Question about Sony A1246282A - VAIO VGN-N Series Laptop Motherboard MBX-160
Hello i have one problem my personal computer, i dont remeber install the password bios, now the sistem dont began, i need the passwort to this mother board , thanks!! mbx-160, sony vaio vgn-n130f
    Master:
  • 388 Answers
I forgate my passwort code to geth in to the computer...can you help me please
Is it the account password you have forgotten, or the BIOS password?
Dec 29, 2013 | Computers & Internet
At first, sorry for my bad english. If I start my "IBM Thinkpad T43", I get a misstake and can't start. On the screen I see: Error 0271 check time and date, and then he want a passwort for...
On a T43 there is no way to enter the Bios without knowing or GUESSING the correct password this is true for all T4x laptops the only way I can suggest is to get a new motherboard from Newegg or from ebay or something but unless you have a specific reason for needing into the bios and you can run windows I would continue to do that until such a time should arise, and maybe keep trying to guess the correct password. Most people use password that have something to do with themselves so think about what you may have used. Also try to think back to the occasion that made you set the password and try to imagine you are reliving it, you'd be amazed at what you can remember from doing this.
Good Luck! hope the correct Password comes to you!
Jun 08, 2011 | IBM ThinkPad T43 Notebook
Ich habe Toschiba tecra a8 bei start jetzt verlangt plözlich system Passwort komm nicht in Bios\r\nbitte help my was ich kann tun ? ich habe keine Passwort gegeben und ich auch nicht weiss was ist...
Im not sure i understood all in German ...but I guess you are talking that you have a BIOS password that you do not know ...and you need access that it is denied cause of this password..
To get rid of it ..you will have to open the computer ..and get to the motherboard and remove the Bos battery for a few seconds..This will remove any passwords and reset it to the factory optimal defaults..
I will try to translate in German the basic part ..
?ffnen Sie den Laptop und entfernen Sie die BIOS Batterie seit ein paar Sekunden.. STELLEN SIE es .. ZUR?CK und schlie?en Sie es.. Das wird das Kennwort entfernen..
Sep 02, 2010 | Toshiba Computers & Internet
Cant remeber my bios password
This information is intended for experienced users. It is not intended for basic users, hackers, or computer thieves. Please do not try any of following procedures if you are not familiar with computer hardware. I'll not be responsible for the use or misuse of this information, including personal injury, loss of data or hardware damage. So use it at your own risk.
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
May 19, 2010 | Toshiba Satellite Pro L350-S1701 Notebook
Administrator Passwort vergessen
I think you forget the admin password...You can remove the password by using the below steps...
1. Place your Windows XP CD in your cd-rom and start your computer (it’s assumed here that your XP CD is bootable – as it should be - and that you have your bios set to boot from CD)
2. Keep your eye on the screen messages for booting to your cd Typically, it will be “Press any key to boot from cd”
3. Once you get in, the first screen will indicate that Setup is inspecting your system and loading files.
4. When you get to the Welcome to Setup screen, press ENTER to Setup Windows now
5. The Licensing Agreement comes next - Press F8 to accept it.
6. The next screen is the Setup screen which gives you the option to do a Repair.
It should read something like “If one of the following Windows XP installations is damaged, Setup can try to repair it”
Use the up and down arrow keys to select your XP installation (if you only have one, it should already be selected) and press R to begin the Repair process.
7. Let the Repair run. Setup will now check your disks and then start copying files which can take several minutes.
8. Shortly after the Copying Files stage, you will be required to reboot. (this will happen automatically – you will see a progress bar stating “Your computer will reboot in 15 seconds”
9. During the reboot, do not make the mistake of “pressing any key” to boot from the CD again! Setup will resume automatically with the standard billboard screens and you will notice Installing Windows is highlighted.
10. Keep your eye on the lower left hand side of the screen and when you see the Installing Devices progress bar, press SHIFT + F10. This is the security hole! A command console will now open up giving you the potential for wide access to your system.
11. At the prompt, type NUSRMGR.CPL and press Enter. Voila! You have just gained graphical access to your User Accounts in the Control Panel.
12. Now simply pick the account you need to change and remove or change your password as you prefer. If you want to log on without having to enter your new password, you can type control userpasswords2 at the prompt and choose to log on without being asked for password. After you’ve made your changes close the windows, exit the command box and continue on with the Repair (have your Product key handy).
13. Once the Repair is done, you will be able to log on with your new password (or without a password if you chose not to use one or if you chose not to be asked for a password). Your programs and personalized settings should remain intact.
Hope you will succeed....
Nov 24, 2009 | Computers & Internet
Clear bios passwort
Unplug the power, remove the battery, check the battery compartmnt, there should be a small screw or slot and a yellow or white or black plastic encased thin watch battery with red and black wires, you need to detatch it and attach back after 10 seconds. It will clear the CMOS settings including password.
May 20, 2009 | IBM ThinkPad T20 2647 Notebook
There is a power on password in my laptop hp cant get it to boot
It is a BIOS password. If you do not remeber it the only solution is to remove the round battery from the mother board and reinsert it. Turn on the laptop. It will directly take you to the BIOS scree. Restore the default bios setting. Save and exit and your laptop will turn on
Oct 10, 2008 | Computers & Internet
A friend install my mother computer. how to jumper
Set the jumper to recovery or to clear
CMOS Jumper
1-2 - Mostly normal
2-3 - Clear
0-0-0 Recovery no jumper
Its a basic conscept it can change according to your bios manual you follow - Trace the cmos jumper exactly dont short any other jumper
Jul 25, 2008 | EliteGroup Computers & Internet
Dont remeber my password
If the password you forgot is the user password, reinstalling the operating system will help you. If the password you forgot is the bios password(one which should be entered before boot up), you could reset it by removing and resetting the button cell present in the mother board.
May 13, 2008 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
PASSWORD
IF ITS BIOS PASSWORD NEED TO BE REMOVED FROM MOTHER BOARD OF NOTEBOOK, IF WINDOWS PASSWORD YOU MAY FORMAT WITHOUT REMOVING THE PASSWORD. BUT YOU WILL LOOSE DATA FROM THE HARD DRIVE.
Feb 26, 2008 | Toshiba Satellite 2430-S256 Notebook
Sony A1246282A -  VAIO VGN-N Series Laptop Motherboard MBX-160  Logo
340 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
