Question about Samsung Office Equipment & Supplies
I have a Samsung SCX-4826FN and I keep getting this message each time I print: Out/Bin full, Open/Close Door. How can I fix this?
SOURCE: paper jam --samsung SCX-4828FN
i found that paper jam was in the middle of the mechine. i opened the front door and removed papers.
Posted on Sep 18, 2009
funkyagain
  • 24 Answers
SOURCE: lsu error on SCX-4725FN samsung printer
The Laser Scanner Unit or LSU is what writes to the surface of the drum. The glass above the cartridge inside the machine could be dirty. The mirror motor in the LSU could be bad or needing cleaned so it spins better. The Laser diode could be bad.
Call the ASC, the mainboard is malfuntion and need to be replace.
I hope this helps! :)
Posted on May 03, 2010
SOURCE: door open , close print cartridge access door
I have an HP Officejet 6210 All-in-One. When you open the print cartridge access door there is a black toggle switch that needs to be in the depressed position to let the unit know the door is closed. Something was missing from the topside of the "door" so the switch didn't close. I simply stuffed in some foam material to close this, and the unit operates normally. You will need to remove this when changing cartridges, then replace it again.0a64d2c.jpg
Posted on Sep 08, 2010
  • 360 Answers
SOURCE: My Samsung SCX-4521F show message: Open
you have to replace heater bulb and thermister.it is located @ your heater roller section.
Posted on Jan 27, 2011
let me help
  • 196 Answers
SOURCE: ON Samsung SCX 4216 Error: Paper
Hello! Welcome to FixYa
Paper jam
means their may be small bit paper jam in side
There are some "micro-sensors" that detect a paper jam. There will be tiny piece of paper, or a lump of dust, inside those sensors, thus "tripping" the sensor and saying you paper jam.
To solve it
Open printer cover and check to make sure no paper or foreign objects obstructing the printer feeder
If you become sure that now really there is no paper, dust or foreign objects then
Turn the printer off, and disconnect the AC power-cable. Open the printer cover & now give the printer a "blow" by compressed air.
more over roll the toner gear check if its not obstructing to something .
secondly try to cut/delete any pending print jobs thats right next to clock on your dektop.then restart PC and then plug the printer and PC on see if it works.
If still problem exist then, post your query here ,
I hope this solution will helpful for you
Anymore help regarding the issue, I am here to help
Thanks
Posted on Apr 05, 2011
Paper Jam 0 , OPEN/Close Door Message Samsung SCX4100
seems as if the motor responsible for taking in the paper has stopped working and may need to be replaced
Dec 26, 2016 | Samsung SCX-4100 All-In-One Laser Printer
I HAVE A SAMSUNG PRINTER SCX-4623 THE MESSAGE KEEPS ON SAYING DOOR OPEN CLOSE DOOR , TRIED EVERYTHING BUT NOTHING WORKS
Dear
The front door right side there is a lever found when it is opened the lever should close the micro switch inside and the door is locked with another short lock (near the long lever). If door lock broken then the micro switch push the lever and door not closed.
the basic problem with the micro switch and related mechanical alignment.
Thanks.
Feb 26, 2015 | Samsung SCX 4623F - Multifunction fax /...
Error message
low heat does not allows u to print , wrong error
May 07, 2014 | Samsung SCX4826FN AllInOne Laser Printer
Scan scx 1400 samsung printer
Here download the Drivers for your Operating system here.
http://www.samsung.com/us/support/owners/product/SCX-4826FN/XAA
Apr 09, 2014 | Computers & Internet
Down load the drivers for your operating system here.
Samsung SCX-4826FN/XAA toner exhausted
You need to replace the toner cartridge with the following part number MLT-D209L or MLT-D209S or MLT-D2092L.
Take these numbers to your local cartridge shop and they will be able to supply them.
Regards GM
May 27, 2011 | Samsung SCX-4828FN All-In-One Laser...
My Samsung CLX-3175 printer will not print - the message is replace/install toner waste bin. I have emptied the waste bin of all the ink and replaced it and still the message will not go. I have a stack...
open the cover and now remove the waist toner container (you say it is empty) check the conection to the drum unit sometimes if the waist toner is verry full there is a pille of toner closing this connection, now clean it and all the sorounding from the toner and mount the waist container back in his possition, close the front cover and try, it should work now.
Apr 27, 2011 | Samsung CLX-3175FN Color Laser All-in-One...
Problem with printing
CRU Fuse Error The toner cartridge is
not installed correctly.
Install the toner cartridge
correctly. See “Replacing the
Toner Cartridge” on page 8.4.
www.zinetic.o.uk
Sep 04, 2008 | Samsung SCX 4521F All-In-One Laser Printer
341 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
