Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Kitchenaid Ice Dispenser Auger not turning
I have a 7yo Kitchenaid side by side fridge that the ice dispenser stopped working on. I ordered an ice dispenser auger motor and a solenoid assembly to repair it myself. The replacement parts arrived but the gear box is not the same as the one coming out of the unit. The motor is the same and so I switched it out and remounted the unit. It is still not working and I am at a loss. When I press the button, the switch jumps into place and it sound like it is trying to turn but nothing happens. This gear box seems to turn fine by hand but not when installed. Any ideas?
Thanks,
Theresa
    Genius:
  • KitchenAid Master
  • 1,689 Answers
There are a number of variations in their products. The reason is that they do different production lines for some of the same models. Many of the manufactures do this for a number of reasons.
The best way to service these products is to call their factory service. The service rep has all the necessary factory schematics, engineering information, and the resources to have the proper parts and replace them. When using the factory service, all their work is gauranteed. When you fix it yourself, you are on your own.
Jerry G.
Posted on May 29, 2008
How do I replace a plastic auger with a metal auger in a Kenmore side by side?
Fridge Dispenser Auger Drum Replacement - Whirlpool ...
? 4:56
www.youtube.com/watch?v=-fUJlQ1BQcs
Apr 12, 2013 - Uploaded by RepairClinic.com
The most common reason for replacing the dispenser auger drum is when ... Whirlpool, Kenmore, KitchenAid, Roper, Estate, Maytag, Crosley, ...
Sep 23, 2015 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice dispenser door open. Ice freezes at bottom of bin, rendering the dispenser useless
If the ice door is open that will need to be repaired first before solving the ice melting and stopping the ice auger from moving. What may be happing is the ice door stuck open causing warm moist air from outside the refrigerator to be drawn in covering everything with frost and possibly locking down auger and causing the refrigerator to run continuous. What is the model number found around the fresh food section? Thanks Sea Breeze
Nov 16, 2012 | KitchenAid Architect Series II KSSO42QTX...
Ge Profile Stainless Steel 26 ft Refrigerator ice maker dispenser
try pulling out the ice bucket, remove all ice and look for signs of damage on the auger mechanism... most of the time the ice tends to clump up and that prevents the auger from moving freely.
Mar 24, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
Whirlpool ed5gvexvdoo side by side When using the ice dispenser (cubed or crushed) it will not dispense. I have pulled the ice tray and the motor for running the dispenser arm runs. I have emptied the tray...
this maybe a problem with you auger motor may be stripped.open the door remove the ice bin.then hold the metal u shape auger arm and try to turn it by hand or have some one try to dispence ice if the u shape braket turn easy ny hand or if it stops turning when being held replace the auger motor.i hope this is some help,good luck you may also have to replaced the ice bin.
Jan 22, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool side by side GD27DQXFW01; ice cubes are not dispensing
We will need to check the voltage at the auger motor while depressing the dispense switch. If all the other features work on the dispenser panel while I would consider checking the voltage going to the motor. Some auger motors are in areas where water causes the voltage to be shorted by constant moisture. We will need to remove the panel and simulate what you have done on the outside but this time we need to see if the voltage has been altered or if the auger motor itself is defective. Sea Breeze
Oct 10, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Kenmore side by side fridge - ice dispenser stopped working
You might check out this site and ask a question. They have drawings on many of the fridges and I have bought many parts from them.
http://www.appliancepartspros.com/partsearch/
Jul 28, 2009 | Refrigerators
Ice maker will not dispense the ice
The auger motor and coupling in the rear may be frozen and won't turn.
Remove the ice bin.
Place a screwdriver or similar device in the forks of the auger and twist counterclockwise till it moves. The replace the ice bin and try again.
It will be difficult to move.
If that does not work. Turn off the fridge and use a hair dryer to hrat the auger gear and motor till it frees up.
Mar 23, 2009 | KitchenAid Superba KSRS27CN Side by Side...
Water and Ice does not work. Ice dispenser does not even turn.
There is a motor that turns the auger for ice at the door but it has nothing to do with the water at the door. If you are sure the water line at the door isn't frozen then I'd suspect the control board isn't working (no power to the motor or the water solenoid valve). These diagrams may help you see what's inside so you can look deeper into the issue. If you can, try turning the ice auger by hand (dump all the ice out first). Also check that melted ice didn't re-freeze and bind up the auger, etc. If you can leave the fridge off a day with the freezer door open that would melt any frozen water line, just to be sure that's not the problem. http://www.partselect.com/Schematics/Frigidaire/6VV40M4Y.gif http://www.partselect.com/Schematics/Frigidaire/P3WRBSB1.gif
Jan 14, 2007 | Westinghouse WRS3R3EW 33" 22.6 Cu. Ft....
Ice dispenser not working
Scorpio, remove the ice bin itself, dump the ice and see if you can move the bin auger by hand by turning the actuator in the rear. If the bin is ok, with the door open and the door switch held in see if the auger motor is turning when pressing the ice lever. If it's not turning the next logical step is to see whether the auger motor is getting voltage when calling for ice. Make sure the door switch is closed. The part number for the auger motor on the posted model is wr60x0202. Hope this gets you going..Catriver.
Jul 23, 2006 | GE Profile 26.6 cu. ft. Side-by-Side...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
279 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
