Question about Kitchen Ranges
Only one of the four knobs gets a spark/click (top knob, back right burner). I can light any burner from that knob. How do I fix the other knobs? What part do I need? Ron
    Genius:
  • 1,478 Answers
If one of your burner heating elements works only, it's probably because of worn or bad contacts in the receptacle that the element plugs into. On most electric ranges, you can remove the element by lifting it up several inches and firmly pulling it away from its attachment (receptacle). Read your owner's manual to learn the correct technique for your range. If, after removing the element, you see that the ends of the element that were plugged in are pitted, corroded, burned, scarred, or rusted, replace both the element and the receptacle.
Take care.
Posted on Oct 07, 2010
When the power is turned on at the wall, the automatic spark that lights the gas top comes on on the two right burners, and wont stop even after the light is lit. What can I do about it?
Behind the knobs for the right burners are 2 electrical switches that start the spark when you turn the knobs on. One of those switches is bad and stuck in the on position. You have to pull the knobs off and remove the trim behind the knobs to get to the switches.
Mar 22, 2015 | Lofra Kitchen Ranges
Spark igniter problem
The igniters probably should be replaced. You can order new ones for about 15 - 20 dollars each. They are easy to replace and sears parts direct will show you a printable schematic.
Jan 02, 2014 | Kitchen Ranges
Burner Igniter will not Spark
No, actually each knob has its own switch and any knob will energize the spark module which sparks at all burners. So, just replace the defective switch which slides over the shaft of the gas valve. Careful! unplug the unit, these are 120 volt switches. Good luck.
Jan 12, 2010 | GE Ovens
Ignitors constantly click.
Hi, it is possible, that your spark module, need replacing, but it could be other things too. could be faulty ignitor switch, whenever you turn knob to light burner, it activate switch, remove burners, lift top off, you will see, that each knob are connected to valve with two, or some model has one wire, connected to it, check for any breaks in wiring harness, could be something simple like bruise wire touching cooker body, etc. also turn knob and light any burner, turn knob clockwise all the way, let burner light, then gently turn knob counter clockwise and listen to hear if clicking stop, if clicking continue until burner goes off, it's possible you'll need to replace spark module, sometimes, they get short circuited, takes about 30 mins to replace module, $90/ hr. oouch, big companies, does that price, includes, price of module? can you get a regular repair guy, ask a friend they might know one. good luck.
Aug 08, 2009 | DCS RGS-305 Professional Gas Kitchen Range
GE Gas Kitchen sealed burner
I unplugged the wires from each end and re-attached the wires. Stove working great, no more clicking.
Dec 29, 2008 | GE Kitchen Ranges
Kenmore Gas Range - 2 knobs don't activate ignitor
there is a switch that is broken behind the knobs they cost no more than $15.00. remove the knob so that you can see it it's white in color.
Dec 10, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Only one burner of four not working
sounds like a bad switch in the knob, turn on the defective side, turn on the one that works and keep the clicking going then turn on the defective burner while "other" is clicking if this lights then it means you have a bad switch or loose connections
May 31, 2008 | GE JGBC20 Gas Kitchen Range
Maytag Kitchen Gas range
First of all- when you turn any ONE of the burner knobs to "ignite" all FOUR burners will spark/click. This is normal. If you're getting a spark from the ignitors when all knobs are set to "off" then you most likely either got some moisture into one or more of the switches below the knobs (sometimes they will dry out and be fine after a while, but I have seen them burn-up/melt/arc too) OR one or more of the switches is stuck/shorted. Good luck and hope this helps.
Unplug the range before working on it and don't attempt anything you're unfamiliar or uncomfortable with.
Dec 21, 2007 | Maytag MER6772 Gemini Electric Kitchen...
Igniter
It is normal for all 4 burners to spark at same time.  Often burners won't light even when you can see the spark at them because the burner is dirty.  Take a pin and clean out all the holes in rim of burner.  Also look for small cracks in white part of igniter.  If cracked it must be replaced.
Oct 21, 2007 | Kitchen Ranges
General Electric stove top burner does not light
whalerpaul, To get access to the gas burner valves you have to: 1.UNPLUG THE POWER CORD 2. Remove all burners 3. There are 2 screws under each burner, remove all of them and lift up the top panel 4. Remove all knobs, remove screws holding the manifold panel (two on top and four on the bottom) 5. Carefully pull out the manifold panel and remove two wires from the oven light switch, put the manifold panel on side Part number for the right front gas burner valve is WB21K12 and you can buy it here: http://click.linksynergy.com/fs-bin/click?id=SrmyP8LkIos&offerid=92089.542247749&type=10&subid=
Jan 14, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
