Where do I buy a pper outfeed roll for top. the covering is coming off the old one. Canon 7130F
    Genius:
  • 1,218 Answers
Look in "Yellow Pages" under "copying" and contact your local CANON dealer.
Posted on Oct 10, 2010
How do you replace the thermal roll to get it to print
Make sure you are using thermal paper which is 57mm wide.
Open the printer cover. Lift the paper holder lever on top of the printer. Remove the old tube from the last roll if it is still in the bottom of the printer. Drop the new roll into the roll holder in the bottom of the printer. Make sure the paper is coming from the bottom of the roll rather than off the top as it unwinds. Pull the paper out the front of the printer and close the paper holder lever down onto the paper. The shiny side of the paper should be facing you as it comes out of the printer. If not, the paper will feed out blank during printing. If you are replacing the journal roll, slip the end of the paper into the slit in the takeup spool (black reel) and wind over a couple of times before dropping into place. Replace the printer cover and make sure the receipt comes out of the cut out in the cover.
Good luck.
Jul 11, 2015 | Casio PCR-T2000 Cash Register
Dismantle the Canon PC6 copier to remove paper fragments.
Try to dismantle it by the look, you need to remove leftside covers.
If you want I can send you service manual.
emma.servis@gmail.com
Jul 03, 2010 | Canon Office Equipment & Supplies
Canon Faxphone 15 user's manual
Plug the power cord it into the wall socket. Plug in the phone wire. There is an On/Off switch on the back. You will need some thermo-paper that comes in a roll, a roll like toilet paper, thinner than regular paper. The instruction of how to load it is on the top paper cover. Good luck
Aug 22, 2009 | Canon Office Equipment & Supplies
Canon 7130F copier. I just installed a new toner cartridge but it is printin out only a quarter of the page.
Hello sir; I believe the problem is te cartridge you purchased is refurbish one, please return to exchange.
Aug 11, 2009 | Canon NP 7130 Black and White Copier
Install web cleaner
open the front door. pull out drawer 1. remove the yellow cover, 1 screw. take out 2 screws, 1 front, 1 rear. remove old web. install new web,put the full roll on the right side with it feeding from top right to bottom left. if this is not installed correctly it will tear up the new web.
Jun 02, 2009 | Canon imageRUNNER 5000 Copier
Infeed Table leveling
Well, the infeed table is supposed to be lower than the outfeed table. This is how the jointer actually removes material to flatten a face or board edge. What is important is that the the outfeed table is level with the top of the cutterhead blades, so as you push material through the cutterhead, the outfeed table fully supports the workpiece.
The infeed table is supposed to be adjustable up and down to remove different amounts of material.
If both infeed and outfeed tables were aligned, no material would be cut (assuming the outfeed was aligned with top of the blades).
Feb 28, 2009 | Delta JT160 Shopmaster 10 Amp 6 Inch...
How do i take out the ink thingy
You will need: 1 Replacement ink roll - Porelon PR42 Ink Roll (This roll will replace the black and red ink all on one roll) Available at OfficeMax or other supply stores.
You must first remove the clear plastic cover on top of the calculator (where the tape comes out). Remove the old ink roll. You will see on the roll where it says "pull up". It will pop out easily. Replace it with the new ink roll, it will just snap in place. Replace the clear plastic cover. It should now be ready to go!
Mar 28, 2008 | Casio FR-2650Plus Calculator
Canon np 7130f keeps running
does anyone know where to get an owners manual for cannon np7130f online for free??
Jan 22, 2008 | Canon NP 7130 Black and White Copier
Error Light
This is the add toner light. Replace the tube of toner and will be well.
Dec 28, 2007 | Canon NP 7130 Black and White Copier
26 people viewed this question
jasbo
jasbo
