Question about Packard Bell Speaker Computer Speakers
My diamond storm speakers wont work - Packard Bell Speaker Computer Speakers
  • Packard Bell Master
  • 27,725 Answers
If they are on a computer and are not working you can try
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
hope this helps
Posted on Oct 07, 2010
2 Suggested Answers
  • 30 Answers
SOURCE: speakers wont work
have you tried downloading them from here
http://uk.gateway.com/support/productsupport.html
Posted on Jul 24, 2009
I need a manual for Diamond Audio's D971 component speakers, I need the thiele small parameters of these speakers
General •Speaker type car speaker Manufacturer Diamond Audio Technology Inc. Features •Amplification type passive •Driver configuration 2-way •Woofer size (inches) 7" m, 30mm m •Nominal (RMS) output power 200 Watt •Max (RMS) output power 400 Watt •Response bandwidth 35 - 30000 Hz •Input impedance 4 Ohm •Sensitivity 92 dB •Connectivity wired Compatibility ' Accessories •Included accessories mounting hardware Cutout & Mounting Dimensions •Diameter 6.3 in •Depth 2.7 in General •Manufacturer Diamond Audio Technology Inc. Thiss should help you out.
Jan 05, 2015 | Diamond Audio Car Audio & Video
Drivers
You may need an updated driver or make sure you have connected them to the sound card correctly.
Jul 04, 2014 | Packard Bell Storm Diamond Audio Speakers...
Hello, I have a woofer from a set of diamond 8.3 Wharfedale speaker. The woofer sounds like the coild is rubbing and emits a scratching sound. Looking for possible repir solution and the model no. for the...
Hello
The voice coil of your speaker is scratching with its magenet body inside. It can't be repaired. Whatever we do will go in vein. there is no possibility other than replacing this speaker. Some people will recone it, but qulaity cannot be assured. it will sound; but with respect to the other speaker, it won't match. Coil position, resistance, number of turns per unit length ete are determining the magnetic strenth of the coil, and therby sound. Wharfedale eill have its secret, and they wont give it out, as they have gained it with tremndous reserch.
So in my opinion, it will be best for you to replace the damaged speaker with and other one of same type and number. All details will be printed on its body. Buy the original one. Do not compromise. Woofers are the heart of any sound system. Keep this in mind. OK.
Mar 31, 2011 | Wharfedale Diamond 8 Cinema System
Can't get the back off of my Wharfedale Diamond's. Model 7.1
Sometimes the back does not come off, but the speaker comes out from the front...
Mar 22, 2010 | Wharfedale Diamond 8.3 Main / Stereo...
The HTC Touch Diamond phonecannot hear caller when answering call
try hard reset, if it does not help, put it to service, it could be broken speaker
Jul 06, 2009 | HTC Touch Diamond Smartphone
Blackberry storm buttons wont work
Have you tried pulling the battery? Often times my Storm has locked up and nothing worked. The only way to really do a restart, is by pulling the battery.
-Take the battery out and wait 1 minute. -Replace the blackberry and wait for Operating System to startup -Test
If this doesnt fix the problem, you may have a problem unit and you should take it in to the Verizon Wireless store.
Jun 20, 2009 | RIM BlackBerry Storm 9530 Smartphone
Problem with Diamond 8.4
No - sounds like the speaker/ cross over is faulty - I assume there are only one set of connections on the back - on some speakers you have 4 connections for dual wiring - and you usually bridge those out Play a piece of music with some drumming in it and you should see the midrange move a lot Just to make sure there is not a problme with the Amp - swap the speakers around - so you have a left speaker and a right speaker connected physically move the left speaker over to the rightside and connect to right side cables - and the right speaker to the left side and connect to left cables Now if the problem goes over to the other side - its the speaker thats fault if it stays on the sam side - its the amp
Apr 12, 2007 | Wharfedale Diamond 8.4 Main / Stereo...
Packard Bell Speaker Computer Speakers Logo
686 people viewed this question
Top Packard Bell Audio Players & Recorders Experts
David
David
SHIVAJI YADAV
SHIVAJI YADAV
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Packard Bell Audio Player and Recorder Expert? Answer questions, earn points and help others
