Question about Gold Medal 2086 Popcorn Maker
The rotation works but the kettle is not heating. Is it replacable?
    Champion:
  • 248 Answers
For parts, web search - gold medal p60 parts diagram
Posted on Oct 07, 2010
3 Suggested Answers
narchoor
  • 22 Answers
SOURCE: kettle does not heat up
yes the coil that heats up needs to be replaced....
Posted on Nov 17, 2007
  • 8404 Answers
Check the wires to the heating element inthe kettle.
Posted on Jul 05, 2010
How do I improve the electrical connection between the base and kettle of my Breville Ikon?
The kettle should be considered unsafe for continued use. It has failed as the parts used are not suitably rated for the load they carry. The only safe option is to replace the kettle with a new one.
Jul 15, 2014 | Breville Kitchen Appliances - Others
Tip
Kettle stoped working...
After the warranty was over, our beautiful electric kettle just stopped working.
Toastess International Kettle
Model: TJK-103 120V, 60 Hz, 1500 W
Here is what I did to fix the problem.
Unplug the kettle and empty it completely.
Remove excess residual water inside.
Remove the bottom cover by removing the screws holding it.
Check the wires inside, the ones connected to the heat element.
On our kettle, one of them was completely burned off and disconnected.
So I replaced it with a heavy duty equivalent copper wire and sauder it in place.
Make sure that you do a good job installing and replacing the new copper wire.
Kettle is now fixed and working perfectly.
on Jan 23, 2008 | Toastess The Storm Electric Kettle
Why won't the kettle heat up to pop
The heating element needs to be checked to see if it has power and if it has burned out. To do this, you need a meter that checks voltage and resistance. To test it, locate the connections to the heating element and with the machine unplugged test the heating coil with the meter set to measure resistance. It should not be infinite. IF it is then the coil is burned out.
Jun 14, 2014 | Cretors Goldrush Popcorn Maker
Kettle does not heat up
Jul 05, 2010 | Waring WPM25 Popcorn Maker
Krups kettle leaks at base of pot
Unfortunately it's unfixable. A few recent Philips models do it as well and it's worst in hard water areas. Basically the cause is that a tiny bit of water gets into the bottom seam each time the kettle is used and leaves a residue behind when it dries out. Over time, the residue builds up and forces the seam apart so the leak gets worse.
All you can realistically do is hope that it's still under warranty and demand that Krups replace it, preferably with a different model. If they won't then you may have to exert whichever consumer rights exist in your country, but one way or another you need to stop using your kettle (it's dangerous!) and replace it with another.
May 21, 2010 | Krups FLF2 Cordless Electric Kettle
Krups electric kettle leaks
You cannot fix it when they split like that.
Apr 01, 2010 | Krups Stainless Steel Electric Kettle...
When I turn on to start heating the water ... it clicks on and off and now over time will not heat water. Power is coming to it... I have clean it in and underneath ... worked once and now again will...
Chances are the heating element has been fading until it can no longer operate. You can try to have the heating element replaced or replace the unit.
Nov 09, 2009 | Bravetti EK119H Electric Kettle
Red light's on... but no hot water!
OK, inside the unit there are three items, the heating element, thermostat, and thermal fuse.What has happened is the element got too hot and the thermal fuse opened.There is no reset button.In some cases you may run across a defective heating element or thermostat but its not common.The fix would probably be replacement of the thermostat and thermal fuse.For this, you would have to contact a small appliance repair center in your area.
Nov 06, 2007 | Kitchen Appliances - Others
Nov 02, 2007 | Benchmark 11065 Popcorn Maker
Gold Medal 2086 Popcorn Maker Logo
334 people viewed this question
Top Gold Medal Kitchen Appliances - Others Experts
Coss
Ted Maxwell
Tom Chichester
Are you a Gold Medal Kitchen Appliances - Other Expert? Answer questions, earn points and help others
