Question about Whirlpool Dishwashers
How to fixerr 4 its saying overfilled. to much inlet water
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. If the dishwasher is overfilling it's caused because of water-inlet valve going bad. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it. If the water-inlet valve is defective, you need to completely replace it. Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Oct 07, 2010
What does it mean when it says PE on my lg wm0642hw washing machine
The PE error or fault code indicates that the machine is overfilling with water. This washer is equipped with a water level pressure switch. As the machine fills, the pressure increases on the switch, at the set pressure, the switch cuts power to the water inlet valve and the water stops flowing into the washer. If the pressure switch fails to sense properly, or the water inlet valve fails to shut off the unit can overfill. This situation can also be caused if the machine does not drain properly. First, check to see if water ever enters the machine when it is turned off. If so, replace the water inlet valve. Next, check the drain line to be sure it's not clogged or kinked. Next, check to see if the drain pump is working properly and removing the water from the previous cycle. If all of those check out, you may need to replace the pressure switch.
Jul 29, 2016 | LG 4.0 cu. ft. Front Load Washer, White -...
Hi I have a lg fuzzy logic wf-1022tp top loader. When I switch it on it says PE pings whole time please HELP
PRESSURE SENSOR ERROR // Water level pressure switch error
The manufacturer has assigned this error or fault code to indicate that the machine is overfilling with water. This washer is equipped with a water level pressure switch. As the machine fills, the pressure increases on the switch, at the set pressure, the switch cuts power to the water inlet valve and the water stops flowing into the washer. If the pressure switch fails to sense properly, or the water inlet valve fails to shut off the unit can overfill. This situation can also be caused if the machine does not drain properly. First, check to see if water ever enters the machine when it is turned off. If so, replace the water inlet valve. Next, check the drain line to be sure it's not clogged or kinked. Next, check to see if the drain pump is working properly and removing the water from the previous cycle. If all of those check out, you may need to replace the pressure switch.
Jul 04, 2016 | LG Washing Machines
My lg fuzzy logic shows PE
The PE or pressure sensor error or fault code indicates that the machine is overfilling with water. This washer is equipped with a water level pressure switch. As the machine fills, the pressure increases on the switch, at the set pressure, the switch cuts power to the water inlet valve and the water stops flowing into the washer. If the pressure switch fails to sense properly, or the water inlet valve fails to shut off the unit can overfill. This situation can also be caused if the machine does not drain properly. First, check to see if water ever enters the machine when it is turned off. If so, replace the water inlet valve. Next, check the drain line to be sure it's not clogged or kinked. Next, check to see if the drain pump is working properly and removing the water from the previous cycle. If all of those check out, you may need to replace the pressure switch.
May 30, 2015 | LG Washing Machines
My LG model WM1812CW washing machine is leaking water and says FE in the display
problem with the inlet valve or oppressor switch,because of the overfilling water, sawing FE ERROR
Jan 26, 2014 | LG Washing Machines
Overfills
faulity water level switch {test & replace} stuck inlet valve test clean or replace . level switch is located in the control panel it will have an air tub connected to it. set vom meter on RX1 look for 0 on one infinity on others. inlet valve inside were hoses go in same setting should read 100 to1000 ohms on each
Nov 28, 2009 | Boating
My dishwasher is saying 'error 4' on the panel and it is beeping, can't find the instruction manual to work out what the problem is. It's a whirlpool
Error Code 4
Error Code 4 means: Overfilled - Too much inlet water. I found by disconnecting the water supply (after turning it off) then reconnecting it fixed it http://kitchen.manualsonline.com/ex/thread/view/idThread/231213
Sep 27, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
OVERFILLED AND FLOODED HOUSE
1 of two problems happened.
1) either the water level sensor went bad. Which tells the water inlet valve when to shut off and the machine to start operating.
2) The water inlet valve has failed. This comes from the water hose and fills the washing machine.
May 25, 2009 | General Electric WCSR2090D Top Load Washer
Kenmore ultra wash 665.16761690
If it is not overfilling, and then leaking, the whirring noise can be a defective water inlet valve, that stays stuck on open, see here : It's overfilling
If it is not overfilling, the two problems may be unrelated, and the noise can be froma foreign object inside the object trap.
See here about leaks and noise
It's noisy
It leaks
Oct 08, 2008 | Kenmore 16919 Built-in Dishwasher
Machine over filling even when set on min. simpson enduro 701
When the machine is overfilling , it means that there is a problem with the inlet valve (valve not closing) or with the water level switch, that should turn off the valve when water reaches level.
See the suggestion from It's overfilling at repairclinic:
It's overfilling If your washer is overfilling, check these:
Water-inlet valve
Water-level switch
Water-inlet valve A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve.
Water-level switch A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
Oct 06, 2008 | Washing Machines
Dishwashers Logo
149 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
