Question about E-Machines T2893 PC Desktop
Computer is dead. When I press the on button, nothing happens. It is plugged in. I opened it up and saw a green LED on.
  • 3 Answers
If power supply! is not dead then try that..
turn on your computer without hard disk and cd dvd rom!!!
disconnect the power plug of hard disk and cd dvd rom
The hard drive must be connected to the motherboard with a tablecloth
also CD DVD Rom
disconnect them and trun on ur pc if all is ok and if u sew something in ... Saisissez du texte, l'adresse d'un site Web ou importez un document ? traduire. Annuler ?couter Device screen like informations about bios, then maybe problem in ur hard disk :-)
Posted on Oct 07, 2010
  • 2,229 Answers
It is entirely possible that your power supply has died. FYI, I just got a similar computer in the shop. Same symptoms. Turned out the power supply had failed and it also blew out the motherboard. Hope that yours is just the power supply!
Thought I should add more detail about what the laptop is doing. The laptop sat for a long time with a dead battery, because the power supply low voltage wire got chewed by one of our puppy's when it was...
from the web -
1 Removed the battery
2 Removed the AC power
3 Plugged in the AC power again
Note:- At this point the light from flashing amber light to solid green indicating AC Power
4 Plugged in the Battery
Note:- Solid green AC power light and Amber charge light
Oct 30, 2013 | Toshiba Satellite C655D-S5084 Laptop
The unit appears to be dead but the green and yellow channel LED's continuously flicker.
I am guessing that the lights are near the network cable plug? This simply shows that there is a signal on the network cable that is plugged-in. The laptop may be dead. Is there a light on the power supply? If you remove the battery, plug the power in and press the power button, what happens?
Dec 15, 2012 | Computers & Internet
Viewsonic N3752w LCD TV: plug in, red light goes on, press button and green goes on but then off before any picture; seems dead, no red light or green and nothing happens when press button again. If I...
We have the same problem with ours. I'm suspecting it's the power supply board. I'm going to order a new one, swap it. That should fix it, I suppose.
Oct 04, 2010 | ViewSonic N3752w 37 in. LCD TV
Gateway yellow power button, nothing starts, no fan, nothing. opened up computer and see mobo led light is lit. newton ps has a test button. tried to test with various components plugged in and the test...
Power supply has several voltages. Just because the 5v power is active doesn't mean all the voltages are OK. You need to have the power supply tested for 12v and 3.3v. A quick test is to unplug all the wires from the power supply. There is a single green wire on the motherboard main plug. Connect (use a bent paper clip) that green switch wire and any black wire. Plug in the power supply and it should run (fan starts)
Oct 26, 2009 | Gateway (ATX-300-12EB3) (ATX30012EB3)...
Dead sharp pc-ax40
You can try reseating the memory and the hard drive if you can get to it, but it sure sounds as though the motherboard is shot.
You can take it to your local computer repair shop.
Good Luck.
Mar 15, 2009 | Sharp Computers & Internet
No Power, Cannot open
contact ur dealer..its hardware problem!
Dec 27, 2008 | Compaq Presario 700 470024-192 Notebook
Power light blinking
That is because either you screen is dead(test by connecting a exteral monitor) or you motherboard is dead and I have been seeing many dead motherboards as of late
Sep 19, 2008 | Toshiba Satellite A45-S250 Notebook
Acer 3680 will not turn on at all
take out the memory from bottom, and battery, plug into wall, and try again..
Mar 20, 2008 | Acer Aspire 3680 Laptop
E-Machines T2893 PC Desktop Logo
61 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
