Question about Bissell ProHeat Turbo Deep Cleaner Upright Steam Vacuum
The cleaner drops debris onto carpet, doesn't extract water adequately.
  • Bissell Master
  • 43,501 Answers
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Posted on Oct 07, 2010
What products will remove dog wee stain from a carpet?
  • Dog liquid waste turns to crystals when it dries,, the only way to get the crystals out is with hot water extraction. If you use too much water you run the risk of it getting into the padding or the backing of the carpet and then it smells till it dries out. You need to get a carpet shampoo or cleaner that has enzymes in it.
May 05, 2017 | Vacuums
Detergent doesn't dispense.
Water will clean carpets but not very well. For the best results don't put any cleanser in your machine. Soap can clogged up the lines in your machine. When you have soap dispensed or or in the water in your machine you are squirting it onto the carpet and sucking it back up at the same time...the soap and water isn't on the carpet long enough to clean well unless you keep going over the same area many times. To clean better it's really important to vacuum thoroughly going slowly in multiple directions to get as much dry, gritty soil and hair and dust out as possible, it's easy to get these soils out when the carpet is dry if your vacuum is working properly. Vacuum, vacuum, vacuum.
Get a spray bottle or sprayer and put hot tap water in it, add the cleaning solution to the hot water and spray enough on the carpets to get the face fibers damp...let the hot water solution sit on the carpets 5 or 10 minutes and then use your machine to clean and rinse the soap, water and loosened soils from the carpet fibers. Repeat if necessary. Your carpets will be cleaner because you allowed adequate dwell time for the soap and water to work on the sticky greasy soils attached to the carpet fibers and stay clean longer because the soap is rinsed out of the carpets. Your carpet cleaning machine will last longer too because the water lines, pumps, spray jets, heaters, etc can't get clogged with soap gunk if you don't put soap in it. The method I'm describing is how the best professional carpet cleaners clean carpets. Hiring a quality carpet cleaner cost more up front but the carpets may stay clean two or three times longer, saving a lot of money in the long run. If you clean your carpets using this dual process method you may do a better job with a small portable home or rented cleaner than hiring the average carpet cleaning professional who is trying to give you the lowest price.
Mar 06, 2017 | Vacuums
My hoover max extract dual v stopped sucking up the water on just its second use. Any ideas on how to fix this problem?
The most likely problem is there is a restriction somewhere or a suction leak. Check to make sure you have good suction where the waste water tank fits down onto the machine. Make sure the lid is on the waste water tank and follow the flow of suction from the machine through the waste tank down to the floor and look for debris clogs or any area where there may be a suction leak. If you have good suction coming from the machine the problem has to be somewhere between there and where the water is being sucked off of the floor.
Oct 24, 2013 | Hoover MaxExtract Dual V Carpet Cleaner...
Cleaner wont release or **** up water off the floor
There are a few different problems this could be. Usually when someone says it won't extract water off the floor it is because it is not squirting any water. If it is not doing either then you have more than one problem. You can try to pour some water from a cup onto the floor to see if it is extracting water from the carpet. water not squirting could be clogged jets. Look underneath at the red jets and make sure they're not covered with hair or dirt. You can remove and clean them. It could be the pump is not working properly. On some Bissel units the pump has a cogged belt that turns the brushroll. If sometihing gets caught in the brushroll it can strip the teeth off of the pulley on the end of the pump which means you have to buy a whole new pump. Another problem I occasionally see on this unit is the pump gets full of soap suds and will not pump water. Sometimes I can get it working agian by removing the lines and flushing out all the suds.
Jul 18, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
Will not **** the water off the carpet.
If the carpet cleaner won't "Extract" water from the carpet, try using the upholstery / hand tool. If you have suction there, your selector switch / knob is either in wrong position, or broken. There may also be a tear in the hose on the inside of the cleaner, or the waste tank is not sealing well.
Jun 13, 2010 | Bissell 1699 ProHeat Clear View Upright...
Hoover SteamVac isn't extracting solution from carpet. Motor runs and the brushes weren't turning at first but do now
That vacuum is fine on liquid extraction but often gets clogged by debris when it hits a solid. It would be better to do the clean with the steamvac then follow it with a wet/dry shop vac to be sure you got all the water. I say this because the vac built into that hoover is way too easy to clog.
Mar 13, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
My Bissell all pro does not extract water from carpet
heatman101
zcvzcv
Jul 12, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
Instructions or manuel was not included.
i downloaded the manual for your machine, but not sure how to access it for you,but i do know about the problem, the tank that sits down on the front of the steamer and it has 2 clips that you push in to lock the tank is where your dirty water is put in when you are cleaning your carpets. the tank above ,the one where you put your solution and water in is what is used to shampoo your carpet. on the handle is a trigger (black) button ,this is the button you push in to release your solution onto your carpet. release the button to extract the water from your carpet,moving your steamer in a back and forth motion. the trigger button is the only button on the machine and is only used to put the water /cleaner located in the upper tank on your carpet, releasing this button and moving your steamer back and forth over the shampooed part with extract your dirty water into the tank that sits below the solution tank. go on www.hoover.com and click on carpet cleaners ,scroll down to find yours and click on manual. and the owner manual will download and you can print it out for future reference, i hope this will solve your problem, sandy
Nov 29, 2008 | Hoover F5810 SteamVac Upright Vacuum
My G series kirby carpet cleaner will not **** up the water or foam very well
The Kirby shampooer deposits the foam onto carpet,and works it into the carpet with the shampooer brushroll.After the carpet is dry,use the vacuum itself to pick up the dry foam and dirt.The Kirby Shampooer is not an extraction shampooer
Nov 14, 2008 | Kirby Vacuums
Bissell ProHeat Turbo Deep Cleaner Upright Steam Vacuum Logo
21 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
