Question about Apple 24" iMac Desktop
How do you open the case to install RAM? - Apple 24" iMac Desktop
    Guru:
  • 166 Answers
Instructional steps
  • RAM
  1. Determine what kind of RAM you need, and whether your computer has enough open slots to hold it. The new RAM should match the existing RAM's specifications and configuration.
  2. Shut down the computer and leave it plugged into the surge suppressor.
  3. How do you open the case to install RAM? - install-ram-1.3-120x120.jpg Disconnect all peripheral devices, such as the monitor, from the computer.
  4. install-ram-1.4-120x120.jpg Remove the computer cover.
  5. Ground yourself to the computer with professional grounding equipment like an anti-static wristband or hold a metal part of the chassis.
  6. Remove any cards or internal components necessary to give yourself unobstructed access to RAM sockets.
  7. Pick up your SIMM (single in-line memory module) or DIMM (dual in-line memory module) by the ends without touching pins or chips.
  8. install-ram-1.8-120x120.jpg If adding a SIMM, find the notched end and turn the SIMM so that it is parallel to the existing RAM card(s). Insert the SIMM into the socket at a 30-degree angle. If adding a DIMM, insert the DIMM straight in so that it is perpendicular to the motherboard.
  9. Use slight pressure to keep a SIMM from backing out while rotating the module to an upright position perpendicular to the motherboard.
  10. Make sure the small holes on each side of a SIMM fit into holders
  11. install-ram-1.11-120x120.jpg Feel or hear retaining clips lock a SIMM into the socket; close the side clips on a DIMM.
  12. 1 Gently try to pull the module out to ensure it is locked in position.
  13. Replace all internal components.
  14. Leave the cover off and reconnect the monitor, keyboard and mouse.
  15. Turn on the computer.
  16. Check the amount of RAM by right-clicking the My Computer icon in Windows and choosing Properties. On a Mac, use the About this Macintosh command in the Apple menu.
  17. If you don't see the right amount of RAM, turn off the computer and try "reseating" the SIMM or DIMM (take it out and put is back in) and reboot. If that doesn't work, call a technician.
  18. Shut down the computer and disconneHow do you open the case to install RAM? - install-ram-1.19-120x120.jpg />
  19. install-ram-1.19-120x120.jpg Replace the cover and reconnect all the peripherals.
Posted on Oct 08, 2010
How to install ram
Please shut the pc and;
remove all cables.
Open the case and locate the RAM slots on your motherboard. If u are still finding difficulties refer to your manual.
Thanks
May 31, 2011 | HP Compaq Presario SR1502HM PC Desktop
How do i install ram on my compact presario sr5223wm
Remove the computer case screws, open the computer case look for the ram slots on the motherboard comparing the ram you bought as to what to look for. Insert the ram into one of the empty slots pushing down until you hear / feel it click into place.
May 11, 2011 | Computers & Internet
How can I ad an additional stick of RAM (2 GB) on my TC4400 tablet? Where the additional slot is? I didn't find it. Thank you, Benjamin
There should be a cover behind the laptop, unscrew these tiny screws and the back cover should open. Then you want to located where the rams are at. In some case the ram slot is already being used by the original rams and you need to take these out to install the new ram. Before hand, make sure your laptop support the correct type of the ram, in your case it will support ddr2 sdram up to 4gb. So pretty much once you locate the ram slot after opening the back panel... then just install it.
Jan 14, 2011 | Compaq tc4400 Tablet PC (RL875AW#ABA)
I want to increase ram, what do I get
First, you have to find out the max of ram that you can add to your pc. Then go to the website crucial.com and run a test where it will tell you what memory and how much you can add. If you decide to purchase the memory and after you recieved , open the case and locate the empty slop where the memory is going to be install. It should be the small slots not the white big ones. Then carefully open the case from the memory and then put i on the slot of the pc. Turn the pc on and then see if it recognize it
May 24, 2010 | Systemax Tiger (SYXS-DC-1000) PC Desktop
Can I install one (1-gig) memory stick instead of 2 match pairs (only have one) this is to replace two 256 sticks?will it preform at 1 - gig memory
Yes.
The Maximum Total Amount of Ram Memory is 2GB.
(2048MB)
The Maximum Amount for EACH ram slot is 1GB.
(1024MB)
Ram should be installed in Slot 1, when using just one stick of ram.
This is the ram slot closest to the Processor.
The Processor reads ram memory that is installed in Slot 1, first.
This is Dell Support, and the main support page for the Dimension 3000 desktop computer,
http://support.dell.com/support/edocs/systems/dim3000/en/SM/index.htm
In the list left-click on - Technical Overview
Now click on - System Board Components
Number 1 is Slot 1.
Note*
Your body carries Static electricity. Static WILL fry out (Short Circuit) the delicate computer hardware components inside a computer.
Work on a table.
After you have opened the computer case, and BEFORE you remove that ram module from it's anti-static protective bag, TOUCH the metal frame of the open computer case. (Power unplugged from computer)
This will relieve your body of static.
Ignore the above if you are already aware.
May 21, 2010 | Dell Dimension 3000 PC Desktop
Addrammemory
If your desktop is a Dell Dimension 2400 then this is the technical specs for the RAM.
Memory
Architecture
DDR SDRAM
Memory connectors
two
Memory capacities
128-, 256-, or 512-MB
Minimum memory
128 MB shared DDR SDRAM
NOTE: Between 32 and 64 MB of system memory may be allocated to support graphics, depending on system memory size and other factors.
Maximum memory
2 GB
Memory type
PC2100 (266-MHz) or PC2700 (333-MHz) DDR SDRAM (non-ECC)
The RAM modules are held in place with clips on the ends of the RAM modules. Push each clip down and away from the RAM modules and the RAM module will lift up.
To install the RAM modules, the RAM modules have a notch and can only be installed one way. Place the RAM module in the memory slot and push down until the locking clips swing up. You may need to push the clips into the sides of the memory modules to lock and secure the memory modules.
The price of the RAM depends upon the size of the RAM you want to install. I suggest a minimum of 1Gb of RAM and the maximum to can install is 2Gb of RAM.
Check the prices of RAM on the Internet and in the computer stores.
May 22, 2010 | Dell Dimension 2400 PC Desktop
Want to install 1G ram internally
ok,
Open your Laptop/Desktop and look for existing RAM slot.
In the laptop it is usually underneath, so flip the laptop over and unscrew a location where it says RAM/Memory.
Desktop, open the case and it should be failry obvious where it is on the Motherboard.
If you have nver replaced RAM i would recommend getting some professional help.. i.e. making sure you buy the correct type of RAM in the first place.
I hope this helps, don't forget to rate my solution.
Thanks.
Mar 16, 2009 | Compaq Evo N610C Notebook
How do I instal two 1gb ram cards into packard bell 1508/2 pc
You need to take the pc apart.
open the case.
then you need to find the memory slots
Remove old modules or place new ones in if there is room.
Jun 27, 2008 | Packard Bell Computers & Internet
INSTALL A 2 MB RAM FOR MEDIAN PC MODEL 8030..
Most RAM today, is plug and play, would you know the specs of your motherboard?
Installing RAM, is something you should get someone at least semi experienced with Hardware to do, if you are then open your case, and you will notice 3/4 slots, one or more of these slots will be filled with RAM already, Providing you have enough empty slots for your new RAM, you can leave the existing ram installed or remove it - your call.
There are many helpful images here
It is basically inserting the RAM, the correct way around and clip it in. In the case of Installing another hard-drive or replacing your old HD, you will have several cables, The main ones are the power, and data pathing cable. Illustration here
Be careful not to disrupt any other devices/cables inside the machine and it should be good to go.
Mar 27, 2008 | Computers & Internet
Apple 24" iMac Desktop Logo
82 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
