Question about Kenmore 23612 Progressive PowerMate Bagged Canister Vacuum
How do you get the cover off the vacuum so i can have access to the motor?
  • 171 Answers
If you are trying to get to the motor and not the bag Sears repair people have a special tool to remove the rubber seal and if you try it your self you will end uo ruining it or stretching it and if it does go back together when your done it wont seal properly and therefore it wont have sufficient air flow.
Posted on Oct 07, 2010
How to remove CLOG Riccar RAD.7 vacuum?
There is a clean out port on the back on the lower portion. Remove two screws to remove the cover to gain access to the air path from the floor to the bag. If this doesn't solve it you may have to remove the screws on the bottom which allow you to remove the cover of the nozzle assembly. There is a cover that goes from the floor to the direct air motor. Remove the screws to remove this cover which gains access to the air path and fan of the direct air motor. It's possible you may need to remove the direct air motor to clean out the fan if it has something stuck in there. This is not a job for the average person but if you are very mechanical you should be able to do it. If in doubt take it to your dealer. It is not very expensive to have done.
Apr 22, 2016 | Riccar Radiance Upright Vacuum Cleaner...
Remove hoover vacuum fan
I don't know what model you have but on most vacuums you need to remove the nozzle housing from the vacuum, remove the cover over the motor to gain access to the motor. Remove any screws holding the motor in. Remove the motor and take the screws out to allow access to the fan. Remove the fan, replace and put back together exactly as it was before.
Nov 09, 2015 | Hoover Vacuums
Accessing the motor on a riccar radiance
On a Radiance you will need to remove the screws going through the bottom of the vacuum nozzle housing which hold the cover on. Remove the cover and remove the screws holding the cover that goes from the brush roll to the lower motor. When you remove this cover tpyou will be able to see into the fan of the lower direct air motor to remove the obstruction. If it is in too far. You may have to pull the motorand open up the fan. This is not a hard thing to do but. If you have never done it, it can be a confusing job that may be best left to your Riccar dealer.
Mar 05, 2014 | Riccar 8955 Upright Vacuum
Electrolux ZUA3820P vacuum cleaner - how to access motor for repair
Tricky but you need to lift the slider cover off that adjust Min & Max speed and you will find 2 screws underneath, then you need to slowly take of plactic cover around the inlet hose and you will find another 2 screws
Apr 11, 2012 | Electrolux Vacuums
Vacuum is making a burning smell from the motor/fan.
Actually the screws to access the motor on Kenmore canisters are located underneath of the foot pedal that retracts the cord reel, and there's usually also two screws that underneath of the tool lid arms.
You may access the screws underneath of the cord reel by prying the foot pedal off of the vacuum. Simply put a flat head screw driver in between where the foot pedal and the vacuum cleaner meet on the top of the machine, and pry upwards with the screw driver. Once you remove the pedal you'll see the screws and have direct access to the vacuums motor.
If you are trying to access the power nozzle motor, here's a detailed step by step instruction tutorial that will walk you right through it.
http://www.fixya.com/support/t4499227-need_replace_belt_in_kenmore_vacuum
When a vacuum cleaner smells like something is burning, it can only really be one of two things. Either the rubber belt inside of the power nozzle is burning, or the motor is burning. If it's the belt that's burning, it will be a burning rubber type of smell, but if it's the electrical motor, it will be more of an electrical smell.
If you have any further quesitons, please feel free to reply using the clarification request tool here on Fixya. I'm always more then happy to answer any follow up questions.
If this was helpful, please rate my repair by clicking the thumbs up icons in the top right hand corner of this repair.
Thank you,
Chris J.
GoVacuum.com
Apr 11, 2010 | Kenmore 25614 / 25615 Progressive Bagged...
How is the motor cover removed?
Two screws at the front, accessed by opening the dust bag lid. Two screws at the rear accessed by prising off the on/off switch and rewind button covers.
Jan 05, 2010 | Electrolux Vacuums
I need to remove the top of the motor unit on a Kirby Generation 3 to access the motor area of the vacuum
First remove the back, then remove the handle assembly. Then pop off the plastic switch cover and it has one screw on the back you will need to take out, then there are two screws in the front of the body housing and two on the back that you will need to take out and then you are ready to take the top cover off and get into the motor area.
Nov 28, 2009 | Kirby Generation 3 Bagged Upright Vacuum
Kenmore whispertone 100 model 116. powerhead no
  • The motor / cord compartment cover must be removed to access the cord reel. There are four screws that hold the cover to the chassis. Two of the screws are found under the cord-retractor-foot-pedal on the top back of the canister. To access these screws the pedal must be removed. To do this, press the pedal down and look (from the top) for the four plastic clips that attach/hold the pedal hinges to the cover. There are two at the end corners and two in the middle. Using a long, thin flat-head screw driver (or similar instrument) press each clip to unhook/popout the hinges. Note: the foot pedal spring will also come out when the pedal is removed.
    The other two screws are found under the curved hinges of the vaccum bag compartment cover. To access these, lift the cover as if accessing the vacuum bag. Keep pulling the cover back until the hinges release from the motor cover. Don't worry, it is disigned to do this and will not break but it may require a little force. A long phillip-head screw driver will be needed to access and remove each screw
Jul 18, 2009 | Panasonic Kenmore Canister Vacuum Vacuum
How do I open my Kenmore Whispertone 12.0 to get to the cord reel
The other two screws are found under the curved hinges of the vaccum bag compartment cover. To access these, lift the cover as if accessing the vacuum bag. Keep pulling the cover back until the hinges release from the motor cover. Don't worry, it is disigned to do this and will not break but it may require a little force. A long phillip-head screw driver will be needed to access and remove each screw. Good luck. - Gary
Mar 30, 2009 | Kenmore 23313 Whispertone Bagged Canister...
Panasonic Vacuum MC-E450UK
Panasonic MC-E 450UK upright vacuum cleaner.
Just had this problem myself...........easy to get at it when you know how.
Panasonic UK wouldn't help me so I spent some time working it out..........here it is.
Remove the hose from its mounting storage at the rear (called hose clip) where the main body of the vacuum cleaner meets the base of the handle assembly. Remove the screw at the rear of the handle assembly which is behind where the hose 'was' situated and is located inside the deep recess.
Using the soft part of your clenched hand as a hammer, knock the base of the handle assembly at the front and it will slide backwards off the main body of the vacuum cleaner. Don't be scared, give it a thump and keep moving it backwards with a few more knocks.
Next remove the two screws at the front which hold the mains cable and on/off switch cover in place.
Finally looking from the rear once more, lift the plastic 'lug' at the top of the cover and which is part of the cover. This will now allow you to release the cover and pull it forward.
There you go! Told you it was easy!
Watch out for the funny little spring at the front behind the cover in the tiny plastic tube where it connects to the small rubber tubing as it could possibly try to escape.
You now have complete access in order to cut the intermittent part of the cable out and remove it from the 'choc' block.
Happy fixing!!
Jack.
Apr 07, 2008 | Vacuums
Kenmore 23612 Progressive PowerMate Bagged Canister Vacuum Logo
204 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
