Question about Yard Machines 158cc Push Lawn Mower #11a 034f200
Mower will not get any fuel when pushing the bulb, so will not start. is it possible there is a blockage in the line and if so how do i fix it? I have soaked the part overnight in fuel and tried again but still no fuel when i push the bulb.
  • Yard Machines Master
  • 7,482 Answers
Check your fuel filter if you have one.
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instrucitons you get with the carburetor kit.
If the mower/weedeater is over a year old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their orginal position before you started.
This is a FREE answer,Please rate me
Posted on Oct 12, 2010
Briggs and Stratton motor mower. Model "Sprint 375" two stroke.
pull the carby and clean it out
clean out the main jet and the blockage in the needle and seat area
check that the tank cap vent is clear
May 06, 2016 | Garden
Push mower starts then dies
Possibly replace air filter . Check fuel is actually coming through carburetor. Check there is no dirt in fuel line or fuel tank. If old "dead" fuel renew with fresh fuel. Check spark plug lead is in good condition. As mower starts and then cuts out problem most likely to be fuel starvation. Hope these suggestions help.
Oct 19, 2014 | Garden
My briggs and stratton 550e push mower starts and
If your using Ethanol Fuel... This goes for All yard equip. Weed wackers,blowers,chain, etc. Change fuel lines to ethanol safe. change fuel filter, push bulbs, (ethanol fuel destroys these making them soft / shrink and close up). Mowers, remove carb. bowl under carb. 1 bolt spray carb cleaner around, under and in bowl (may have to r&r needle if sticking) clean / replace air filters and possibly spark plug....All maintenance items.(Change Oil) If this doesn't do it.... there's more, this is the simplest start........
Aug 26, 2014 | Garden
Craftsman 550
Priming may not be the problem. First try putting some duct tape over the hole in the primer button. then try priming and subsequently starting it. This could indicate a need for a new air filter...I know it doesn't make sense, but it will probably be the answer to your problem. It was with mine although a different type of mower.
Jul 21, 2014 | Mtd 22" Yard Machine Push Mower
How do I fix my push mower with a Briggs & Stratton engine?
Its obviously a fuel starvation issue, so there is still some blockage in the carb, re move the carb and see if your frendly local dealer will clean it in there sonic cleaning tank, if not soak with carb cleaner and blow the jets through.
May 11, 2012 | Garden
MTD Briggs and Straton 22" Mower Wont Start Brand
You probably have dirt in the carburetor. Or, you may have water in the fuel. As long as you have spark, then there is nothing else that it could be. Unless you have taken it apart already; have you done this?
Jim
Aug 16, 2011 | Mtd 22" Yard Machine Push Mower
I have a JD 903 push mower that will only run when i spray starting fluid in carberator. what could be the problem.
Ethanol,dirty filter,or a crack in the fuel line or primer bulb.Clean the fuel system with spay can type of cleaner .Make sure to remove the fuel line,and inspect it for cracks.Make sure to clean or replace the in line filter.Check for more filters in the tank.There is also a screen inside the carb that may be clogged.Also make sure that the primer bulb is in working order.
May 15, 2011 | Mtd LAWN MOWER PART # 903-0382 AXLE...
Mower starts then shuts off
hey mate, it sounds like you have a fuel blockage weather it is in the fuel tank fuel filter or carby you cant tell, i recommend that you start at the fuel tank and flush it out make sure there is no debris on the filter screen then check for a in-line fuel filter you can remove this and back flush it with compressed air or replace with a new one, if it still does not work then you have a blockage in your carby, this is a bit more complex alot or small parts in there and i would recommend taking it to your local small engine dealership for repair...
Regards
Brad:)
Sep 21, 2009 | Garden
I have an MTD 3.5 hp Tecumseh lawn mower. The
WHAT KIND OF OIL DO I NEED FOR THE LAWN MOWER
Sep 17, 2009 | Mtd 22" Yard Machine Push Mower
Yard Machines 158cc Push Lawn Mower #11a 034f200 Logo
88 people viewed this question
Top Yard Machines Garden Experts
Phil Walker
Phil Walker
Dean Gruber
Tim Whalen
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
