router and pc, and to also configure your internet providers settings. You can access your router from your pc by going to http://192.168.1.1 and you can change settings in the router from there instead of using setup disc. If you insist on using the setup wizard disc you usually have to set your computer's ip address to a specific number and possibly reset router to default state (see manual or http://www.linksys.com).
Jan 22, 2009 | Linksys Wireless-G WKUSB54GS Kit
I have a linksys wrt54g, and i'm trying to set it up but i managed to loose the setup disc and i was wondering if there was a way i could download the linksys setup wizard disc somewhere online?
If youre trying to setup the linksys router since you don't have the setup CD you can just call Linksys tech support and they can walk you through with the manual process to configure it, this the number for Linksys 800-3267114.
Hope that helps.............
Aug 14, 2008 | Computers & Internet
Where can i get the software disc from?
Have you tried to plug in the camera to the PC anyway. Windows XP or Vista should have its own pic transfer wizard or something like that. If that doesn't work see if you can view your camera thru "MY COMPUTER".
You shouldn't need any additional software, even if it came with it.
If you PC has a memory card reader then just pull card out of camera and put it in the PC.
Apr 02, 2008 | Cameras
Can't use camera w/new dell XPS 410 pc-wont fully install from disc
what operating system Vista? Remove the software and iplug camera in- Computer should recoginse it and put up Scanner/Camera Wizard
Jan 02, 2007 | Canon PowerShot A70 Digital Camera
Cameras Logo
5,638 people viewed this question
Top Vivitar Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
