Question about Philips Televison & Video
My phillips 1080 37" tv was working fine then all of a sudden the sound starts to turn itself up, no jam in remote control
  • 8,596 Answers
First reset the television by unplugging it from the wall outlet - see if problem persists. If the problem does persist, then go to www.usasupport.philips.com and enter in your exact model number. go to the software and drivers section for your model. If your model has a software upgrade, then a software upgrade should resolve. You will just need a USB memory stick to get the file from your computer to the television - remember, only transfer the file called "autorun.upg" or whatever to the memory stick, not the entire zip folder.
If the model does not have a software and drivers section, it is b/c the TV is lacking a USB port. In that case, check the sound menu and turn off delta volume and AVL - see if sound behaves normally after that.
If none of the above works, then call Philips to get it serviced.
Posted on May 29, 2008
My remote control for my Pro View TV suddenly quit working. Is it fixable or, if not, how can I get a new one?
The replacement batteries could be defective or installed incorrectly. If the remote cannot be revived, you can search online for several providers of replacement OEM remotes.
Feb 28, 2015 | Televison & Video
Hi there I have a 20" Humax IDTV - LU20-TD2, it
Look for any jammed buttons on the remote or on control panel. Try changing the input device to something that you are sure, works.
Jul 29, 2012 | Televison & Video
Westinghouse tv turns off with rmote but cannot be turned on unless button on tv itself is used
How old are the batteries in the remotes? The on/off signal from the remote is the same. There is some lattitude in the IR reciever module for what it accepts. Low battereis may be shifting the signal's frequency or light intensity enough for it to not be recognized.
If sunlight is failing on the sensor or the remote's IR emitter, that can cause interference. Other IR devices can also interfere with the IR signal such as a "Remote Extender" being used for something else.
It may sound odd, but if your remote was working one day and not the next- was the room rearranged? If so, look around for possible sources of interference blocking the beam from the remote, or shining or reflecting light onto the IR reciever module in the set.
Dec 30, 2011 | Westinghouse Televison & Video
My KLH 5100 System worked fine for nearly a year. Very suddenly the remote control seems to have no effect on the unit. It doesn't switch it on, or off, or change the volume...nothing. I changed the...
Read this procedure to possibly fix the remote:
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12963989782821
They also sell replacement remotes.
Zoom in on the picture of the original remote provided on the site (or look at your own) and get the actual remote model number.
or check eBay: search for "(model of the device or the remote) remote", check the 'include description' box. Usually cheaper than the vendors.
Sep 08, 2011 | KLH R5100 Receiver
I have a phillips 42 inch plasma televison and i cannot get any remote control to work on it, i broke the origial control a hwhile ago and replaced with a univeral control which set up fine, after a few...
it may have a problem within the tv itself not on the remote control. its problem maybe in the system control i.c that control the infrared remote receiver
Feb 04, 2011 | Philips Televison & Video
Just did. Where did it go? Remote control does
Not the remote,it is the tv itself.Now,turn on the tv it have a flashes of pictures only a few sec. than dies and have sound left only?Yes,than the tv have a 1 or 2 long board call the LCD inverter boards,they are dead.These 1 or 2 long LCD inverter boards help the LCD screen panel to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those 1 or 2 refurbishes long LCD inverter boards for the replacement.
Dec 10, 2010 | Toshiba 32HLX95 32 in. LCD TV/DVD Combo
Philips Magnavox TV turns itself off and on
I had a problem that has not been fixed that i had put glass cleaner on my tv and every time i turn it off it comes back on sooo i do not have a solution so i need more and cheap ways to fix my tv.
p.s. i am 9
May 19, 2009 | Philips Magnavox 32PS55S 32" TV
The volume is turning itself down all by itself. The volume on the remote won't work, but the remote is fine with the other TV controls.
It sounds like the button is stuck. Take the remote apart if you can and see if the key is stuck somewhere. This happened to me once with a rubber key type of remote. It drove me crazy.
May 10, 2009 | Sansui HDLCD3210 32 in. LCD TV
Samsung SPN4235 has a mind of its own
Honestly,your TV should be still under warranty right?I would have Samsung fix it. TV had a serious problem from the beginning.
solutiondoct
Jul 31, 2008 | Samsung SPN4235 42 in. Plasma HDTV
TV keeps turning itself on and off, onto standby
Right i had this same problem for ages! i cannot explain why but when i uplugged my DVD player (which was flashing its light at the same time as the tv for some reason) the TV has worked fine.
Aug 24, 2006 | Philips TV Tuner Video Capture PCI Card -...
Televison & Video Logo
53 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
