Question about Maytag Microwave Ovens
Maytag Washer will not wash dishes - starts the heat water cycle, but does not into the wash cycle. All buttons seem to work, have tried starting it on different cycles and the same thing happens. Will run through an entire cycle without washing the dishes.
  • kim_klipstei Oct 07, 2010
    It does heat up and there is water inside the dishwasher after about five minutes, however, it never starts washing. When opening it after the five minutes or so, it is all steamed up inside. I realized I accidently listed this under microwaves. I also have the model number if that helps. Model #MDB7600AWS It's a Quiet Series 300. It is seven years old.
    Just wondering if another expert would agree that the unit needs to be replaced.
  • 2,069 Answers
Make sure your washers buttons are fully depressed. (For your safety, the washer will not agitate or spin unless the door is closed and locked.) also, the lid switch, which prevents the washer from agitating or spinning when the lid is open, could be malfunctioning. If that happens, a built-in failure detector will stop washer operations until the lid switch is repaired. In that case, please contact an authorized Maytag service provider for assistance. you may use this service locator here.
Posted on Oct 07, 2010
  • Muzahura Frank Oct 08, 2010
    seven years, it rightly should be time for service.. but if you cant locate a service center nearby, go ahead and replace unit.
  • 2,973 Answers
Does the water heat up? To me it seems that the control module has gone. It works alright but does not make other components work. It may need a change.
Posted on Oct 06, 2010
  • Rinoo Kumari Oct 07, 2010
    Kim,
    My answer stay the same. It seems that the control panel has gone and it needs a change as repairing it would neither be possible nor economic. You must call the mechanic to do the needful.
My Maytag Microwave, Model MMV 4205 BAS has an issue. As soon as you close the door, there is a humming sound. This is without pressing [Start] or entering any time. I have tried pressing the [Stop/Clear]...
did it come into contact with water at anytime, if yes than this is probably the reason ask an electrician to come and have a check or if it is working fine you can continue using but make sure that no liquid will spill over inside
May 12, 2011 | Maytag MMV4205 Microwave Oven
It is an older model maching and it seems to be clogged and not cleaning the dishes..how do you unclog it
It would be helpful to know exactly what machine you have, but the bottom line is, you need to access the screen at the bottom of the machine, where the water exits into the pump. Many units have a macerator blade in front of the screen that chops up large particles of food so that they will pass through the screen. The blade is attached to the same shaft as the pump, which both supplies the high pressure water to wash dishes and pumps out the dirty water at the end of the cycle, and if there are small hard particles, such as bits of bone, plastic or broken glass in there, they can jam the blade so that the pump does not pump properly. You will need to remove the dish racks whatever covers, etc., are on the bottom inside the machine to get at the screen and/or macerator.
Mar 18, 2011 | Microwave Ovens
I need to know how to operate my Kenwood KGTS23 Microwave. I put it on, operate it on how I understood it, but it doesn't warm my food (it remains cold) Please where can I get a user guide/manual for...
Use a microwave safe dish and put in some water. Now open door and keep the dish on the glass plate. Close the door, select the power to be medium or high. Or choose a fast cook. Press 0 and the start button as the microwave should start up. If there is no heat after the cycle then it is possible that the magnetron, the capacitor or the fuse is open.
Jan 08, 2011 | Microwave Ovens
Dishes are not getting clean particularly in the upper rack. The soap dispenser opens properly but the soap was still there. The washer seems to fill properly and it sounds normal. The dishwasher goes...
Make and model?Is the water hot enough? Is this a new problem? Is all of the detergent still in the dispenser or do you use detergent both in the washer and the dispenser? Please reply to this inquiry for more help. Do you have the manual?
Jan 07, 2011 | Microwave Ovens
Our Magimix 11400 (less than 2 years old) heats normally, the vapour nozzle fonctions too, but our problem : when the coffee selection switch is put on the motors starts up, seems to fonction properly but...
Hello Pat, You have a common occurring problem. Your tubing in clotted. The least expensive solution is to use regular vinegar instead of water for several cycles, no coffee grounds. The clot will dissolve and water flow will return to normal. Cycle just water until no taste or smell of vinegar is present. Have some HOT COFFEE.
Oct 12, 2010 | Microwave Ovens
Hi. I have a Maytag mmv5207bcs Microwave. Pressed...
mmv5207ba/bc microwave 0 button fan on button does not work all other key pad buttons seem to work
May 21, 2010 | Microwave Ovens
Wash cycle wont finish start button does an 8 flash cycle
Hi, these machines get corrosion in the door safety switch. I would start there.
A little cleaning of the contacts might get that machine going. How about a repair manual?
I have a few:
http://docs.google.com/fileview?id=0B5If-wTgYWH5ZmJjMzhhMmYtNTI1Zi00MDExLThiNTMtYmE0NzQ3OTdmNGFi&hl=en
Take care
Apr 11, 2010 | Microwave Ovens
It is stuck on wash cycle
The cycle select knob may need to be replaced, or u may have a bad solenid in your washer. If a solenoid is bad, it wont allow the washer to go past a certain point in the cycle.
Nov 28, 2009 | Microwave Ovens
MMV5000BAW maytag over-the-range microwave
Found this in the GE section instead of Maytag, but we're happy to answer it anyway.
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Let us know if the hard reset doen't fix it.
If not, you may have a shorted keypad or bad control panel, either of which we can repair economically.
Please write back with more details if you need further help.
Nov 25, 2007 | GE JVM1870 Microwave Oven
Self start when door closes
if electronic control, one of two things come to mind. 1)your toutch pad is defective.replace it. 2)you electronic board has a leaky component.not very likly though. believe it or not, ive seen it start before by itself then i noticed a large quantity of bugs inside the glass which i realised triggered the microwave 0ff.
Jul 23, 2007 | GE JVM1460SA Microwave Oven
Microwave Ovens Logo
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
