Question about GE Refrigerators
THe repair guy was out today...(Freezer not freesing) He replaced two parts including a board.....this evening everything is not working. I have power....lights on...freezer is all damp (its empty)...and fridge not cooling...Arghhhh Help!!!
    Sergeant:
    Champion:
  • 351 Answers
I would call the repair guy back look like he missed something maybe compressor not running new board is bad or bad sensor
Posted on Oct 08, 2010
I need help with my television repair.
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Oct 19, 2015 | Philips Televison & Video
EVERYTHING WORKS WELL INCLUDING ICE MAKER >>>>BUT WATER KEEPS RUNNING OUT UNDER UNIT NOW FOR 3 DAYS WE HAVE A REPAIR GUY FROM SEARS COMING ON 24TH BUT DONT WANT WATER...
Hello, Thank You for using FixYa. I will be helping you today.There are not many places for water to come from. Is there ice on the bottom floor of the freezer? If so the drain in the freezer can be frozen causing water to leak out the front.The back panel in the freezer would have to be removed to thaw the drain line. Did you pull out the unit and check the water line for leaks at the hookups,and line itself? and last the drain pan remove the back cover and see if the drain pan has any visible signs of cracks and that the drain line is positioned over the pan. Water usually leaves a visible sign of where its leaking from. And for the record dont tell the repair guy you looked at it yourself if its under warranty some love to get out of calls by saying you touched it now its not under warranty.
Thank You and please rate my answer if it was helpful..
Jun 12, 2011 | LG LRBC20512
The freezer keeps freesing up and stops the air
Excuse me , but your fan works off 6-9 volts DC so do not try 120 volt cord . Your refrig has no defrost timer . It works off thermistors and a main control board .
Pull the refrig out and remove the 8 " x 10 " panel . Behind this panel , is the main control board . Unplug the refrig . Remove the BLUE plug from the board , with 3 larger wires going to it . Looking at the blue plug , the sequence will be wire1,wire2,space,wire3 . Get a short piece of insulated wire , and strip about 1/4 inch from each end . Insert 1 end into wire2 , and the other into wire3 . Plug the refrig back in . After about 3 min , look in the freezer , at the bottom , behind the crisper , look for a red glow . If no red glow , unplug the refrig , and reassemble the plug and cover . This no glow , indicates a shorted defrost heater WR51X10055 . It is also advisable to replace the defrost thermostat ( pt. number WR50X10068 ) when replacing the heater . To access these parts , you will have to remove the inside rear wall of the freezer . The heater , is at the bottom of the coils , held on with 2 screws , and the thermostat , is the 1 " cylinder , with a blue and pink wire going to it , clipped on the top left of the coils .
If you do get a red glow , then the # 4 thermistor is bad . This tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp and when to cycle off at selected temp.
May 26, 2010 | Hotpoint HSS25GFP Side by Side...
My NEW GE side by side fridge died today!
The display off because your power board is faulty. (Under gaurentee i hope. Need to call the warrenty repair guy out.
Sep 21, 2009 | GE Energy Star PDS22SIS Stainless Steel...
Fridge and freezer stopped working.Power still on (light on in fridge). Digital control for fridge and freezer shows straight line no numbers. Any suggestions?
The double dashes in your display are for one of two reasons. First situation would be would be "you turned the unit off". Press the up arrow on the feezer or fresh food control until a 4 is in each display. Second, if the control is locked out, the board has been scrambled or failed possibly from a power surge. Unplug unit for 30 seconds, and plug it back in and try to set control's for "4". If controls are still locked out, the board (12868513) needs to be replaced.
Jun 05, 2009 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
GE refrigerator side by side-6yrs old
I had this problem...my frige is gss20iejp and it was the defrost heater. Very easy to replace yourself if you're good with a screwdriver. Repair guy wanted 200 bucks. I fixed it myself for 40, but still had to pay the guy 30 bucks to come out. You have to remove everything from your freezer, shelves, etc...
Then take off the back panel.
Coils should be completely frosted up.
Defrost heater is at the bottom. It is metal. Should have 2 screws to remove and Conected by wires on either side, they pull out from the bottom, just tug them. Replace with new defrost heater...your problem will be solved.
If you have any more questions, email me jcoverload@yahoo.com and I'll be glad to help you out. I know how frustrating it can be if you don't have the funds to pay the repair guy and know you can fix it yourself with just a little advice. :)
Mar 25, 2009 | GE GSS20IEP Side by Side Refrigerator
JCD2389GES SIDE BY SIDE
hi thanks for the question if you say that the fan is not working replace the fan thanks the appliance doc
Aug 23, 2008 | Jenn-Air JCD2389G Side by Side...
MAGIC CHEF CTF1920ARA - Freezer works, Refrig. portion does not.
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 04, 2008 | Magic Chef Refrigerators
Thanks!
Glad to hear man! Thanks for the follow-up.
Mar 14, 2008 | Sony KP-65XBR10W 65" Rear Projection...
Bottom of Maytag Freezer Ices Up
We had the same problem; soon your other side of the fridge will start to not cool as well. A circuit board had to be replaced per the Sears repair guy. Cost was about $270 but our icemaker doesn't work so well still. The ice cubes are hollow and it doesn't churn as well.
Aug 16, 2007 | Maytag MSD2756G Side by Side Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
