Question about Maytag Neptune MDG5500AW Gas Dryer
Our two year old Maytag gas dryer is making a rattling noise. The noise is intermittent. Also, when the dryer turns off and the drum stops turning something else seems to "run on."
  • 171 Answers
This is most likely a broken wheel which is a wheel that the bearings have worn out on.If it is a wheel you should replace the set because if you replace just the one the others will wear out faster than they should.
Ps if it is only two years old it may still be under warranty!
Posted on Oct 07, 2010
6000 Series Rattle & Vibration
Sounds like the drum wheel or wheels need replaced .The twist frame thing just doesnt line up sorry ..LOL
Aug 19, 2013 | Maytag Dryers
Noises
After 15 years of service I imagine it will be hard to get the parts you want to repair it.. Newer machines may not dry as quickly as the older types but they use less power to do so.. Consider a new machine for the sake of the economics of the problem
Jul 26, 2013 | Maytag Neptune MDG5500AW Gas Dryer
Maytag gas dryer makes loud rattling noise. Not a squeaking noise, but something between a rattle and a fast, rhythmic knocking. Tumbler works, heat works, but insane noise.
sounds like the drum isnt balanced. either make sure appliance is properly balanced on the floor or make sure you are not overfilling the tub.
May 24, 2011 | Maytag MDE8000 Dryer
Maytag dryer makes rumbling noise when drum starts and again when
Sounds like a broken spring or a spring mount.
Jan 17, 2010 | Maytag Dryers
My Maytag gas dryer makes a loud rattle and clanging noise.
Prob. some failure of a bracket or loose inside...
Have a local tecnician check it out.
i think that ll be best cause i can't imagine that will be an easy fix.
I hope this is useful, and greets,
Olivier.
Oct 21, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag SD-8 about 10 years old. Making clunking
The reason to this problem is due to the bearing.
Sep 02, 2009 | Maytag PYE2300AY Electric Dryer
Rumbling noise in maytag gas dryer DG110 series 01
Unplug Dryer first: Page 3-11 of full service manual at link below will get front off. The most common solution for your problem is the blower wheel loose on the shaft. Hold drum and see if you can turn blower wheel (lower left plastic squirrel cage) separately. If you can turn the plastic wheel while you hold drum still, replace blower wheel.
http://www.servicematters.com/maytag_library/docs/16008714.pdf
Aug 22, 2009 | Maytag PYE2300AY Electric Dryer
Maytag gas Dryer is Noisy
If the noise is like a shaking of rattling , like coins being shaked , then it is an object trapped inside the drum.
If instead the noise is a loud grinding , that may get louder on high speed, then it is usually a bad drum bearing.
If dryer is not cooling, check that the noise is not coming from the ventilation fan.
Rollers and belt tensioner can also make noise.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Mar 19, 2009 | Maytag MDG7600AW Gas Dryer
Maytag Neptune MDG5500AW Gas Dryer Logo
191 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
