Question about Acer Aspire 3050-1733 Notebook
I turn on my Acer Aspire 3050 and get a power light but, nothing on the monitor. I have tried taking off the battery and unplugging the power source, holding down the power key for 20 seconds. When I try to turn I still have a blank screen. I can hear the fan running and the power light is on.
  • Acer Master
  • 4,924 Answers
If you do have the devices displayed on screen when you start it ..before getting to windows screen ..and this blank screen only gets after ..It may be a windows error ...and reinstalling it or running the recovery partition will fix this ..It may be related with the updates for video card ..made auto ..and installed a wrong driver or setting ..(unsupported ) ..If this is the case try to turn it off by unplugging ..and will give you the boot mode screen ..where you should load safe mode..If you manage to load it in safe mode just reinstall the video driver for it and it may work ..
Another case it may be a damaged display screen or damaged wiring or the inverter for it ..(in this case you should check and see what s wrong and change the inverter if it is the case..Basically you will have just shadows on screen and miss the back light )..
anyway ..try to see if it starts to bios at least ..and if it does..it is just a corrupted windows and need to be reinstalled from scratch and will work ..
If it does not load windows either bios settings ..but still opens and looks blank ..(this I assume it does not mean it do not open ..but opens and shows an empty screen ) You may see the cause for not loading BIOS ...the cmos may be damaged or the battery for it empty ..and you will need to reinstall Bios ..
Usually if it is a damaged video card will not open at all and make some beeps noises ..so this may be excluded..So ..it is either the operating system ..or the wrong driver for video ..(and wrong ..unsupported setting ..and in this case will even load windows but you can not see it pass the windows logo ..and you should hear the log in ..
Or it may be something wrong with the ram memory and in this case is explainable if it does not load bios settings ..To see about this..just open the back lid for ram memory ..and remove them ..and place them back one by one ..and try to boot up each time ..If it shows devices and loads at least bios ..with one ..it means it works ..check them all and eliminate the faulty ones..Try several times to press them in the slot ..cause sometimes just do not make a good contact and nothing wrong with the modules physically .
Posted on Jan 02, 2012
Bios password reset scer 3050
Try removing the main battery and unplug the power, then hold the power on button down for 30 seconds, if this does not work, remove the cmos battery for 30 seconds to reset the bios
Apr 01, 2013 | Acer Aspire 3050-1733 Notebook
Acer aspire 3050 not switching on. On/off no affect.
Sounds like either the battery pack or the DC Jack has a problem.
First I would try a known good battery pack. If that does not work then more than likely it will be your dc jack. The jack itself is not very expensive and if you are good at soldering then you've got it made. If you prefer you can get a local tv shop to do the soldering for you. Good luck!
Jun 07, 2010 | Acer Aspire 3050-1733 Notebook
I have acer 3050 is switch on but no display
Hi! Try to check if there is a hotkey to turn on/off lcd display. If none, try to power drain the machine by unplugging ac adapter and removing the battery.Press and hold the power button for 10 secs and then after that put the battery back and plug in ac adapter.Press power button and then check if you will see anything on the screen,if still the same then try to connect the laptop to a external monitor and then press FN+F5 to switch display to external monitor, if you see something on the ext monitor it means you are dealing with a faulty lcd on your laptop...Hope this helps...
May 20, 2010 | Acer Aspire 3050-1733 Notebook
I have acer 3050 is swtich on but no display
try this step:
Turn off the pc remove cables and battery on the laptop Press and hold the power button for 5 seconds Reinsert the cable and battery Turn on the pc If the screen won't turn on, check the power button of the monitor if it is on. If it does not, please call the tech support of Acer 1-800-816-2237 for possible replacement of battery...
Acer Aspire 9300 My Aspire 9300 has worked fine
It maybe the problem of your graphics processor,so you can't see the NOOK working normally .Your Acer Aspire 9300 battery haven't effect to this mattery ,why you tried taking it out !
May 18, 2010 | Acer Aspire 9300 Notebook
Will not power up. Green light on power source
Please do a power drain. To do so:
Turn Off the laptop, uplug battery, unplug power cable and any external device. Keepon holding the Power button for 10 secs. Plug all the devices & battrey. Turn On the computer. It should take care of the issue.
Mar 23, 2010 | Acer Aspire 9500 Notebook
Acer Aspire 5610 that wont boot up
Take battery out, press and hold power button for 10 secs, reinsert battery and try again?
Aug 15, 2008 | Acer Aspire 5610 Notebook
Connector cn2 aspire 3050
i cant turn on my acer 3050
battery and adapter are working fine
i mean nothing wrong with them
just i cant turn it on
please help!
thank you
May 21, 2008 | Acer Aspire 3050-1733 Notebook
Frozen keyboard acer 5100
for aspire 3050, try to remove the battery, battery can cause many strange thing.
if you still got problem after removing battery, it's look like motherboard need repair.
Mar 02, 2008 | Acer Aspire 3000 Notebook
3050 will not boot
Try a different power supply. Plug in the AC with the battery out.
Jan 18, 2008 | Acer Aspire 3050-1733 Notebook
Acer Aspire 3050-1733 Notebook Logo
70 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
