Question about Toys
I can't fold up my Cosco Play Yard 05028. Specifically I get all the sides unlocked but they won't fold up into their upright position (i.e., compact enough to get back into the carry bag.
Hi You have to remove the floorboard and pull up on the strap in the center of the floor before you do anything else, then you unlock the long rails followed by the short rails. If the lock won't release pull center strap higher and try again. Hope that helps!
Posted on Oct 15, 2010
How to fold down the cosco funsport play yard.
There is usually buttons under the cover in the middle of each side? Squeeze this and the side should collapse, then usually a pull up in the middle which reduces the cot right down. Hope it helps
Apr 16, 2012 | Cosco Juvenile Cosco Funsport Playard
I can't fold my treadmill back up. Instead of folding upright at the 12 o'clock position it is tilted to the 11 o'clock position. Any ideas why it won't go all the way upright?
1) SEE IF SOMETHING IS PENDING between the folding section
2) Your Pin is little bend.
3) the receiver where the pin is coming is not adjusted.
sincerely.
Sep 14, 2011 | HEALTHRIDER S300i Treadmill Motor Control...
Can you send me the directions for setting up the cosco playpen
Try this step by step instructions Hope it help you
Instructions
1. Unfasten the floorboard from the folded play yard frame by loosening the hook and loop tabs holding it in place.
2. Unfold the play yard and set it upright with its four legs on the floor. Pull out on opposite corners to spread the legs of the frame.
3. Pull up on the plastic handle in the center of the floor of the play yard to unlock it fully.
4. Pull up firmly on the center of each of the four side rails until they click into place, while continuing to pull up on the center handle.
5. Push the center lock down until it clicks all of the legs into place.
6. Place the padded floorboard into the play yard.
7. Locate the two hook and loop tabs located on the underside of the floorboard and pull them through the slots in the bottom of the play yard frame. Secure the tabs underneath the play yard.
Jul 02, 2011 | Cosco Juvenile Cosco Funsport Playard
We cannot get the hinges to release on our cosco play yard. So that we can fold it for carrying We have read the directions and squeezed as hard as we can in the center but it still won't release to fold...
Try pushing the hinge more as if you are locking it in place, before you squeeze to release.
i.e. If when the hinge releases it goes 'up' - push 'down' firmly on the hinge, squeeze to release and then pull up.
Oct 03, 2010 | Cosco Beatrix Potter Playard Crib
Cosco Play Yard Setup problems
you have to have the middle pulled up towards you then you lock the sides in to place and push the middle back down, it took me an hour to figure it out...lol
Oct 12, 2009 | Cosco Beatrix Potter Playard Crib
Locking the top of cosco playpen
How do I set up the costco play yard; I cannot make the side bars lock -- and there are no instructions with it.
Jul 01, 2009 | Cosco Beatrix Potter Playard Crib
Folding up Cosco play yard
My wife and I have the same model for visits by our granddaughter. She was having the same trouble as were you and, like you, we did not have instructions.
I'm happy to share with you what I found to close the model up for storage. It may not be the same as what the manufacturer envisioned but it worked for us.
-- With the pad removed from the inside of the Pack n Play, pull up on the red handle so as to loosen the legs;
-- Next, you will find there is a big button in the middle of each of the long sides of the Pack n Play. Start with either long side. You will have to press very hard on either side of that button; I found it helpful to use both hands, one pressing on the outside of the playpen, the other hand pressing on the inside of the playpen. Pressing these together will loosen the long support arm at the open top of the Pack n Play.
-- Do the same for the opposite long side.
-- You will also do the same, one button, one side at a time, for each of the two short sides of the Pack n Play.
-- Now pull up on the red handle in the middle, and guide the four corners so they meet and close.
-- Cover.
I found the buttons may not have fully allowed the support arms to collapse, thus blocking the Pack n Play from folding down completely. If so, try pressing the button again (both the outside and the inside at the same time).
Hope this helps!
Jan 06, 2009 | Cosco Beatrix Potter Playard Crib
Play yard assembly COSCO Funsport L-3
for Model Cosco Funs Port Play Yard
Just pull the cord in the middle of the upward and straighten out
each poll one by one. If you have someone that can help you
open the play yard pull lightly up the four sides and while you're holding them up, pulled the middle strip that located inside pull it up it will lock all four sides at the same time.
I don't have childred, but it drove me crazy that I couldn't do this
until my wife said maybe this is how you do it, I tryed it and it worked. I hope this helps everyone. Regards,
Frankie.
Jul 11, 2008 | Cosco Beatrix Potter Playard Crib
Cosco Playpen
-- Cover.
By the way, I've found it to be an exercise in frustration in trying to obtain an instruction manual from the manufacturer. I'm very disapopinted with this purchase and in particular this company.
Hope this helps!
Jul 01, 2008 | Cosco Beatrix Potter Playard Crib
you also need to hold one of the middle indicator tabs on the longer side..because if you don't do that it will not shut... and make sure the 2 legs go inside with the center of the play pen
Dec 03, 2007 | Cosco Beatrix Potter Playard Crib
Toys Logo
206 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
